Old 01-19-2013, 11:12 AM   #16
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
Originally Posted by chasbmw View Post
Kai,
Yours shows benefits of CNC stuff. Mine is slightly lighter at 5.24lbs.
Is the picture of your old flywheel showing the starter side of the ring gear?
Yes it is, as per your request.
Yes mine was CNC'd. I have slightly lighter one but the machining went into the ring gear by about 3 mm and I don't know if it'll hold up. My machinist did exactly as I asked, I just asked for a bit too much.
It'll make a great lamp base eventually.
Kai Ju screwed with this post 01-19-2013 at 11:17 AM
Kai Ju is offline   Reply With Quote
Old 01-20-2013, 04:36 AM   #17
chasbmw OP
Oddometer: 2,349
Kai Ju.
Thanks for the photos, big difference in the design of the ring gears, the older ones such as mine having the chamfer.
C
Charles
1971 Commando Fastback
Old 01-20-2013, 07:02 AM   #18
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,243
My burning question concerns what exactly the problem is -
Is it a problem with the starter motor engaging the flywheel teeth? Does the starter motor start spinning and grind against the flywheel teeth without turning over the engine?
Or two - does the starter motor engage the flywheel ring gear, but can't turn the engine?
Old 01-20-2013, 07:27 AM   #19
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,984
^^^^^^^this^^^^^^^
---Albert Einstein
Old 01-20-2013, 10:02 AM   #20
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,644
Originally Posted by supershaft View Post
I think a couple of people here have said they have replaced the gear ring. Reportedly it's an interference fit.
Interesting.. I've never heard/read this before. Seems like a lot of work for something still relatively easy to find on ebay and ibmwr.
crazydrummerdude is online now   Reply With Quote
Old 01-20-2013, 12:28 PM   #21
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
Except when you're in chasbmw's shoes where you have a modified flywheel that was balanced with the rest of the engine.
Old 01-20-2013, 04:26 PM   #22
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,644
Yeah, but what's more work; assuming his teeth are actually beyond repair, finding another flywheel with "good" teeth and 1) lightening it or not... or 2) pressing the ring gear off the new one, pressing the ring gear off the old one, and finally pressing the ring gear on the new one and hoping/assuming it's still balanced?
Old 01-20-2013, 06:46 PM   #23
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
All good questions, the most important one being whether he has a flywheel or a starter problem.
Reading some of the comments it seems that the v-notch may actually be normal. If so then I have to agree that the teeth don't look any worse than the ones in the pic I posted.
Which in turn means that this is a starter/battery problem.
Old 01-22-2013, 12:06 AM   #24
Wirespokes
Wirespokes's Avatar
Oddometer: 8,243
I don't recall ever seeing a flywheel without the angled tooth faces. They have always looked similar to the ones in question.
Old 01-22-2013, 12:50 AM   #25
Kai Ju
Kai Ju's Avatar
Oddometer: 1,895
Wirespokes, I've had four different flywheels pass though my hands in the past 6 months and none of them had the v-notch type tooth that chasbmw's wheel has.
Mind you, they were all '77 vintage as far as I know.
Old 01-22-2013, 01:08 AM   #26
chasbmw OP
Oddometer: 2,349
It's an interesting discussion about the design of the flywheels. Mine is from a 92 tooth early flywheel, did BMW change the design? Did the design of the starter motor gear change at the same time?
Mind you on my flywheel the V notch looks to be unworn. They main damage on my flywheel is to the front of the teeth, where it looks to have been bashed by the starter.
Charles
Old 01-22-2013, 01:13 AM   #27
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,984
I found almost 25 flywheels on Ebay in a search. There were even more found on Google. Some of these flywheels have the V shaped cut, or V notch. Not all but many of the unlightened 93 tooth flywheels have this. See;
If there is damage from a 9 tooth starter being used on a ring gear designed for an 8 tooth starter the damage will progress as the flywheel spins. It will appear at one edge of the notch in some places, the middle and then the other edge. Now I've never seen this but it makes mathematical sense. I've never seen a ring gear that didn't work. A few stories about this but nobody has ever taken a picture.
---Albert Einstein
Old 01-22-2013, 01:41 AM   #28
chasbmw OP
Oddometer: 2,349
Dissiton,
Any chance of that photo without the cobwebs, I can use a file to put back the facets on the lead edge of the tooth.
Cheers
Charles
Old 01-28-2013, 09:43 AM   #29
chasbmw OP
Oddometer: 2,349
I have cleaned up the ring gear on my flywheel, with a combination of hand file and Dremel.
It looks much better now, just have to wait until everything is done and we shall see how well the starter works.
Charles
Old 01-28-2013, 10:19 AM   #30
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,984
What do the teeth on the starter look like? Also the part directly under the teeth of the starter is a one way clutch. It should spin freely in one direction only and it should not be cracked. Often when these go bad they are cracked.
---Albert Einstein
Times are GMT -7.   It's 01:45 PM.
