Old 01-17-2013, 11:42 PM   #4816
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,125
Originally Posted by RandoCommando View Post
The 2008 and newer KLRs had an issue with the wiring harness rubbing in certain spots.
Did you have the recall done for the armoring?
2009 KLR, had the "recall" done on this model. But there were a few areas that they still didn't get. One area said the front fairing, so took that off and found a tiny little cut on one of the wires. It was being rubbed on the soft metal hold down. That little wire kept shorting the main fuse as soon as it got power. Taped it up good, put the fuse back and bike starts fine.
This spot, looking at the front of the bike sans fairings.
Tiny little rub-through
The culprit - Note the two sparky areas.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is online now   Reply With Quote
Old 01-18-2013, 12:18 AM   #4817
PNWcrazymike
PNWcrazymike's Avatar
Location: Bend, Oregon (in the sunny half of the state)
Oddometer: 24
Problem spot
Thank you for the photos! I'll take a look at mine now I know what/ where to look for!
PNWcrazymike is offline   Reply With Quote
Old 01-18-2013, 04:51 AM   #4818
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,524
That's just crazy, man.
The Murph Channel
Acoustic Originals and some Double Aught
http://www.youtube.com/channel/UCkomGsMJXH9qn-xLKCv4WOg
Murphy Slaw is offline   Reply With Quote
Old 01-18-2013, 07:54 AM   #4819
Aprilia
Oddometer: 668
GenII's have about 6 consistent places that develop rub thru's but I've seen a few others on more than one bike. Strip the bike down and just start going over EVERYTHING.
Aprilia is offline   Reply With Quote
Old 01-18-2013, 10:41 AM   #4820
KamikazeKLR
Shorty on the 650
KamikazeKLR's Avatar
Oddometer: 596
Hey everyone, I haven't posted on this thread in a while but I'm going from Winnipeg to St. John's, Newfoundland on the old '02 in may. What is a list of things I should do to the bike before leaving? Besides doing the doo. I'm planning to do that already.
- Mel
Long Way Back
Not all those who wander are lost
2002 Kawasaki KLR650 - Big Red
KamikazeKLR is offline   Reply With Quote
Old 01-18-2013, 10:53 AM   #4821
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,842
Originally Posted by GAS GUY View Post
It can be mounted in any position.
It does have a floating piston in it separating the nitrogen from the oil.
Now, the shock will get completely filled with oil along with the hose and approximately 1/3rd of the reservoir.
The other 2/3 rds of the reservoir gets the nitrogen charge.
This will probably double my oil capacity and add compression adjustment.
Cool, man. Is this added on to the stocker or to an aftermarket shock? Seems like this concept could be used on the stocker at the schrader valve.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 01-18-2013, 12:42 PM   #4822
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,283
Added on to the stock shock.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is online now   Reply With Quote
Old 01-18-2013, 02:17 PM   #4823
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,842
Then I'm definitely interested in hearing more.
-DustyRags
Old 01-18-2013, 04:40 PM   #4824
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,283
Dirty Dog,
Of all the Klr riders, you could probably use it most, the stuff you subject your bike to.
I just got some fittings in the mail, so I will be working on it soon.I will post up details as I get it done.
First thing I have to do is remove the stock schrader valve where you charge it with nitrogen and drill it out for a 1/8 pipe tap, then tap the hole and install a long street elbow fitting.
2001 GAS GAS 321
IBA # 23,716
Old 01-18-2013, 04:49 PM   #4825
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,283
Dirty Dog-I don't know if you have seen my thread on the bike but I will post details there as I get it done.
Heres a link.
http://advrider.com/forums/showthread.php?t=828655
2001 GAS GAS 321
IBA # 23,716
Old 01-19-2013, 06:07 AM   #4826
Grinnin
Forever N00b
Oddometer: 2,630
We don't know if your bike gets regular rigorous maintenance or if it's overdue for everything. It may be OK with checking valve gap, change oil, and have chain and sprockets that are not totally shot. Have the swingarm and linkage bearings ever been serviced? Are the wheel bearings 11 years old? I usually deal with fork seals only when they leak, but if those are 11 years old you may want to just replace them before you go. I will assume that modifications for comfort have been taken care of.
There are entire threads on what may or may not need to be done to a bike from thermobob to larger or smaller sprockets. Some people need many of them and others need none.
Motorcycles are magical.
Grinnin is offline   Reply With Quote
Old 01-19-2013, 03:39 PM   #4827
WARRIORPRINCEJJ
Not in the clique...
WARRIORPRINCEJJ's Avatar
Oddometer: 9,746
For any of you GenII ('08+) KLR guys who might be interested...
http://www.advrider.com/forums/showthread.php?t=856807
I spent all my money on motorcycles, 4X4's, whiskey, and women...The rest I just wasted. (edited to fit/original phrase by "WIBO")
"There's a WEALTH of cool people and knowledge on ADV, there's also a decent sized pocket of douche bag assholes that think their ADV forum Post Count (Oddometer) is their badge at being experienced riders." goodcat8
WARRIORPRINCEJJ is offline   Reply With Quote
Old 01-20-2013, 03:01 PM   #4828
DesertDuster
Old Pueblo Rider
DesertDuster's Avatar
Oddometer: 191
front wheel
I bent the rim on my front wheel yesterday. I notice that the replacement cost is quite high. Does anyone have any recommendations on what to do?
DesertDuster is offline   Reply With Quote
Old 01-20-2013, 03:16 PM   #4829
marc11
Oddometer: 148
Contact Woody's Wheel Works. They are a supporter here. Great people but more important great work. They fixed an rim for me and I couldn't even tell it was never bent.
Sent from my Nexus 7 using Tapatalk HD
2007 BMW R1200RT
2002 Honda XR400r
marc11 is offline   Reply With Quote
Old 01-20-2013, 03:41 PM   #4830
Newner
Buffering
Newner's Avatar
Oddometer: 1,619
1. Is it causing the bike to shake or behave like it is out of balance?
Assuming "No" then the KLR solution is a big ass rubber mallet. Congratulations on your new character mark!
"Serious. Just like that scene from the matrix, except the chick was me and the ducati was a klr." -DirtyDog
Newner is offline   Reply With Quote
Times are GMT -7.   It's 10:04 AM.
