Thread Tools Rating: Thread Rating: 538 votes, 4.98 average. Display Modes
Old 01-18-2013, 07:46 AM   #2836
EvanADV
Big Bearded Boy
EvanADV's Avatar
Oddometer: 1,337
Originally Posted by dorkpunch View Post
Mostly done air engine sporting a whopping 2cc of displacement!
Still need to drill and thread the intake hole to install a hose barb, and finis welding the motor to the base. The crank will be cut down to match the flywheel, and when I get the proper belt for my lathe I will finish the flywheel up.
The goal was to have a working air engine made with nothing other than basic power tools- mainly the drill press and welder. My students will not be using the lathe on their flywheels unless they want to come in after school and figure it out...
Some of the specs: 2cc, crankshaft made out of bent up 1/8" welding rod, piston made from 3/8" rod, rest of it is just basic hot rolled bar or flat stock. Lucked out on the flywheel and found a large chunk of 2 1/2" brass round stock at a scrap yard- plan on making about 40 flywheels out of it. Figure the total cost is under $5. The welds on the base plate are done with stick, wire feed, and oxy-acet- they practice a bunch and then hopefully do their "good one" on the base for display...
I'll post pics of the students projects when they get 'em done.
Wish I would have went to your school!
Current Steed: '08 FJR1300
9 states left to ride: WI, MN, ND, SD, UT, OK, KS, AK, and HI.
EvanADV is offline   Reply With Quote
Old 01-18-2013, 08:11 AM   #2837
Westy99
Oddometer: 221
My uncle and I put this together late last summer...
Started life as two 20 gallon drums which we turned into a sweet little tailgating smoker.
2010 F800GS | 1973 Honda Z50 Mini Trail
Westy99 is offline   Reply With Quote
Old 01-18-2013, 09:31 AM   #2838
ColinDoyle
ColinDoyle's Avatar
Oddometer: 723
Originally Posted by jesusgatos View Post
Your customer? You didn't really build that piece of shit for a paying customer, did you?
1/4" isn't shit, and what you really need is more vertical separation between the top/bottom walls, and more than one hitch, and a fawking clue - obviously. You're putting other people's lives at risk ASSHOLE.
They're stupid for making them, and their customers are stupid for buying them.
You're a man of exquisite passion. Very admirable.
Originally Posted by Iwantabikesobad View Post
There is a chance of pulling your frame horns down and causing major frame damage.
Come on, buddy. Toyota truck frames are renowned for their unparalleled strength and resistance to corrosion.
Here's something else I made: hardwood stakesides! Also sandblasted the frame, reinforced the leaf spring attachment points, painted the frame, installed new decking, and replaced the bearings and tires.
Look out for the giant hand from the heavens!
Colin Doyle
2004 BMW R1150R Rockster | 2008 Honda Ruckus
ColinDoyle is offline   Reply With Quote
Old 01-18-2013, 09:59 AM   #2839
hwy61
hwy61's Avatar
Oddometer: 433
I liked the cantilevered bendy death thingy better...
"Don't speak unless you can improve on the silence." Chinese proverb
hwy61 is offline   Reply With Quote
Old 01-18-2013, 10:36 AM   #2840
snakebit
growing old disgracefully
snakebit's Avatar
Oddometer: 1,058
Hauling my NX250 on a commercial rack on the back of my E150 I found it was unstable side to side. There is a single bolt designed to screw down and take up the slop in the receiver but it wasn't really effective.
My solution was to use ratchet straps from the extreme ends of the carrier looped around the rear bumper.
That made the set up completely stable, it might help on the FJ.
The other thing I do is run a 1/4 inch SS cable through the bike frame and around the hitch cross bar so if anything went bad I would be dragging the problem with me, not watching it tumble down the road in my rear view mirrors.
If i were trying to use that FJ set up I would have a minimum of two safety cables. They are likely to be needed.
snakebit is offline   Reply With Quote
Old 01-18-2013, 12:15 PM   #2841
42
Bokononist
42's Avatar
Oddometer: 17,546
Crawling from the wreckage
42 is offline   Reply With Quote
Old 01-18-2013, 01:04 PM   #2842
marksbonneville
marksbonneville's Avatar
Oddometer: 967
What a great name "the cantilevered bendy death thingy"
marksbonneville is offline   Reply With Quote
Old 01-18-2013, 02:28 PM   #2843
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Originally Posted by mike54 View Post
You should make a video of that FJ taking a jump at about 40mph with the quad on the back. Just so every one can see how well it works.
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 01-18-2013, 02:35 PM   #2844
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Originally Posted by Juanjo_NY View Post
Mateo Maria & Julieta Maria
Old 01-18-2013, 03:07 PM   #2845
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 2,950
I think OP was screwing with us, had a plan for a trailer all along
he got us good and proper
a lesson in how not to carry a quad!
Moments before you die, your life will flash before your eyes - make sure the film is worth watching - my Grandad
Don't go gentle into the long final good night from which no man has yet returned.
Moose Antlers need love too.
Hay Ewe is online now   Reply With Quote
Old 01-18-2013, 07:13 PM   #2846
ColinDoyle
ColinDoyle's Avatar
Oddometer: 723
The world may never know.
Colin Doyle
Old 01-18-2013, 08:03 PM   #2847
Tallbastid
Let's get tropical
Oddometer: 1,412
Originally Posted by Monday View Post
That's exactly what I made it for...really cool, one of a kind desk piece.
You don't care to make a few more to sell, do you?
Tallbastid is offline   Reply With Quote
Old 01-20-2013, 01:01 PM   #2848
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,182
Computer Stand
Needs to be painted glossy black.
Start slow then easy off
OhBoy is offline   Reply With Quote
Old 01-20-2013, 01:38 PM   #2849
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,662
Here's another one I made........
http://www.youtube.com/watch?v=N3a-v3uvI9k
Murphy Slaw is offline   Reply With Quote
Old 01-21-2013, 08:46 AM   #2850
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,511
ThermoNixie
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 11:48 PM.
