Old 01-12-2013, 05:05 PM   #46
RustyStuff
RustyStuff's Avatar
Oddometer: 852
I used Dawn Dish soap and a Stiff brush to take unknown years worth of goo and road grime off my aluminum rims.
I'll do it again this year.
1980 Suzuki GS450 Confused bitsabike.
1990 Kawa KDX200 Desert sled.
RustyStuff is offline   Reply With Quote
Old 01-13-2013, 08:23 AM   #47
GravelRoad
Feckless Warrior
GravelRoad's Avatar
Oddometer: 30
mr Clean Magic Erasers do a great job on the chrome rims on my KLR as well as the aluminum painted ones on my CBR.
GravelRoad is offline   Reply With Quote
Old 01-13-2013, 11:19 AM   #48
atomicalex
silly aluminum boxes
atomicalex's Avatar
Oddometer: 2,994
I just had to do this, and since my chain cleaner was not immediately at hand, I used WD-40. And it worked!
Katherine, in words - F650GSa - CBR250R (sold) - Super Sherpa - Nine Days in the Alps - More Alps: Finding GS Land
atomicalex is online now   Reply With Quote
Old 01-13-2013, 03:56 PM   #49
SRG
SRG
SRG's Avatar
Oddometer: 1,319
4 pages and no one suggested "3M General Purpose Adhesive Remover"?
Geesh.
Works very well on all sorts of stubborn stuff. Won't harm paint. Will strip wax.
Available at auto body paint stores.
No garage/workshop is complete without it.
SRG is offline   Reply With Quote
Old 01-13-2013, 04:20 PM   #50
ttpete
Rectum Non Bustibus
Oddometer: 6,063
I use Coleman lantern fuel (naphtha). Cuts the grease instantly and leaves no residue. Doesn't hurt paint.
Old 01-14-2013, 12:18 PM   #51
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,916
Don't bother cleaning oil splatter off you wheel rims - just cover it up with mud.
Seriously, I have obtained the best results with warm water, dish soap and (the key ingredient) elbow grease. A purpose-made wheel brush helps greatly for between spokes, etc.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 01-15-2013, 10:07 AM   #52
urbanXJ
urbanXJ's Avatar
Oddometer: 3,107
chain cleaner works well but I use WD40
...SPEEDING PAST THE LINE OF GOOD TASTE...
urbanXJ is offline   Reply With Quote
Old 01-15-2013, 12:55 PM   #53
SRG
SRG
SRG's Avatar
Oddometer: 1,319
Holy cow - what is the fascination with using xyz products for something other than their intended purpose? Sure, in a pinch or when an proper product is expensive or unavailable, but that's not the case here.
3M General Purpose Adhesive Cleaner is not expensive, is readily available and is an excellent solvent that will not harm paint and leaves no residue. Your garage should have some. A can like this will last you a long time, buy some for christ's sake - o yeah, the KLR thing :
http://www.waresdirect.com/products/...FQU5nAodLggAAw
Old 01-15-2013, 01:07 PM   #54
rbrsddn
3banger
rbrsddn's Avatar
Oddometer: 2,781
I've got a can of the 3M and it will remove anything, including brain cells! Definitely use that stuff with lots of ventilation!!!!
rbrsddn is offline   Reply With Quote
Old 01-15-2013, 10:37 PM   #55
JonXX
Infraction Collector
JonXX's Avatar
Oddometer: 384
I clean the chain wax gunk and brake dust off my wheels with...Wait for it...Wheel cleaner.
Unlike kerosene, wd-40, and others, it doesn't make my tires slick.
Hungry? Out of work? Nowhere to ride? Do us all a favor and eat a Sierra Club member.
"They" said we couldn't run the OBDR on supermotos...
JonXX is offline   Reply With Quote
Old 01-17-2013, 06:44 AM   #56
urbanXJ
urbanXJ's Avatar
Oddometer: 3,107
That is a decent mix of solvents. We used to buy that by the bucket for cleaning and thinning contact cement (plastic laminate work).
Read the MSDS you may be shocked at what all is in there. I would not consider it safe on most plastics.
http://www.google.com/url?sa=t&rct=j...41018144,d.b2I
Ingredient C.A.S. No.
HYDROTREATED LIGHT NAPHTHA (PETROLEUM)
XYLENE
PROPANE
ETHYLBENZENE
TOLUENE
BENZENE
I have a slight feeling it is one of the reasons my uncle had those liver issues.
Old 01-17-2013, 07:40 AM   #57
ttpete
Rectum Non Bustibus
Oddometer: 6,063
Goof-Off is nothing more than xylene. You can get a whole quart for the same price as 3 or 4 1-ounce cans of the former.
Old 01-17-2013, 08:02 AM   #58
urbanXJ
urbanXJ's Avatar
Oddometer: 3,107
According to the MSDS, Goof off is 60% Acetone and 10-30% Xylene.
But yes, you can buy both by the gallon for much cheaper.
Hazardous Components (Chemical Name)
1. Acetone
2. Xylene (mixed isomers) {Benzene, dimethyl-}
3. Ethylbenzene {Ethylbenzol; Phenylethane}
4. Hydrotreated light distillate (petroleum)
5. Diethylene glycol monobutyl ether
CAS #
67-64-1
1330-20-7
100-41-4
64742-47-8
112-34-5
Concentration
60.0 -100.0 %
10.0 -30.0 %
1.0 -5.0 %
7.0 -13.0 %
1.0 -5.0 %
{2-(2-Butoxyethoxy)ethanol {(a glycol ether)}
4
Old 01-17-2013, 08:24 AM   #59
ttpete
Rectum Non Bustibus
Oddometer: 6,063
1. Acetone
CAS #
67-64-1
1330-20-7
100-41-4
64742-47-8
112-34-5
Concentration
60.0 -100.0 %
10.0 -30.0 %
1.0 -5.0 %
7.0 -13.0 %
1.0 -5.0 %
4
Straight xylene works just as well.
I keep small amounts of various solvents around, things like alcohol, acetone, xylene, lacquer thinner, toluene, MEK, trichlor, etc. Even some cyclohexane. It makes it easier to find out which solvent won't affect a certain plastic or paint.
Old 01-17-2013, 08:47 AM   #60
urbanXJ
urbanXJ's Avatar
Oddometer: 3,107
Denatured alcohol is methanol/ethanol mix. Good for removing ink stains form cloths.
Xylene solavates wax and chewing gum too. Great if you need to cleanup after changeing a wax ring on your toilet or if the kids get gum in your carpet.
Colman fuel/white gas is just naptha. Makes for a cheap substitute for WD 40 if using for cleaning reasons.
Think I will try that next time.
Times are GMT -7.   It's 04:35 AM.
