Old 01-18-2013, 11:47 AM   #6886
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,182
Valve Job
Damn I need a valve JOB. Dont think I can convince the wif of the living room being the right spot. Dont think I can squeeze it into an afternoon while she is at work, so I'm f"d. Dont want to pay the steelers and it would be my first v'job...yeah I'm virgin. And my math aint so gooood. Measuring the little f'ers (assuming I'm out of spec) is going to test my logic skilz. Suppose it is easier the second time for you pros.
So, gonna have to delay the inevitable for a sunny day in the condo parking lot. Seen the links, time for a deep breath of spring air, in the spring, and go for it. FYYFF.
Start slow then easy off
OhBoy is offline   Reply With Quote
Old 01-18-2013, 11:51 AM   #6887
yuu
yuu's Avatar
Oddometer: 122
Technology to the rescue
I didn't make this gem, but it's an excel spread sheet that you punch in the numbers to and it spits out closest shim fit KTM part number
http://dl.dropbox.com/u/19350741/690...Calculator.xls
FWIW - you can get harley Shims for the V-rods in smaller increments than the ones from KTM if you want a more accurate fit. KTM ones go at 0.005 mm and the HD ones are 0.0025 per step
Throttle's on the right, so are the brakes. Good luck.
yuu is offline   Reply With Quote
Old 01-18-2013, 12:39 PM   #6888
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,806
Originally Posted by Seth S View Post
good point. Was thinking about the valve adjustment procedure of the 950's where you have to pull the cams out to get at the buckets. Forgot that the cam stay in place in the 690 motor...makes life a lot easier.
It surely does, 15 minute valve checks, another 5 if you have to re-shim.
Old 01-18-2013, 12:44 PM   #6889
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,806
Valve JOB or valve clearance check? Two very different things.
Old 01-18-2013, 10:40 PM   #6890
jorich
jorich's Avatar
Oddometer: 76
Hey has anybody seen or (hopefully have a link) for an extension harness for the 2010 enduro R instrument? I swear I have seen one for sale somewhere, but I have been looking all night without success
A ship is safe in the harbor, but that's not why ships are built...
'10 KTM 690R:)
jorich is offline   Reply With Quote
Old 01-19-2013, 03:43 AM   #6891
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,182
Thank you
Old 01-21-2013, 01:23 AM   #6892
ktmmitch
Oddometer: 692
Now we have finished the EVO2 moulds we are back onto some development jobs we want to get into production this spring.
One of them is our 2 piece billet clutch cover to suit the KTM 690 Enduro and Rally.
Here are a couple of shots of the finished CNC machined model,which we will fit to an engine,before making the final billet aluminium parts.
ktmmitch is offline   Reply With Quote
Old 01-21-2013, 03:30 AM   #6893
Evil Invader
Evil Invader's Avatar
Oddometer: 696
Dammit ktmmitch, I want your job!
Nice
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is offline   Reply With Quote
Old 01-21-2013, 09:34 AM   #6894
ktmmitch
Oddometer: 692
Nice
I'd like to train someone up,just like me.............
But then I think,no,they would be a bitch to live with!!!!!
Old 01-21-2013, 12:10 PM   #6895
Baja Dad
Baja Dad's Avatar
Oddometer: 2,033
My Evo 2 parts are starting to land at my front door
I will post pics as thing get opened up !!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 01-21-2013, 12:35 PM   #6896
SKINNY
SKINNY's Avatar
Oddometer: 653
I'm curious as to how the main fairing mount that fits against the steering stem can miss the big black plastic wire junction thing that is already there...and if there is enough slack in the instrument panel wiring to move it to the Rally Raid dash board...I'm waiting to see what (if any) your frustration level is as you install...
I'm heading for central Mexico end of March and would like to have the fairing and tanks mounted by then...
SKINNY is offline   Reply With Quote
Old 01-21-2013, 12:47 PM   #6897
ktmmitch
Oddometer: 692
The big plastic housing is removed and the wiring loom re-routed through our cockpit support.It reaches easily up to the speedo mounted in the dash,for either the Adventure,or in this case,the Rally version.
Old 01-21-2013, 01:18 PM   #6898
SKINNY
SKINNY's Avatar
Oddometer: 653
Thanks for the tip...I'll be ordering in a few days...
Old 01-21-2013, 02:21 PM   #6899
Noyah
poser
Noyah's Avatar
Oddometer: 400
Sent from my HTC One X using Tapatalk 2
KTM 690 Enduro R
--> My Movies <--
Noyah is offline   Reply With Quote
Old 01-21-2013, 02:40 PM   #6900
Baja Dad
Baja Dad's Avatar
Oddometer: 2,033
I trashed that Big Black junction box long ago!
the wire loom seem to have lots of slack in it.
I will post pics as I do the install.
Times are GMT -7.   It's 02:33 PM.
