01-15-2013, 08:24 AM
#61 | |
Won't it be cheaper to order the complete gasket set rather than individual gaskets? When I rebuilt my Dakar I ordered the complete set.
01-15-2013, 12:08 PM
#62 |
Oddometer: 22
I did the math and the kit was more $ than the individual gaskets/seals i needed. I'm reusing the cam cover gasket. If not the kit may have been the better deal.
01-15-2013, 12:25 PM
#63 |
Oddometer: 22
![]() More parts have arrived! New counterbalance shaft bearings are sealed vs old ones that were open. Every other internal engine bearing is open. Hmmm? What's better? Sealed are dependent on the grease that was put inside for its lifespan. Any wear particles are stuck inside too. Open bearings get constantly flushed and lubed with engine oil. Maybe better cooled by the oil too? Let the debate begin! |
01-15-2013, 12:56 PM
#64 |
Oddometer: 416
My vote is for using what BMW currently makes (in this case sealed). Why? I have a feeling the boys at BMW engineering in Munich and the corporate structure of ISO 9002 (or whatever they use probably more sophisticated) for QA production naturally create a better part (in general).
F650 GS 2001 F650 GS DAKAR 2002 at least one should be running |
01-16-2013, 09:56 PM
#65 | ||
01-16-2013, 09:59 PM
#66 | ||
01-17-2013, 09:48 AM
#67 |
Oddometer: 22
01-17-2013, 09:51 AM
#68 |
Oddometer: 22
what year is your dakar? what workshop manual were you using?
01-18-2013, 03:53 AM
#69 | |
I have a 2004 twinspark. Drop me a PM and I will send you the link
Spyker screwed with this post 01-20-2013 at 08:13 PM |
01-19-2013, 04:44 AM
#70 |
Oddometer: 22
interesting NSK technical article on sealed trans bearings-
http://jeep.yager.net/docs/trans-toy...nsmissions.pdf |
01-19-2013, 05:52 AM
#71 |
Oddometer: 416
That's a confirmation for sure. Sealed is better. Whaddya gonna do? Keep em as is, or you going rogue?
F650 GS 2001 F650 GS DAKAR 2002 at least one should be running divimon2000 screwed with this post 01-19-2013 at 06:17 AM |
01-19-2013, 07:38 AM
#72 |
Oddometer: 22
dont rush me divimon! i still have time to flip-flop. could end up a coin toss. i would agree that sealed would be better if the engine/trans oil was very dirty or metal contaminated, but if the oil is kept clean and the engine/trans is "healthy" then more oil exposure seems better.
01-19-2013, 09:33 AM
#73 |
Oddometer: 7,979
Do your self a favor and pop one of the seals off and see how much grease is in the bearing.
![]() You might decide that there is not enough lubricant for the long haul after all. If it were me I'd pull the seals and let the motor oil do it's thing but that's just me.
Steve in SF BMW's 58 R26 79 R100s 91 R100gs 87 Harley FXRS-SP ~ 06 KTM 625 SMC ~ 72 Honda CB750/915cc ~ 92 XR600/654cc ~ 95 XR650l/675cc ~ 03 CRF450r ~ 05 CRF450x ~ 02 XR650l/675cc ~ 86 YZ490 ~ 93 YZ80 ~ 93 XR650l Project |
01-19-2013, 10:00 AM
#74 | |
Oddometer: 3,809
So I guess the point I'm making is that not all factory ideas are that good. (Not to mention, the original KTM bearings were the lowest quality/cheapest bearings sold in Europe (again according the bearing pros), which is mostly likely why they failed in the first place.
"Deeply flawed people make deeply flawed decisions." |
01-19-2013, 03:06 PM
#75 | |
Oddometer: 22
my new bmw bearings are designed for transmissions. they are greased only for initial lubrication, then the seal allows engine/trans oil to "leak in" to do the lubrication after the grease is washed out. they are designed this way. |
