Old 01-10-2013, 09:04 PM   #91
aposaric
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 134
I just saw this thread :-) Amazing, how is your progres ?
Looking forward to seeing this beast finished
aposaric is offline   Reply With Quote
Old 01-10-2013, 11:45 PM   #92
Lappeman
He's Down Again!
Lappeman's Avatar
Oddometer: 1,314
Never seen anything like this...can't wait to see the finished product in action! Good luck with the build!
Lappeman My Photos http://s891.photobucket.com/profile/Lappeman
Youtube http://www.youtube.com/channel/UCB-w...7m3yBQA/videos
2010 KTM 530exc Orange Adventure
2003 KLR 650 Touring Adventure
2009 KTM 300xc-w For Sale
Lappeman is offline   Reply With Quote
Old 01-11-2013, 10:05 AM   #93
Quacamole OP
Quacamole's Avatar
Oddometer: 41
Thanks for the thumbs up everybody!
Been quite busy with other matters.
Will post some pics of tank fab on sunday, first time using
tig welder so it aint pretty!
Quacamole is offline   Reply With Quote
Old 01-13-2013, 10:38 AM   #94
Quacamole OP
Quacamole's Avatar
Oddometer: 41
Tank fab
As mentioned before, will weld two tanks together. First will fabricate the lower pan
and then just weld the existing GS tank on top. Will try to fit in ventilation and overflow
pipes also as it was in VFR original tank.
Need to work on these tig skills.
Got the VFR tank cap opening welded in
Excess sheetmetal will be cut off
Old 01-13-2013, 07:54 PM   #95
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 897
There ya go....nice tank fab. PLEASE let us know how many gallons/liters it holds when you are done.
I stated earlier that I bought a Rockster tank to use the base, like you did with the VFR tank, but I also have a 1986 R80G/S BIG Paris/Dakar style tank, like the ones that are sometimes signed by Gaston Rahier. I am thinking of cutting out the tunnel on that and over laying the shell onto the Rockster tank base....a Vintage P2D 8 or 9 gallonish tank on an R1100 custom....someone will probably shoot me for ruining a perfect condition P2D tank, but You can still find them, it is not like they are 1 in a million...yet.
Nice job so far Quack
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 01-14-2013, 07:55 AM   #96
nzrian
nzrian's Avatar
Oddometer: 97
awesome
i own a 4th gen vfr750 and the motor is sooooo smooth, sounds brilliant, and really broad spread of power from idle till about 9k rpm.
this bike will be the best dual sport ever.
good luck, cant wait to see it goin.
If you don't know where you are going, any road will get you there.
-Lewis Carroll.
nzrian is online now   Reply With Quote
Old 01-18-2013, 11:04 AM   #97
Quacamole OP
Quacamole's Avatar
Oddometer: 41
Tank progress
Managed to weld tank pieces together, still some plates to go.
Ventilation pipes were a pain in the ass so I decided to drop those,
will think something through the gas cap.
Not the winner of beauty contest but nothing putty and paint won't fit.
Hopefully the welds hold.
Old 01-18-2013, 01:21 PM   #98
kellymac530
motorcycle addict
Oddometer: 897
To test for leaks you can get a big tub like those ones people use for camping gear, and fill it mostly full with water, push the tank down into the water and hold it so the filler is just above the water line. Hold it there for a couple minutes, pull it out and shake it to see if there is any water inside. If you mark the water line you can check how much fuel it will hold by using the displacement method. After you remove the tank pour pre measured amounts of water back in until it rises back up to the line and that is how much it will hold...minus a bit for the metals volume.
That or just go to the tried and true, fill it with water and let it sit...watch for leaks. Measure the water that pours out.
The only issue with that method though is water inside the tank can be a pain to get out sometimes.
Looking fantastic though. Keep us posted with more pics of that nice work. Too bad you are on the other side of the world, I could probably use a bit of help here and there on my beast project.
kellymac530 screwed with this post 01-18-2013 at 01:23 PM Reason: add
Old 01-22-2013, 03:15 PM   #99
charlie264
charlie264's Avatar
Oddometer: 5,023
I need more.
Old 01-22-2013, 06:08 PM   #100
Barnstormer
Jellyfish Proctologist
Barnstormer's Avatar
Oddometer: 1,946
FWIW, it's pretty easy to measure how much it holds, weigh it full and empty.
Barnstormer is offline   Reply With Quote
Old 01-25-2013, 12:05 PM   #101
achile
achile's Avatar
Oddometer: 281
Send a message via Yahoo to achile
Like he said...use water . 1 l of water = 1 kg
achile is offline   Reply With Quote
Old 02-08-2013, 05:36 PM   #102
Lappeman
He's Down Again!
Lappeman's Avatar
Oddometer: 1,314
Updates???
Anymore recent updates to this awesome project?
Old 02-08-2013, 07:03 PM   #103
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 11,582
Send a message via Yahoo to Ricardo Kuhn
Yeah me too, I'm dying to see more and more..
I'm really Sorry but I'm "Out" of Rickybars, Actually I have a bunch of bars and a Ton of end pieces but Not that many clamps to offer them as a product anymore.
Ricardo Kuhn is offline   Reply With Quote
Old 02-08-2013, 07:09 PM   #104
nzrian
nzrian's Avatar
Oddometer: 97
me too
-Lewis Carroll.
Old 02-09-2013, 06:51 AM   #105
Frank from Quebec
Oddometer: 11
Congratulations on a superb build !!
One other way of checking tank leak is to put a little air pressure in it and to spay some bubly soap on the welds.
Frank
Frank from Quebec is offline   Reply With Quote
Times are GMT -7.   It's 08:28 PM.
