Old 01-18-2013, 08:43 PM   #1
pdxmotorhead OP
pdxmotorhead's Avatar
Oddometer: 823
EFI Fuel pump?
Wonder if this pump would be a decent replacement?
http://www.summitracing.com/parts/sum-g3138/overview/
or this one...
http://www.summitracing.com/parts/ae...0/media/images
I have a 950, but the various fueling issues are interesting...
Does the 990 efi have a return line? or does it just pressurize the injectors?
Just wondering..
Dave
pdxmotorhead is offline   Reply With Quote
Old 01-18-2013, 10:13 PM   #2
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
the 990 does not have a return line, it "dead heads" to the injector rail. The FPR (fuel pressure regulator) is just after the pump and after the 7-10 micron rated filter, it just dumps the excess fuel back into the tank..
the 950 uses a completely different system and substantially lower fuel pressure... the 990 runs at ~51PSI the 950 is 1.5-2PSI
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 01-19-2013, 12:48 AM   #3
pdxmotorhead OP
Oddometer: 823
HMM. I do a lot of tuning on EFI race engines,, cars, some bike powered dirt cars, I found that pumps are way happier moving fuel than dead heading to the injectors.. I bet you could reduce the EFI fuel issues with a very small bleeder line
from the fuel rail back to the tank.. Enough so the fuel in the lines does not heat soak and so the pump gets cooling..
It could have a .020 orifice in it just so the fuel moves...
Be interesting to have a temp probe in that line right after the pump...
Just mulling ove rthe important world problems, fuel pumps, beer selection, the ususal...
Dave
Old 01-19-2013, 02:29 AM   #4
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,733
At the kind of MPG we get out of the 990 I think there is quite a flow through that pump ;)
Peanuts is offline   Reply With Quote
Old 01-19-2013, 03:55 AM   #5
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,149
the stock pump does plenty of bleeding back to the tank via the also in tank pressure regulator. its just the connection to the fuel rail thats a bit longer then with systems that have a regulator near or at the fuel rail.
Heat can build up in the line but i doubt that is near being an issue.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 01-19-2013, 10:58 AM   #6
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
Fuel heat could be a issue, and i agree that flowing fuel through the rail would definitely reduce the fuel temps at the injectors, the question would be what would the outcome be? Granted cool/cold fuel can equal greater density and potential power, perhaps the greatest improvement would be related to not boiling the fuel in the rail. At 51 psi that temp is pretty high.
The challenge with the throttle bodies and the fuel rails is there is very little space to do much of anything like adding a flow through port at the end of the rail..... personally i'd prefer the FPR at the end of the rail with a return line, but as presently designed/built its very crowded in that area already... it would require a new fuel rail design, and to retrofit to an existing throttle body would be difficult.
Sent from ADVmachines.com via Tapatalk
Times are GMT -7.   It's 07:12 AM.
