Old 01-19-2013, 04:18 AM   #73141
greer
Oddometer: 3,494
Shipping may cost a war pension, but Amazon and Phat Performance show them in stock.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 01-19-2013, 04:20 AM   #73142
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,497
Re: grips...
I may have to replace mine eventually when I change bars, but I'm certainly not going for foam grips (that nobody has) when this 'solution' has worked for me on two bikes and many miles so far:
Tightly wound in a spiral, these cushion and leave no noticeable pressure points that had my hands tingling after many miles with traditional grips.
And, they're wider than most grips - I don't even have big hands, but I find this far more comfortable.
Yeah, yeah, I wish I had some other color rope to change it... sorta... but it's what I had on hand from the limited choices Home Depot had that day. (Of course within days they had most colors available again.)
If even only as a stop-gap until you can find foam grips, I think if its comfort you're looking for, you might try this out.
"After reading through this thread I've come to the conclusion that more people cruise the internet looking for reasons why X bike won't work in Y scenario rather than actually riding their motorcycles." -- RyanR
Mambo Dave is online now   Reply With Quote
Old 01-19-2013, 07:01 AM   #73143
jessepitt
Dual Sport Addict
jessepitt's Avatar
Oddometer: 988
Originally Posted by ER70S-2 View Post
There was a question about removing the idle fuel screw plug over on DRRIDERS.com. I posted a link to Jessepitt's photo essay on the procedure: http://www.advrider.com/forums/showp...5&postcount=71
I got this response, thanks Jesse.
Jessepitt should do a manual for us rookies. These photos are fantastic!!!!
This is the definitive answer to "THE CAP OVER THE STOCK NEEDLE ADJUSTMENT SCREW."
Even I can do this now!!!
If you don't understand this. You might seriously consider taking the bike to a shop or have someone show you.
jessepitt is offline   Reply With Quote
Old 01-19-2013, 07:05 AM   #73144
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,458
Fellas,
Can the carb inlet tube on the stock BST be rotated ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot is online now   Reply With Quote
Old 01-19-2013, 07:15 AM   #73145
neo1piv014
ADV in training
Oddometer: 610
Originally Posted by procycle View Post
I've probably read your suspension rebuild articles a hundred times each, since those are the upgrades I'm likely to do in the near future. Very, very well written.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-19-2013, 07:17 AM   #73146
jessepitt
Dual Sport Addict
jessepitt's Avatar
Oddometer: 988
Originally Posted by motolab View Post
A couple of points to mention:
1) It is likely that the drill will pull itself into the fuel screw when it breaks through the far side of the plug. The result can be just a little nick, mostly ruining the head, or somewhere inbetween. The way to avoid this is to use a drill stop, which, when properly set, will prevent the drill from going any further when it breaks through.
2) I've seen quite a few cracked/broken fuel screw wells. These are the result of the plug cocking as it is being pulled out. The way to avoid this is to tap the hole (I use a M4X.7 tap, which takes a 3.3mm or #30 drill). Grind the point off of the tap (if it has one) for clearance with the head of the fuel screw. Tap only deep enough to get through the plug. Then use a metal tube with squared ends and an ID just larger than the OD of the plug in conjunction with a screw and a washer with the same or larger OD than the tube as a puller to extract the plug. This way it is guaranteed to come out squarely.
3) Shimming the needle clip richens the mixture by lowering the slide rather than by raising the needle (except when the slide is against either stop), as the shim increases the preload on the slide spring.
Regards,
Derek
If you look at the write up you will see that I use a drill bit with an old, dull counter-sink collar on it for grip and drill it by hand. There is really no way to loose control and damage the screw. I dont even drill all the way through the plug. The plug has a tiny hole already drilled in it which acts as a pilot for the drill bit but also allows a small fine thread screw to be turned a couple threads in if you leave a little bit of the cap when you drill.
Prehaps I should remove a small amount of the spring in order to counter the increased preload?
Old 01-19-2013, 07:26 AM   #73147
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,576
Originally Posted by DockingPilot View Post
Fellas,
Carefully, yes. You want to be sure and have a good bite on the tube or it can bend. When I had a stock carb I believe I used a large adjustable wrench on the tube and once it "cracked", I was able to rotate it without harm.
Steve
07 KLX250S w/300 kit, 05 DR650SE, 04 XT225
99 VFR800 w/870 kit, 96 GPz1100
Lil' Steve is offline   Reply With Quote
Old 01-19-2013, 07:48 AM   #73148
Porky
Don't Pass Gas
Porky's Avatar
Oddometer: 458
Originally Posted by Mambo Dave View Post
Re: grips...
GREAT IDEA
Have been thinking about thicker grips but want to retain my Cramp Buster. Your idea will enable me to keep my Buster.
'08 Suzuki DR650
'11 Triumph venom yellow ABS Tiger 800 - SOLD (Too much heat and exhaust popping)
No fat chicks, fender will scrape.
Porky is offline   Reply With Quote
Old 01-19-2013, 08:00 AM   #73149
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 6,266
Originally Posted by LucasLeader View Post
My bike does the same thing. Doesn't burn up a noticeable amount of oil and stops smoking after a minute. It's been doing it a lot less lately too. I think the only problem I have with it is being a little embarrassed when I'm warming up my bike and spitting smoke at people walking by me.
Same here. My '96 has 20K miles on it. Only after a long period of not starting.
1996 DR 650 (a big girl that likes it dirty)
1973 Penton Six-Days (mint)
1971 Suzuki TS185 (needs restoration)
2005 KTM 400exc w/ BajaDesigns D/S light kit
Rusty Rocket is offline   Reply With Quote
Old 01-19-2013, 08:08 AM   #73150
Rusty Rocket
Life behind "Bars"
Oddometer: 6,266
Wow! Just the right colors. U should be selling that rope and idea on the KLR forum, you'll be able to retire in no time
Re: grips...
Old 01-19-2013, 08:56 AM   #73151
acap650
acap650
acap650's Avatar
Oddometer: 354
There are 2 reasons why you don't see grips on the DR page. First, I like to keep the number of 'general' items that folks can usually get at any shop to a minimum - especially on the pages that are so filled out like the DR page. Second, for most folks replacing grips on the DR for the first time can become a nightmare of a job.
Some day we'll have some separate pages for our favorite general items.
After reading about the throttle grip being bonded to the tube it just made sense to order a new tube with the grips-my time is worth more than the few dollars a new tube costs, and the next grip change will be easy.
acap650 is offline   Reply With Quote
Old 01-19-2013, 08:57 AM   #73152
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 3,765
Fellas,
Yup. I padded the tube with a shop rag, then applied gently-increasing torque with a wrench until it moved.
Kommando is online now   Reply With Quote
Old 01-19-2013, 09:00 AM   #73153
DockingPilot
Oddometer: 7,458
Thanks fellas
Frank Reinbold
*2010 FOREVER WEST*
TRANS AM TRAIL WEST
Old 01-19-2013, 09:13 AM   #73154
victor441
victor441's Avatar
Oddometer: 462
grips...
Gran Turismo grips are a good option, have been around at least 40 years...they are tapered and soft in the middle, very comfortable for long rides and not too slippery...vintage British bike parts suppliers often carry them
victor441 screwed with this post 01-19-2013 at 09:42 AM
victor441 is offline   Reply With Quote
Old 01-19-2013, 09:27 AM   #73155
Mambo Dave
Mambo Dave's Avatar
Oddometer: 2,497
Originally Posted by Porky View Post
GREAT IDEA
Inerestingly enough, because I lay down a grip's-length of rope across the grip before wreapping it, with the right placing the throttle's "bulge" from that underlying end of rope it acts as sort of a cramp-buster. That, or for both hands at least an ergonomically better bulge up into the palm than a standard purely-round grip.
The neat thing, of course, is experimenting and catering the rope to your needs.
I don't ever want to go back to tiny Japanese grips again.
Times are GMT -7.   It's 09:00 PM.
