Old 01-18-2013, 08:47 PM   #32566
scottmac
scottmac's Avatar
Oddometer: 1,760
Force Radiator Guards
http://www.forceaccessories.com.au/s...d&productId=58
scottmac is offline   Reply With Quote
Old 01-18-2013, 09:08 PM   #32567
BlockPass
BlockPass's Avatar
Oddometer: 125
Not looking for brace or guard, the plastic shroud itself got damaged and I need to replace it.
Sent from my iPad using Tapatalk HD
BlockPass is offline   Reply With Quote
Old 01-18-2013, 09:18 PM   #32568
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
Tire Problems
TNX for the recommendation on tires guys. I have one more check to do tomorrow to see if it is "out of round", if it is I will probably leave it on for now and just do some winter trail riding. I have a fairly new 606 on the rear. Possibly the high spot will get worn in a little while I do load testing in anticipation of my summer trip. I only payed $46.00 for the Kenda 270 so it isn't worth taking it off and returning it to Rocky Mountain MC. I already have a TKC 80 or Shinko 700 to replace it with in the spring before I leave for my trip to AK./Yukon and I have a set of Warp 9 wheels I'll use for that trip.
ps. Isn't a IRC GP1 a copy of the Kenda 270?
kenda 270
IRC GP1
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 screwed with this post 01-18-2013 at 09:31 PM
pfy50 is offline   Reply With Quote
Old 01-18-2013, 09:41 PM   #32569
theMISSIONARY
hunting and riding!!
theMISSIONARY's Avatar
Oddometer: 2,217
Originally Posted by idc22 View Post
Has anyone replaced the radiator shroud, on the right side? Wondering if you need to order the two pieces and the plastic rivets? I am struggling to see the rivets in the parts fiche.
i would say its sold as one Part two sides with rivets.
I put a Flatlands racing guard on mine,it touches the big IMS tank lightly so i had to put some rubber between the two
Happiness is a warm barrel....i don't care if its the bikes barrel or the rifles barrel!
WR250r of Awesomeness.......now with extra added Awesomeness!
theMISSIONARY is online now   Reply With Quote
Old 01-18-2013, 09:43 PM   #32570
matt33
Oddometer: 121
Originally Posted by iWander View Post
I put GP1 tires on both of my DR650s and a KLR250. Fantastic tire for both road and trail. I'll be trying them on the R2 as soon as I wear out the Kendas.
Something else I've found that works well are Dyna Beads. Over the years I've used lead, Slime, Ride-On, and now Dyna Beads. I was pretty skeptical about the beads, but I spent a weekend running tests with the same tire/rim combo and there was no more room for doubt. Way out of wack with no compensation, decent with lead, smooth as glass with both Ride-On and Dyna Beads.
I recently had Pirelli Scorpion Pro Enduro f/r on my new WRR. The Pirelli's are pretty much as aggressive as you can get and still be DOT approved. Instead of traditional balancing, I had approx 3 oz of beads installed along with "Lite-lock" rimlocks. I've only had her up to 70 MPH, but the new tires at 15 PSI feel pretty much as smooth as the OEM Trailwings.
matt33 is offline   Reply With Quote
Old 01-19-2013, 03:11 AM   #32571
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 172
If anything, the Kenda K270 is a copy of the IRC GP1.
A cheap copy.
I was using IRC GP1s on my 1990 Yamaha DT-200R back in the day, and they were/are awesome tires for smooth running on the street with casual off-road use, and that's the reason I mounded the IRCs for a trip up to Mt. Washington from CT. back then.
The wheels were balanced after the tires were mounted (with an old-fashioned static balancer), and the bike was as smooth as glass for the trip up and back.
Myself, I'd recheck the balancing job with another wheel balancer.
You may be surprised.
YZEtc is online now   Reply With Quote
Old 01-19-2013, 05:39 AM   #32572
eemsreno
Oddometer: 981
First post on this thread, but I have been reading on it a lot.
You guys are busy on here.
Just picked this up.
eemsreno is offline   Reply With Quote
Old 01-19-2013, 05:49 AM   #32573
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,855
A cheap copy.
Actually the Kenda is a "copy" of the old Yokohama, which was run as OEM on a bunch of 70s Honda dual sports. I was running the Yokohamas on my trials bike around 1983. I'm thinking Kenda may have bought the Yokohama tooling when they quit doing bike tires. Shinko got some of the tooling too.
Personally I've had great success with the Duro HF903/904, but I don't know if they're available in the correct rear size.
I have always wondered about the GP110 myself. But the Duros have done so well both on and off road, that with the price they are, I just won't change. Oh, I run them on a 650, was just nosing around in this thread.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 01-19-2013, 05:56 AM   #32574
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
A cheap copy.
Yes,YZEtc you may be correct about the order. The Kenda 270's seem to run $5-7 cheaper than the IRC GP1's and I was just looking for an inexpensive trail and hard surface general tire. What type of mileage did you get out of your GP1s, and what pressure did you run it at off- Hard surface?
Old 01-19-2013, 05:59 AM   #32575
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
Hello Mark,
Thanks for the clarification, I believe I have seen your avatar on some RR's and 650 forums
ps the Motorcycle-superstore still sells them: http://www.motorcycle-superstore.com...ront-Tire.aspx
Old 01-19-2013, 06:26 AM   #32576
shep546
shep546's Avatar
Oddometer: 215
Welcome... bike looks great... any farkles you plan on getting?
shep546 is offline   Reply With Quote
Old 01-19-2013, 07:21 AM   #32577
YZEtc
Feel lucky?
YZEtc's Avatar
Oddometer: 172
I can't remember how long they lasted, but I don't recall any memories of thinking they wore out too fast.
I did buy them for street-biased use, and they were excellent for that.
I do remember the GP1s having thin construction compared to an off-road knobby or even the stock Bridgestone tires from a WR-250R, so they're probably not the best to prevent pinch flats in rocky terrain.
For dual-purpose off-road use, I typically compromise at 18 psi.
Old 01-19-2013, 07:25 AM   #32578
30Bones
30Bones's Avatar
Oddometer: 4,643
I have used 270's on a KLR and a KTM 640 with good results and life. My husky ate rear tires and an MT21 would last 1500 miles. so I never tried a 270 on that bike.
On a light bike like the WR I see no reason not to run a 270 if you do street and mild dirt. They are soft and were squirmy on my heavy KLR but somehow wore really well. I think low HP helps a lot, and on a significantly lighter WR I think they would wear very well.
30Bones is offline   Reply With Quote
Old 01-19-2013, 07:30 AM   #32579
eemsreno
Oddometer: 981
At least a skid plate.
Old 01-19-2013, 07:34 AM   #32580
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,739
Artic Ocean to Baja
Yeah.. those WR250Rs can't be any kinda real adventure bike right!... haha!! WRONG! BigDog and Dingweeds continue riding our WR250Rs on more epic adventures.. they head to Baja today. They've ridden from the Artic Ocean to Baja on WR250Rs, that pretty much says it all to the 250 nah-sayers
ANYWHERE!
Like our disclaimer says......
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Times are GMT -7.   It's 03:47 AM.
