Old 01-15-2013, 01:51 PM   #121
England-Kev OP
Oddometer: 3,690
Originally Posted by Rob Farmer View Post
That wasn't Joes work that was the handy work of the bikes previous owner. It was the most dangerous bike I've ever ridden. Chipped 1100 fuel injected engine with the standard eldo rear bevel drive. The front brake was a single leading shoe Accelerated like shit off a stick.
Which goes to prove... Just because you can, don't mean you should!
England-Kev is online now   Reply With Quote
Old 01-16-2013, 09:45 AM   #122
England-Kev OP
Oddometer: 3,690
Piston + Barrel upgrade...
You guys who have done the upgrade to new Gilardoni Barrel sets, I wonder, did you feel the need to change the big end bearings at the same time? Also, is there any way of telling if your bike has already had the cylinders changed to Gilardoni?
Old 01-16-2013, 10:05 AM   #123
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,990
England-Kev, I had a few photos provided by another inmate but I can't seem to find them right now, sorry. If you have Gilardoni jugs on your bike you should see the name in the casting at the bottom of the jug where it meets the case. Or you could use the old magnet trick by removing the spark plug and running the piston down out of the way...
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is online now   Reply With Quote
Old 01-16-2013, 10:18 AM   #124
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 364
If you still have the motor in the frame, you can check the rods for play and make a decision. If the bike has high miles, it might be worthwhile to pull it down and clean the sludge trap in the crank pin, but that takes more disassembly.
You can change the rod shells in situ. Kinda hard to check the pin for roundness tho.
Life's too short.
F_Sahms is offline   Reply With Quote
Old 01-16-2013, 10:19 AM   #125
danedg
Horizontally Opposed
Oddometer: 6,736
Crank bearings
I changed the front and rear carriers because they needed to be changed. The front cam retainer as well.
At 46,000 miles, the front and rear bearings measured JUST within specification. It didn't seem wise to reuse them if I plan on riding the thing 10,000 miles / year....which is exactly what I intend to do!
All the bearings were still usable (sizewise), but they were dirty. You can see what the lack of an oil filter will do to the bearing surfaces. On the other hand, the cam and crank were in fine shape.
So the bearings did their job. Nothing failed and I probably could have thrown a battery in it and ridden it for another 20,000 But they were due for retirement.
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic
danedg is offline   Reply With Quote
Old 01-16-2013, 10:50 AM   #126
nick949eldo
Oddometer: 1,048
Here you go Kev. If they are Gilardoni they are stamped right at the base of the cylinder between the lower two fins. The easiest way to check if you have iron bores is the put a stick magnet down the plug hole. If it sticks like crazy: iron sleeves. Barely at all: nikisil. Not at all: chrome.
Nick
Beyond the Coffee Shop: Riding 1970's Moto Guzzis in Northern Canada (Kindle Book) Buy it - it's cheap and good! All my adventures and disasters in one place.
nick949eldo is offline   Reply With Quote
Old 01-16-2013, 03:12 PM   #127
danedg
Oddometer: 6,736
Old 01-18-2013, 06:48 AM   #128
England-Kev OP
Oddometer: 3,690
Thanks, I am sure I would have noticed that if I had them.... not much going on here right now, we have 3" of snow, which is enough to bring the UK to a grinding halt, it surprises me that we ever conquered half the world, we have trouble these days getting to the end of the road!
On top of that, my Dad passed away on monday, so my mind has been diverted away from motorcycles a little..
Roll on spring....
Old 01-18-2013, 07:37 AM   #129
woodly1069
woodly1069's Avatar
Oddometer: 1,990
Damn Kev, sorry to hear the bad news about your dad...
Old 01-18-2013, 04:45 PM   #130
danedg
Oddometer: 6,736
Peace brother...
It's a hard step...
Old 01-19-2013, 01:10 AM   #131
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,820
History shows we mainly conquered the countries without any snow
Rob Farmer is offline   Reply With Quote
Old 01-19-2013, 01:28 AM   #132
England-Kev OP
Oddometer: 3,690
I suppose Canada was just an accident then Rob, they must have gone in the summer my year really starts next weekend, Kempton on saturday, and the Talmag pre 65 trial on Sunday
Old 01-19-2013, 03:17 AM   #133
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,820
I avoided mentioning Canada...You know how sensitive the colonials are
Glad you're getting out and about. see you soon hopefully.
Old 01-19-2013, 04:07 AM   #134
England-Kev OP
Oddometer: 3,690
I just came across a picture I took at Horseshoe pass....
Old 01-22-2013, 12:53 PM   #135
woodly1069
woodly1069's Avatar
Oddometer: 1,990
Dang! Sure do love an Eldorado in black!
Times are GMT -7.   It's 09:50 AM.
