Thread Tools | Search this Thread | Rate Thread | Display Modes |
01-20-2013, 10:02 AM
#1 |
Sure, why not?
Oddometer: 16,137
Can you turn off the dashboard on a 660/665?
Can you turn off all of the dashboard fields? Or make them really small or transparent?
Just curious.
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
01-22-2013, 07:50 PM
#2 | |
Oddometer: 3,985
If so I think the answer is no. Unlike the hand helds which the user can choose how many and which ones of a list of a hundred (I like glide ratio), Garmin thinks that users of street GPS units are not smart enough to set these fields and they do it for you and you better like it.
Jerry Counts |
01-23-2013, 04:54 AM
#3 | |
Sure, why not?
Oddometer: 16,137
01-23-2013, 05:05 AM
#4 |
Oddometer: 1,562
On the 62s, dashboard changes are made under the 'Setup Map' screen. When I change the 'Data Fields' to '0'. All I see is the map on the GPS screen.
On the 62s, I can set the 'Data Fields' to display 0, 1 Large, 2 Small, 4 Small, Dashboard or Custom. Hope that helps! daryl |
01-23-2013, 06:59 AM
#5 |
Forever N00b
Oddometer: 1,603
In the "Setup" menu and the "Display" submenu there are supposed to be options for "More Data" and "Less Data".
It's in plain sight only if you know what they mean by those terms. You won't find it by searching the very logical "dashboard". Neither setting may be as "off" as you'd like. You can also apparently make the fields transparent and move them to the corners of the screen:
Motorcycles are magical. Grinnin screwed with this post 01-23-2013 at 07:09 AM |
