Old 02-27-2010, 01:42 PM   #1
h2smokin OP
Oddometer: 43
any it465 owners out here?
I'm just curious what I'm getting into. Friend of mine had 1 I'm getting for a $100. Ir runs and is 90% complete. It does foul plugs and needs the compression release lever fixed but for the money what the heck. How are parts and stuff to get? Also how do they ride? I've only heard they are a handful. Thanks
h2smokin is offline   Reply With Quote
Old 02-27-2010, 08:52 PM   #2
kdxkawboy
Mr. NVKLRGirl
kdxkawboy's Avatar
Oddometer: 2,631
Be thanklful it's not the IT490. The 465 was sweet where the 490 was a beast. The only thing you'll face is soft suspension. Very good for a play bike, but too soft for competition levels. The engine has one of those sweet power band: great torque and good top end power.
Parts Bandit still lists the parts fiche so would expect Yamaha still has the important parts available.
When the going gets weird, the weird turn pro
kdxkawboy is offline   Reply With Quote
Old 09-24-2010, 04:39 AM   #3
GravelTrygve
Oddometer: 17
Hi.
I bought one 1981 IT 465 yesterday. It was quite hard to start it, so i wonder if anyone have a "How-to start an old big two-stroker" guide?
Should I twist the throttle a few times before I kick, and how can I determine that the piston is in right position etc etc.
How many % of oil do you mix in the fuel?
GravelTrygve is offline   Reply With Quote
Old 09-24-2010, 06:36 AM   #4
gplassm
gplassm's Avatar
Oddometer: 588
Some tricks I used to use when starting big bore finicky 2 strokes:
1) Try tipping the bike over on its side, until fuel dribbles out the carb over flow.
or
2) Stick the bike in gear and rock it back and forth a couple of times. This will get a fuel/air charge into the cylinder.
For either method, make sure you ratchet the kick start lever all the way up before you kick it. You can often "feel your way" to catch one more tooth on the ratchet system. This can help immensly.
Street bikes for the street. Dirt bikes for the dirt. Let's keep it that way.
gplassm is offline   Reply With Quote
Old 09-24-2010, 08:23 AM   #5
GravelTrygve
Oddometer: 17
Thanks! It is basicly the same in this video:
http://www.youtube.com/watch?v=FamfgXMW9Mc
It started on the second kick after a little blow-job ;-)
Old 01-17-2013, 06:27 AM   #6
RoyVanas
Oddometer: 4
Shocker!
1. I use 20:1 Mixed 110 octaine fuel & caster Klottz oil. 2. I turn on fuel & twist throttle once. 3. turn choke on. 4. stand on metal milk crate then find top dead center & kick starter on top of stroke. 5. jump on the pot licker like it owes me money. 6.Ride untill tank is empty to have most possible fun with out having to re-start.= I LOVE MY 465!
RoyVanas is offline   Reply With Quote
Old 01-17-2013, 12:29 PM   #7
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,742
I use those same gloves at work
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust, big tube header, 6 Sigma stage 3 carb mods
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is online now   Reply With Quote
Old 01-17-2013, 01:12 PM   #8
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,834
i had two YZ465H's both with IT465 lighting kits installed with Rego for road use. loved them great bikes.
at Ngarkat consevation pk
this one was port & polished & using a TT600N Disc front end.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Times are GMT -7.   It's 03:36 PM.
