01-17-2013, 03:44 PM
#1 |
Oddometer: 914
Q about speedo pickup
I wore my speedo pickup wires threw last summer. Rode without a speedo for some time. I recently resoldered the wires and added a bit more preventative heat shrink and tied them back so hopefully this does not happen again. well I took a rip and speedo just reads 0 I trust my splice so started poking around and I cant find a magnet in the brake rotor. I took a look at a parts schematic and no magnet there either.
Anyone know what signals the sensor that the wheel has made a rotation?
When Quality matters,Its all about choices. Performance LED Vendors thread http://advrider.com/forums/showthread.php?t=839163 www.cyclopsadventuresports.com http://youtu.be/1fmEJO3ftFI |
01-17-2013, 03:53 PM
#2 |
AWD please!!
Oddometer: 3,866
the rotor bolt heads
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
01-17-2013, 03:58 PM
#3 | |
Rough Rider
Oddometer: 838
Same as the 990S and other non ABS LC8's Check clearance between the sensor and rotor bolts. Max
Da oggi la strada é senza limiti |
01-17-2013, 04:57 PM
#4 |
Where fun goes to die....
Oddometer: 3,162
When I got rid of the ABS I had to replace my pickup with the one used on the 950.
I don't know but maybe it is possible your splice might have added too much resistance to the wire for the pickup to work. Also check the clearance of the pickup to bolt heads like other said. I think there is some wiggle room when installing it that will change that gap.
DSM8 - A different kind of mean SQL > SELECT finger FROM hand WHERE id=3 WWW.DSM8.whereamiriding.com |
01-18-2013, 09:05 AM
#5 |
Oddometer: 914
Thanks guys
.That helps a lot. I need that speedo, you know how thirsty these things are.
01-18-2013, 04:07 PM
#6 |
KOTW 2010 Finisher
Oddometer: 3,010
When mine failed like this (a common problem) I soldered it back together like you did only to find that the overall wire was old and fragile and broke again right away. Ended up having to replace it.
Edit- new cable costs $66.
Brents347 Truckee, CA. 07 Yamaha R6 07 KTM 950 Super Enduro 04 KTM 250exc- plated two-stroke |
01-19-2013, 09:35 AM
#7 |
Oddometer: 914
Thats where Im leaning. Those wires take a lot of abuse
