Old 01-20-2013, 07:59 PM   #1
Bob Tosi OP
Bob Tosi's Avatar
Oddometer: 1,607
Having trouble seating the bead on heidenau's k60 scouts
I'm changing to these in my Tiger and I can't seem to get the bead to seat. I even tried to use a ratcheting tie down strap around the tire but no luck.
Anyone got some good ideas?
When you're lost in the wild and scared as a child. And death looks you bang in the eye, and your sore as a boil, its according to Hoyle to cock your revolver... and die. But the code of a man says "fight all you can" and self-dissolution is barred. In hunger and woe, its easy to blow... Its the hell-served-for-breakfast thats hard........Robert Service
Bob Tosi is offline   Reply With Quote
Old 01-20-2013, 08:14 PM   #2
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,973
try taking out the valve stem to get more volume of air in, did you lube the bead too?? You'll need a decent cfm compressor, not a little 110 tire pump thingy, or worse 12volt pump.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-20-2013, 08:18 PM   #3
Idle
Oddometer: 719
Had the same problem with a heidenau K73 for my tubeless rear rim.
I took it to the tire shop and they helped me get it set. Used a bead blaster air tank.
Idle is offline   Reply With Quote
Old 01-20-2013, 08:59 PM   #4
victor441
victor441's Avatar
Oddometer: 1,041
+1 on the tire lube and use the real stuff, Napa carries it for about $12/gal IIRC, a gallon would probably last a hobbyist a lifetime. Also try pumping the tire up to 50-60 psi, that will often do the trick and get the bead to seat and usually you will hear a pop when it happens...
victor441 is offline   Reply With Quote
Old 01-20-2013, 09:10 PM   #5
Bob Tosi OP
Bob Tosi's Avatar
Oddometer: 1,607
I was using soapy water. The big blocks seated real easily.
These wont even pressure up.
Old 01-20-2013, 09:23 PM   #6
victor441
victor441's Avatar
Oddometer: 1,041
hmmm, what are you using as an air source? If it won't flow a fair volume as said above sometimes tubeless tires won't seat. I ran into that once before I had a compressor and ended up connecting two hand pump air chucks with a hose and connecting one end to a inflated auto tire and one to the MC tire and that worked....once the MC tire held air I was able to fill both up w/ my bicycle pump. A portable air tank might work too...or maybe a bead seater?? have not tried one myself but they are supposed to seat even the most difficult tires
victor441 screwed with this post 01-20-2013 at 09:58 PM
Old 01-20-2013, 10:08 PM   #7
Bob Tosi OP
Bob Tosi's Avatar
Oddometer: 1,607
I was using my 6gal home compressor that I use for air tools and filling up tires. It probably is not putting out enough volume.
Old 01-21-2013, 12:58 PM   #8
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
Push one side against the wheel by hand, then use an old (or new) bicycle tube to fill the gap on the other side. Maybe a piece of plywood to hold the tube in place and close the gap but don't pinch the bicycle tube in there. Then inflate. Trust the really old guy who showed me that so many years ago.
Have tools, will travel!
Old 01-21-2013, 03:09 PM   #9
gsweave
Yinz, blinkers are on.
Oddometer: 12,506
Did you clean the old rubber from inside the rim??? Scotchbride and kero are your friend
pull valve stem
Heat tire up. nice sunny days are hard to find here right now... more lube
More cfms 6 gallon could do it but bigger compressor would be mo better.
I wouldn't be afraid to run her up to 60 psi as long as valve stem is pulled. (short duration pushes to 60psi)
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 01-21-2013, 03:31 PM   #10
dirtybike
Oddometer: 128
Ratchet strap around the circumference (outside) of the tire. As you tighten the ratchet, it should push the beads out toward the rim.
I haven't needed to do this in many years. I would stop adding air, and release the ratchet as soon as the tire would hold pressure.
dirtybike screwed with this post 01-21-2013 at 03:34 PM Reason: Additional info
dirtybike is offline   Reply With Quote
Old 01-21-2013, 05:49 PM   #11
Jeff B
Socially Awkward
Jeff B's Avatar
Oddometer: 6,187
Jeff B is offline   Reply With Quote
Old 01-21-2013, 06:24 PM   #12
_cy_
Oddometer: 6,442
go to 3.15 ... guy is long winded
Old 01-22-2013, 11:20 AM   #13
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 774
dangerous practice
No need to ever use ether or other explosive mixture to seat tire at home.
YOU RISK DEATH OR WORSE WITH ETHER !
Maybe 100 mile from nearest service ^ ,other wise straps, remove valve core and 5 + hp compressor(10cfm) and proper technique will seat any tire .
It might take more than 2 hands and it might take more than 2 tries ,but 3.50-4 to 11r24.5s will seat .
Get someones help , another rider, tire tech ,somebody .
pennswoodsed is offline   Reply With Quote
Old 01-23-2013, 07:38 PM   #14
Bob Tosi OP
Bob Tosi's Avatar
Oddometer: 1,607
I end up taking out the valve stem and using the mechanics compressor at work, industrial size. The front popped right into place.
Thanks guys
Bob Tosi screwed with this post 01-24-2013 at 11:56 AM
Old 01-24-2013, 11:58 AM   #15
Bob Tosi OP
Bob Tosi's Avatar
Oddometer: 1,607
Ok the rear is being a real pita! Can't get the bead to seat. I tried taking out the valve stem and using a high volume high pressure air and that wouldn't do it.
Any ideas?
Times are GMT -7.   It's 02:10 PM.
