01-16-2013, 03:11 PM
#256 | |
Unwounding
Oddometer: 4,323
350lbs. isn't a massive leap to hold a twin 500cc to. I don't think they care about how well their bikes hold up 3,000 miles and 30 years down the road!
01-16-2013, 03:33 PM
#257 |
Oddometer: 687
New Duke 390 has extensive use of alloy, including light wheels & brakes (unsprung weight), and as a thumper weighs 324 lbs. wet. The new Ninja 300R twin doesn't have these advantages and weighs 378 lbs. wet. It would take a pretty high-tech (I want one!) 500 Twin to hold the weight down to 350 lbs. wet.
Another reference point: The 2012 (higher-tech) Duke 690 thumper weighs 352 lbs. wet. I think 385 lbs. would be a better target for a twin, which is still 40 lbs. lighter than my NT650 Hawk GT (425 lbs. wet). Going back to another thread, the Japan-only 400cc super-sports barely make the 385 lb. target.
1990 Honda NT-650 Hawk-GT Never doubt that a small group of thoughtful, committed citizens can change the world; indeed, it's the only thing that ever has. - Margaret Mead
Gryphon12 screwed with this post 01-16-2013 at 03:39 PM |
01-16-2013, 03:38 PM
#258 | |
Unwounding
Oddometer: 4,323
Well, wet weight is +20 lbs most often! ![]() Lets call it 378 like the Ninja 300 and it shouldn't be a Herculean undertaking. I think the Kawi guys use lead in their parts in the cheapo bins! |
01-16-2013, 04:37 PM
#259 | |
I'd rather be riding
Oddometer: 2,565
01-16-2013, 04:40 PM
#260 |
Oddometer: 2,565
It sounds like it is whizzing dog. It will benefit from an aftermarket exhaust.
01-16-2013, 06:39 PM
#261 | |
b00b
Oddometer: 357
01-16-2013, 07:18 PM
#262 |
Oddometer: 687
Well, to start: The frame is designed to handle higher-speed road stresses, not dirt. I don't know all of the details, but street frames are quite a bit heavier than enduro frames (and have real rear subframes and pegs for a passenger - even if you never carry one). Then, street wheels are wider, heavier alloy; the rotors and calipers are heavier, too, to resist fade at highway speed. Gas tanks are metal, electrical systems, batteries, and lighting systems are larger, more sophisticated and add weight.
Lot's of this stuff is mandated by DOT regulations. Overall weights are up quite a bit. KTM 350-EXC-F weighs 255 lbs. wet; Duke 390 weighs 324 lbs. wet. Difference is ~70 lbs. Many of these same issues apply to the weight differences between an enduro and a dual-sport. For example, lots of folks complain about the weight of the WR250R at 298 lbs. wet, or the WR250X at 302 lbs. wet. (The DRZ falls into this category, with low-tech (e.g. heavier) components.) These dual sports meet all of the DOT regs for street bikes. KTM street-legal enduros meet the minimum regs too, but without the electrical systems and the subframe support. Call them race bikes or call them "dual sport light". It is all a continuum. Pick your desired performance envelope and pony up!
01-19-2013, 11:20 AM
#263 | |
I Am the Mayor
Oddometer: 15,611
The Versys I owned spun-up pretty fast, which went a long way to compensating for a relative lack of bhp.
IBA #40578 shine on, you crazy emo diamond |
01-19-2013, 08:41 PM
#264 | |
Oddometer: 9
The Honda CB500 is cheap and reliable. |
01-19-2013, 09:20 PM
#265 |
Oddometer: 2,565
I agree, if it revs freely, that will take care of it.
01-20-2013, 02:35 AM
#266 | |
BAZINGA!
Oddometer: 3,867
since it's the same engine setup. The problem is most aftermarket exhaust actually make it sound worse in my opinion, thin and "screamy". I only liked the Akrapovic and Arrow on the 650R, and only up to about half the revs, then, again, it goes bad. If you don't like the way this thing sounds look at the NC700, they've got a completely different note and sound very deep stock.
'12 Kymco Downtown 300i ABS, '08 Yamaha FZ6n S2 ABS SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125 My Flickr gallery |
01-20-2013, 08:18 AM
#267 | ||
Oddometer: 14
http://www.youtube.com/watch?v=uZR2kXLELFc&hd=1"]https://www.youtube.com/watch?v=uZR2kXLELFc&hd=1"]http://www.youtube.com/watch?v=uZR2kXLELFc&hd=1 |
01-20-2013, 12:02 PM
#268 | |
Oddometer: 743
It's ok,I planned on this happening |
01-20-2013, 12:53 PM
#269 |
Unwounding
Oddometer: 4,323
01-20-2013, 01:15 PM
#270 |
Oddometer: 213
In order to get a real sense of what it might sound like like you'd have to be onboard rowing through the gears but at idle and unloaded throttle this sounds very, very annoying. Only good for the aftermarket.
stock Ninja 300 sounds much better.
