Old 01-20-2013, 02:24 PM   #16
Queen of Spades OP
tall drink of water
Queen of Spades's Avatar
Oddometer: 361
I'll snap a pic and upload in a bit.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=Vl7XlZs2CRc (May 2013 trail riding)
'02 Kawasaki KX250 L4 http://www.youtube.com/watch?v=Sjgw-yZJdfs (Jan 2013 gopro )
Queen of Spades is offline   Reply With Quote
Old 01-21-2013, 08:01 PM   #17
Queen of Spades OP
tall drink of water
Oddometer: 361
Old 01-22-2013, 03:48 AM   #18
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,255
You lost yer battery..
Laromo
'91 Vespa PX 200E "Lusso"
'05 KTM 640 ADV "Fatman"
'99 HD FLHRCI "Leviathan"
Laromonster is offline   Reply With Quote
Old 01-22-2013, 04:45 AM   #19
Queen of Spades OP
tall drink of water
Oddometer: 361
http://www.youtube.com/watch?v=3HUGeA2lur4
Old 01-22-2013, 04:53 AM   #20
Queen of Spades OP
tall drink of water
Oddometer: 361
Returning to the topic at hand, does anyone have a picture of this section of wiring on their 640 LC4? Mine is a 99 model (enduro).
I'm unsure if both of the ends of the yellow/red wire are to be joined and inserted into the white plastic coupling (see the empty brass fitting).
Old 01-22-2013, 02:42 PM   #21
tallbob
tallbob's Avatar
Oddometer: 511
Mine's a 99 640E too. Picture isn't too clear but there are 2 yellow/red wires on one pin and 2 brown wires on the other pin of that connector.
Twin Valley Riders
tallbob is offline   Reply With Quote
Old 01-22-2013, 03:03 PM   #22
Queen of Spades OP
tall drink of water
Oddometer: 361
That works - suspected they fell out of the connector. Not sure of the best way to get them back in it -- will soldering work here? It seems like it would need to be cleaned off prior to that, though. Any ideas?
Old 01-22-2013, 04:48 PM   #23
bmwktmbill
Traveler
Oddometer: 4,063
Problems like this are difficult.
You will have to release the connector from the plug with a pick, resolder and then reinsert.
Sometimes that works. If it doesn't you will need new stuff to somehow recreate the connection.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 01-22-2013, 04:58 PM   #24
Queen of Spades OP
tall drink of water
Oddometer: 361
bill
Have you seen any youtubes or pictoral guides on how this is done (releasing fitting from connector with a pick)?
Old 01-23-2013, 05:52 PM   #25
bmwktmbill
Traveler
Oddometer: 4,063
No, you will have to use skill and imagination.
the rest if the forum can jump in anytime.
Usually there is a spring loaded clip thar retracts as it is pushed ahead, then snaps into place.
Check this out.
http://www.mcmelectronics.com/browse...ors/0000000675
bill
Bill Shockley
Old 01-23-2013, 07:15 PM   #26
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 2,733
Go to an electronics, auto sparky or auto parts store & get some new spade terminals to go in the plugs, should only be a few cents. The connectors come in all different shapes & sizes but the actual terminals inside are fairly standard. Once you have the new bare terminals you'll see how they are retained.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is online now   Reply With Quote
Old 01-24-2013, 11:39 AM   #27
Queen of Spades OP
tall drink of water
Oddometer: 361
Cheers
Clint
We don't have an Auto Sparky (though I wish we did - love the name!), but I will drop in at a Radio Shack and see if they still sell anything remotely close to what we are talking about.. Used to be a good place to get electronic parts, but now they are geared up as a phone dealer with a few odd audio/power cables.
Old 01-24-2013, 01:27 PM   #28
ChrisC
Molon Labe
ChrisC's Avatar
Oddometer: 6,287
Google "McMaster Carr" - they have all sorts of 12V connectors, including waterproof, so you could rewire and replace the faulty connector...
Chris
'03 KTM Adventure 640
'43 BSA M20WD
ChrisC is offline   Reply With Quote
Old 01-24-2013, 04:36 PM   #29
wrk2surf
BITD/Rallye
wrk2surf's Avatar
Oddometer: 5,344
radio shack does have molex connectors similar that come with the new pins and they sell the tool .. works in a pinch !
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle
wrk2surf is offline   Reply With Quote
Old 01-26-2013, 01:04 PM   #30
Queen of Spades OP
tall drink of water
Oddometer: 361
Good news/bad news.
Good: made a tool to get the molex connector removed. It worked.
I crimped the wires back to the clip and soldered the connection too. It is snug as a bug.
More good news: it started up no problem. Warmed the engine up, then let it idle while I went over to talk with a neighbor.
About 5 minutes later I heard the bike stall out of nowhere. The headlight stays on, it just won't start. I've jiggled the connections, taken them apart and put them together. Fuses ok.
Exact same f'ing problem as before.
I want to pull my hair out. What else would randomly cause it to die? Nothing else in the battery area is loose or worn/exposed.
Times are GMT -7.   It's 10:52 PM.
