Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 01-21-2013, 03:59 PM   #6661
MizzouRider
MizzouRider's Avatar
Oddometer: 1,465
Originally Posted by Emmbeedee View Post
I hope you realize we are talking about the Trip Computer data fields. You can add data fields to the map screen too as long as you choose the right Dashboard.
Sent using strings and tin cans and Tapatalk
I was able to change both!! It helps to unlock the data fields. I went with speed, heading, distance to next, and ETA at Dest on my map. I also added six data fields to the trip computer. Then locked the data fields. Really very simple. Lots of choices. Now I've got to figure out how to set up different profiles and short cuts. Oh boy...
Thanks.
IBA#32778 2008 R1200GSA 2007 G650XChallenge
No man is as good as he ought to be, and few men are as bad as they seem.. (from a early 1900s post card found in Perry, Missouri..)
MizzouRider is offline   Reply With Quote
Old 01-21-2013, 04:35 PM   #6662
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,052
Thanks.
Glad to hear you're working it out. The best way to learn how it works is to just play with it when you are not under pressure and needing it for guidance. Then when you really do need it, you'll know exactly how it works.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 01-21-2013, 04:45 PM   #6663
AlaskaDave
AlaskaDave's Avatar
Oddometer: 11
Send a message via Skype™ to AlaskaDave
I put together a quick route on map source Friday, and took the bike out on Saturday. Couple of questions;
The Montana shut off a couple of times. I would hit the power button and it jumped right back in place, no problem.
Is this the loose battery issue? It happened twice. One when I was on the smooth blacktop. If its the loose battery, does the foam plug go above or below the battery? Or, is this possibly just a loose connection in the mount?
Second, it shows me on the screen how many miles to destination, but does not give me a ETA, or distance to next turn, can I add those fields to the map/route screen? I know these are probably answered elsewhere, put I'm not all that proficient at searching out answers. Or, I'm just a lazy bas&@rd..
Jeff
I've had similar problems regarding shutdowns. It doesn't happen often and I don't recall the roads where it happened as being especially rough. However, I will try the earplug trick even though I cannot understand why the battery connection would affect the power while connected to the AMPs mount.
AlaskaDave is offline   Reply With Quote
Old 01-21-2013, 05:01 PM   #6664
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,052
I was curious about that too at the time but mine was shutting down very often on one ride where the roads weren't rough, but I was revving the engine through the gears and it shut off or gave me the "Wrong Battery" message repeatedly until I stuck the earplug in the battery case.
My wife's did exactly the same and was cured the same way. The earplug seems to dampen the battery's movement.
Old 01-21-2013, 05:05 PM   #6665
woodsatyr
What?!!!
woodsatyr's Avatar
Oddometer: 254
A while back, I set the Montana so that when I put it in the car mount, it switches to Automotive profile; and when I put it in the rugged mount on the motorcycle, it switches to Motorcycle profile. I noticed recently that it didn't switch. I searched everywhere I could think of and can't find where that setting is. Do any of you guys know where that is?
TIA...
I'm still hot... it just comes in flashes now.
woodsatyr is offline   Reply With Quote
Old 01-21-2013, 05:15 PM   #6666
AlaskaDave
AlaskaDave's Avatar
Oddometer: 11
Alright-y, then. Done. And thanks.
Old 01-21-2013, 05:41 PM   #6667
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,052
TIA...
Setup/Profiles/Menu/Set Mount Profile.
I agree, it is hard to find.
Old 01-21-2013, 09:13 PM   #6668
eddyturn
Wannabe
eddyturn's Avatar
Oddometer: 1,003
Oh faaaack. My 600 will be here on Wednesday courtesy of FedEx and GPS City. Diving in and holding my breath. I'll still keep one of my 478's around as a back up but hope I can remember all of these posts when the time comes.
All things being equal... fat people use more soap
eddyturn is offline   Reply With Quote
Old 01-22-2013, 06:16 AM   #6669
Riteris
Dessert Runner
Oddometer: 2,553
TIA...
I had the same thing happen. Why does the Montana "forget" stuff???
Chris
I am taking the advice of all those people that told me, "Hey kid, why don't you go play in traffic!"
Riteris is offline   Reply With Quote
Old 01-22-2013, 06:37 AM   #6670
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,052
I think sometimes what happens is a software update breaks things like that, and you have to go back and restore the connection again through the menu.
Just a guess on my part, though.
Old 01-22-2013, 06:50 AM   #6671
Riteris
Dessert Runner
Oddometer: 2,553
I did update the maps around the same time I noticed the issue. I am not saying that caused the issue but that is the only coincidence I can think of.
Chris
Old 01-22-2013, 06:59 AM   #6672
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,304
Do we know of a config file that holds those settings? If so, maybe we could backup that file prior to an update and then restore it after, and this would prevent it "forgetting"?
2005 R1200GS | 2013 R11200GSW | SOHC4 208 | DoD 2032 | BMWMOA | BMWRA | YB
Smugmug Coupon: mStnWv71mNkjo
Join the NRA: http://membership.nrahq.org/
Old 01-22-2013, 08:39 AM   #6673
Riteris
Dessert Runner
Oddometer: 2,553
I think it might be more user error on my part. AAAAAUUUUGH!!!
Under "External Power Only" in "Set Mount Profiles," the selection was "Last Used." I changed it to "No Change." I am guessing the change happened when I plugged it in to update the maps.
Can we get a "No Change" selection on all the features of this thing?
Chris
Old 01-22-2013, 09:57 AM   #6674
GaM
GaM's Avatar
Oddometer: 1,876
Is the power cable an integral part of the rugged mount? I can't find a pic that shows how the cable hooks in. I've always been able to have a cable on each bike and just move the cradle to the bike I was using. I don't even see a separate part number for the power cable though. Am going to need the rugged cradle with power cable for each bike?
GaM is offline   Reply With Quote
Old 01-22-2013, 10:49 AM   #6675
bighopper
Oddometer: 129
Sorry it is part of the rugged mount. But the car mount has a cable that can be disconnected, but the mount is only a snap in style.
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Times are GMT -7.   It's 02:43 AM.
