Old 01-18-2013, 07:25 AM   #32551
KansasBob
KansasBob's Avatar
Oddometer: 515
Originally Posted by avgas View Post
I'm thinking of trying the t63 rear. Anyone have an opinion on 120 vs 130 width? I hear they run small.
I run the 120 and it looks good on the bike with no clearance problems. The 130 is taller too which I didn't want.
KansasBob screwed with this post 01-18-2013 at 07:32 AM
KansasBob is offline   Reply With Quote
Old 01-18-2013, 09:18 AM   #32552
zimzooma
zimzooma's Avatar
Oddometer: 175
I'm selling my 2009 WR250X/R.
http://www.advrider.com/forums/showpost.php?p=20517280
Don't check out my adventures.
zimzooma is offline   Reply With Quote
Old 01-18-2013, 09:42 AM   #32553
jon_l
jon_l's Avatar
Oddometer: 3,310
I have a new T-63 ready to mount, and it is a 120. My sense is that with the amount of power we have available, the larger tire isn't needed. This will be my 1st T-63 on a WRR though.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 01-18-2013, 12:06 PM   #32554
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by ggemelos View Post
I have been reading this thread and thinking of buying a WR250R as a light weight adventurer tourer for a while now. The hope is to build it up over the next year or so for a trip through South America. This thread has been very useful in helping me make the decision. I just picked up a new WR250R today. Now that I have the bike and plans to start working on it, I guess I need the service manual. Please PM me if you know where I can get a copy. Thanks again for all the great information.
Update:
I found a copy. Thanks for all the help.
Congrats on your new bike, I hope to be getting one soon - just have to find someone to buy my Tiger first :) I'm also preparing for a trip down South as well, and I hope you keep the thread updated with all you do to your bike.
UtahFox is offline   Reply With Quote
Old 01-18-2013, 12:21 PM   #32555
indypup
indypup's Avatar
Oddometer: 3,764
Originally Posted by henrymartin View Post
My first IDIOT moment with the WR.
I'm about to install my new turn signals and taillight from SoloRacer. Package comes, all nice, bagged, all the parts are there. I take the stock parts off and, being freezing outside, decide to work on it in my living room instead of the cold garage. I cut my wires the length of the stock wires, fix all the connectors, solder all the connections on top of crimping them, insert the metal pieces in the plastic, and voila. Then I go to install the brackets, only to find out that the nut won't go over the connectors. Damn, I feel dumb.
Work delayed, bike is going to be apart until the weekend
lol, don't feel bad...I made the same mistake when installing mine..
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 01-18-2013, 12:37 PM   #32556
KustomizingKid
Oddometer: 678
I cannot find a used WR anywhere near me and am getting very frustrated!
KustomizingKid is offline   Reply With Quote
Old 01-18-2013, 12:44 PM   #32557
30Bones
30Bones's Avatar
Oddometer: 4,650
I feel your pain. Alaska, New York...it's winter and I am not shipping this bike no matter where I buy it.
30Bones is offline   Reply With Quote
Old 01-18-2013, 02:13 PM   #32558
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
Problems with WRR front end Still
Well I finally got enough good weather to work on the WRR a few minutes STILL trying to correct the tire/wheel problem I mentioned back in post #32472. Here it is again if you don't want page back: I switched out my OEM deathwing 301 for a Kenda 270 . I am now getting a pogo/bounce action when I get in the 30-40mph range. It seems to be a little more pronounced while slowing down thru that range than speeding up thru it. I have had it computer spin balanced at the dealership, I also checked the balace when it was on the truing stand. I have trued the wheel, rechecked for even bead seat, tried different air pressures(Hard surface so far only). I have increased rebound which helped a small amount, but the problem still exists. Has anyone had this problem or can suggest an area to check. My next step was to re-torque the steering head, but I would rather not play with that mess unless I can be sure I will get some positive results as I have a submounted Scotts dampener that would have to come off also.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 screwed with this post 01-18-2013 at 04:35 PM
pfy50 is offline   Reply With Quote
Old 01-18-2013, 02:20 PM   #32559
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 387
Originally Posted by pfy50 View Post
Well I finally got enough good weather to work on the WRR a few minutes STILL trying to correct the tire/wheel problem I mentioned back in post #32472. Here it is again if you don't want page back: I switched out my OEM deathwing 301 for a Kenda 270 . I am now getting a pogo/bounce action when I get in the 30-40mph range. It seems to be a little more pronounced while slowing down thru that range than speeding up thru it. I have trued the wheel, rechecked for even bead seat, tried different air pressures(Hard surface so far only). I have increased rebound which helped a small amount, but the problem still exists. Has anyone had this problem or can suggest an area to check. My next step was to re-torque the steering head, but I would rather not play with that mess unless I can be sure I will get some positive results as I have a submounted Scotts dampener that would have to come off also.
Sounds to me like you need more pre-load on your rear shock. IE that your front floats and more rear pre-load places more down force on your front....
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is offline   Reply With Quote
Old 01-18-2013, 02:40 PM   #32560
TwilightZone
Oddometer: 3,123
>"I switched out my OEM deathwing 301 for a Kenda 270 . I am now getting a pogo/bounce action when I get in the 30-40mph range."
If changing the tire is all you did to introduce the bounce, I'd replace the Kenda 270. Some tires have a heavy spot, mislaid belts, or whatever, so it may be a bad tire.
I like these IRC GP1 for a dualsport tire.
http://motorcycle.chaparral-racing.com/search?w=IRC%20GP1
I run the 'lightweight' rim locks, Wheels are stable... well as fast as I want to push the WR250 anyway.
http://www.rockymountainatvmc.com/p/43/-/171/726/-/26096/Motion-Pro-LiteLoc-Rim-Lock-/rim+locks
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 01-18-2013, 03:45 PM   #32561
amtz.zero
amtz.zero's Avatar
Oddometer: 72
Does anyone here know if a fender from a yz or from a wrF will fit our bikes? Thanks.
amtz.zero is offline   Reply With Quote
Old 01-18-2013, 03:48 PM   #32562
N8
Oddometer: 72
They're so different I'm sure they won't. I have a YZ250.
07 300 XC-W
N8 is offline   Reply With Quote
Old 01-18-2013, 03:49 PM   #32563
bigdon
Oddometer: 2,643
IMO Kinda 270's SUCK !
Life is to short to run suckey tires
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 01-18-2013, 07:32 PM   #32564
iWander
Adventure Geek
iWander's Avatar
Oddometer: 61
I put GP1 tires on both of my DR650s and a KLR250. Fantastic tire for both road and trail. I'll be trying them on the R2 as soon as I wear out the Kendas.
Something else I've found that works well are Dyna Beads. Over the years I've used lead, Slime, Ride-On, and now Dyna Beads. I was pretty skeptical about the beads, but I spent a weekend running tests with the same tire/rim combo and there was no more room for doubt. Way out of wack with no compensation, decent with lead, smooth as glass with both Ride-On and Dyna Beads.
iWander is offline   Reply With Quote
Old 01-18-2013, 08:00 PM   #32565
BlockPass
BlockPass's Avatar
Oddometer: 125
Has anyone replaced the radiator shroud, on the right side? Wondering if you need to order the two pieces and the plastic rivets? I am struggling to see the rivets in the parts fiche.
Sent from my iPad using Tapatalk HD
BlockPass is offline   Reply With Quote
Times are GMT -7.   It's 10:51 PM.
