Thread Tools Search this Thread Rating: Thread Rating: 41 votes, 4.34 average. Display Modes
Old 01-22-2013, 10:52 AM   #6676
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,814
Originally Posted by GaM View Post
Is the power cable an integral part of the rugged mount? I can't find a pic that shows how the cable hooks in. I've always been able to have a cable on each bike and just move the cradle to the bike I was using. I don't even see a separate part number for the power cable though. Am going to need the rugged cradle with power cable for each bike?
At $35 each, it's easy to justify buying a Rugged Mount for each bike but it's also easy to make the mount movable, by putting a SAE plug on the end of it, and running a cable up to the steering head of the bikes. I used to do this until I bought the second mount for my DR. Actually I still have the SAE plug on each cable, it's just that I no longer need to move the mount over. I like having the SAE plug though because when I don't need to power the gps, I can hook up a Battery Tender to the bike.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 01-22-2013, 11:13 AM   #6677
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,814
Originally Posted by Emoto View Post
Do we know of a config file that holds those settings? If so, maybe we could backup that file prior to an update and then restore it after, and this would prevent it "forgetting"?
No idea if there is a config file storing those settings but I think it's more a matter of multiple files which make up the environment. It's always a good idea to back things up, but I am not convinced that a complete restore would re-establish things like "Set Mount Profile".
I've found it helps to just check once in a while, and if something looks or behaves differently, I try to restore it but not lose too much sleep over trying to figure out why it changed. But you're welcome to.
Old 01-22-2013, 12:08 PM   #6678
GaM
GaM's Avatar
Oddometer: 1,876
Ok, I think I'll just get two cradles. It was an easy swap with the 2620, but the 2620 didn't have a tether point, I hope whoever finds it enjoys it.
GaM is offline   Reply With Quote
Old 01-22-2013, 12:26 PM   #6679
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,814
You lost the 2620?
Sent using strings and tin cans and Tapatalk
Old 01-22-2013, 12:45 PM   #6680
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,142
Forgive me if this is the wrong thread for this, but what are people using for Canadian topo maps on Montanas?
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA
Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/
Old 01-22-2013, 12:53 PM   #6681
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,814
Topo Canada V4 is the best.
Old 01-22-2013, 12:58 PM   #6682
Rocky TFS
Rocky TFS's Avatar
Oddometer: 200
Yes, the cable is part of the mount and although it can be removed it's not something you'd want to do routinely.
No, you don't have to buy a mount for each bike, just add an SAE connector on each bike and the mount, then swap the mount along with it's cables. You will have to figure out a way to coil and/or shorten the cable that allows for the different configuration of each bike. Some velcro bands like musicians or electricians use to keep wires and cables from turning into rat's nests would make it fast and clean.
I would get a Ram ball for each bike, that will make the swap into a 15 second affair.
Edit: Sheesh, in the time it took me to type this reply three people beat me to it!!!
Rocky TFS is offline   Reply With Quote
Old 01-22-2013, 01:12 PM   #6683
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,814
Boy, you sure do type slowly. I responded at 1:52 and bighopper at 1:49. ;)
Old 01-22-2013, 01:31 PM   #6684
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 16,142
I am also intrigued by Toponav.
Old 01-22-2013, 01:46 PM   #6685
GaM
GaM's Avatar
Oddometer: 1,876
You lost the 2620?
Yep, rode a lot of dirt roads that day, didn't even go back to look for it. I used it on two bikes for six years, a refurb at that. Never tried to update the maps, probably time for a change anyway.
Old 01-22-2013, 03:08 PM   #6686
Rocky TFS
Rocky TFS's Avatar
Oddometer: 200
That's because I was an editor in a former life....I can't help editing the post over and over.....
Perhaps you've noticed there are almost NO typos or punctuation mistakes in my posts...
Ti deosnt hlp thut m'i slecdlic, iethr.....
Old 01-22-2013, 03:38 PM   #6687
woodsatyr
What?!!!
woodsatyr's Avatar
Oddometer: 238
Setup/Profiles/Menu/Set Mount Profile.
I agree, it is hard to find.
Ah!! Thanks! I knew it was there somewhere.
And I agree - I think the updates wipe out that setting.
I'm still hot... it just comes in flashes now.
woodsatyr is offline   Reply With Quote
Old 01-22-2013, 04:32 PM   #6688
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,814
Yes, I was keeping track of the number.
Old 01-23-2013, 04:00 AM   #6689
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 5,814
Sure glad I don't need to go outside today...
Old 01-23-2013, 07:44 AM   #6690
Rocky TFS
Rocky TFS's Avatar
Oddometer: 200
OK, now it's your turn, you Easterners!
It was +30F here yesterday and the pavement 150 yds from the house was dry so I went for a short ride, the first since November 28th!
That 150 yds was interesting......
Edit: Boy we've sure done a good job of hijacking THIS thread!
Times are GMT -7.   It's 08:11 AM.
