01-20-2013, 02:24 PM
#16 |
tall drink of water
Oddometer: 344
I'll snap a pic and upload in a bit.
'99 KTM 640 LC4 Enduro http://www.youtube.com/watch?v=Vl7XlZs2CRc (May 2013 trail riding) '02 Kawasaki KX250 L4 http://www.youtube.com/watch?v=Sjgw-yZJdfs (Jan 2013 gopro ) |
01-21-2013, 08:01 PM
#17 |
tall drink of water
Oddometer: 344
01-22-2013, 03:48 AM
#18 |
Vesperado !
Oddometer: 1,255
You lost yer battery..
Laromo '91 Vespa PX 200E "Lusso" '05 KTM 640 ADV "Fatman" '99 HD FLHRCI "Leviathan" |
01-22-2013, 04:45 AM
#19 |
tall drink of water
Oddometer: 344
01-22-2013, 04:53 AM
#20 |
tall drink of water
Oddometer: 344
Returning to the topic at hand, does anyone have a picture of this section of wiring on their 640 LC4? Mine is a 99 model (enduro).
I'm unsure if both of the ends of the yellow/red wire are to be joined and inserted into the white plastic coupling (see the empty brass fitting).
01-22-2013, 02:42 PM
#21 |
Oddometer: 509
Mine's a 99 640E too. Picture isn't too clear but there are 2 yellow/red wires on one pin and 2 brown wires on the other pin of that connector.
Twin Valley Riders |
01-22-2013, 03:03 PM
#22 |
tall drink of water
Oddometer: 344
That works - suspected they fell out of the connector. Not sure of the best way to get them back in it -- will soldering work here? It seems like it would need to be cleaned off prior to that, though. Any ideas?
01-22-2013, 04:48 PM
#23 |
Traveler
Oddometer: 4,009
Problems like this are difficult.
You will have to release the connector from the plug with a pick, resolder and then reinsert. Sometimes that works. If it doesn't you will need new stuff to somehow recreate the connection. bill
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
01-22-2013, 04:58 PM
#24 |
tall drink of water
Oddometer: 344
Have you seen any youtubes or pictoral guides on how this is done (releasing fitting from connector with a pick)?
01-23-2013, 05:52 PM
#25 |
Traveler
Oddometer: 4,009
No, you will have to use skill and imagination.
the rest if the forum can jump in anytime. Usually there is a spring loaded clip thar retracts as it is pushed ahead, then snaps into place. Check this out. http://www.mcmelectronics.com/browse...ors/0000000675 bill
01-23-2013, 07:15 PM
#26 | |
Trans-Global Chook Chaser
Oddometer: 2,703
Cheers Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
01-24-2013, 11:39 AM
#27 | |
tall drink of water
Oddometer: 344
01-24-2013, 01:27 PM
#28 |
Molon Labe
Oddometer: 6,286
Google "McMaster Carr" - they have all sorts of 12V connectors, including waterproof, so you could rewire and replace the faulty connector...
Chris '03 KTM Adventure 640 '43 BSA M20WD |
01-24-2013, 04:36 PM
#29 |
BITD/Rallye
Oddometer: 5,310
radio shack does have molex connectors similar that come with the new pins and they sell the tool .. works in a pinch !
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle |
01-26-2013, 01:04 PM
#30 |
tall drink of water
Oddometer: 344
Good news/bad news.
Good: made a tool to get the molex connector removed. It worked. ![]() ![]() I crimped the wires back to the clip and soldered the connection too. It is snug as a bug. ![]() More good news: it started up no problem. Warmed the engine up, then let it idle while I went over to talk with a neighbor. About 5 minutes later I heard the bike stall out of nowhere. The headlight stays on, it just won't start. I've jiggled the connections, taken them apart and put them together. Fuses ok. Exact same f'ing problem as before. I want to pull my hair out. What else would randomly cause it to die? Nothing else in the battery area is loose or worn/exposed.
