01-23-2013, 11:58 AM
#256 | |
Oddometer: 189
And how the hell does that data inform you that you don't need to counter steer a chopper unless you're going fast? I'm either dumber than my mom said or something is wrong here. Or both.
2010 BMW S1000RR |
01-23-2013, 12:29 PM
#257 |
Oddometer: 584
I don't think he's serious lol
01-23-2013, 12:33 PM
#258 |
Oddometer: 189
Well, that does explain it.
Seems the answer is "both".
2010 BMW S1000RR |
01-23-2013, 12:37 PM
#259 | |
Oddometer: 17,983
The "Transition speed" is MOVING OR NOT MOVING. To turn a moving motorcycle you counter steer evey time on EVERY BIKE. 1 mph? Yup! 5 mph? Yup! 15 mph? Yup! 60 mph? Yup! It does not matter what bike. It does not matter what speed. There is no mythical transition speed. If you are moving and you turn. YOU COUNTER-STEERED! 100% of the time. The end. ![]() Nice troll.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
01-23-2013, 12:47 PM
#260 |
Oddometer: 365
01-23-2013, 01:04 PM
#261 |
Oddometer: 13
I think part of the problem with non-believers is that it doesn't feel like your counter steering on some bikes... like a big cruiser going 5 mph.
A few months ago I switched from a Ver-sys (having other standards/dual-sports before that) to a Suzuki C50 (an 800cc "old style" looking cruiser - big tires, fenders, etc.) When going slow the front wheel heavily turns the direction you're going, if you didn't know better you would think it's not counter-steering. It's just a millisecond twitch that leans the bike over and then the wheel turns. I can see how some people don't think it's happening even though it is. I also think having big arguments about it is pretty funny. . |
01-23-2013, 01:08 PM
#262 |
I'd rather be riding
Oddometer: 2,565
I agree. And I add: Some people are trolling even when their statements are correct. Some are not trolling even when they are wrong. It's all in the wrist, I mean the attitude.
01-23-2013, 01:11 PM
#263 |
UDF Adventurer
Location: an alternate universe, much better than yours
Oddometer: 294
maybe somebody has already posted this...
Honda ST1300, Ural Gear Up, Rokon Ranger and now an Argo, WTF is wrong with me? A Brit named Billy once said something silly; he so wrongly concluded that Ural deluded.
01-23-2013, 01:30 PM
#264 |
Oddometer: 17,983
Embed
01-23-2013, 01:44 PM
#265 | ||
Oddometer: 663
From a physics stand point (which applies to everyone) this is what would happen if there was some sort of "transition" between direct steering at low speeds to counter-steering at high speeds. At some point in speed when you are directly in the middle of that transition point than steering the front tire in any direction or any amount would literally have zero effect on the motorcycle. You wont lean or turn in any direction, it would have no effect. Does that actually happen? No! For there to be a transition point you MUST have a transition!!!!! To add to this issue while your approaching that "transition" point the steering would get less and less sensitive until nothing happened at all. (it could never be a single magical speed at 0.0000001 mph). As you accelerated past that transition point it would gradually get more sensitive until you got to full "counter steer." Quote:
. Unfortunately there are a lot of different forces and factors that make counter steering work. If the broom example helps anyone understand why it works and gets them in the right frame of mind than stick with it! But that's not how counter steering physically works. With the broom you move your hand around under it to get the broom's CG centered back on your hand. For that to work on a motorcycle you would need to move the entire front tire left or right out from under the motorcycle the same way you move your hand under the broom (there is actually an RC bike that steers this way). On a motorcycle the front tire simply turns, it doesn't move relative to the frame other than the tiny amount caused by rake angles.
Fajita Dave screwed with this post 01-23-2013 at 01:59 PM |
01-23-2013, 03:03 PM
#266 | ||
Oddometer: 76
Countersteering is nothing more than steering off the line that the bike is currently balanced on in an effort to move the CoG away from the current location in order to change the lean angle and affect a turn. We only countersteer (outside the turn) momentarily to initiate a turn (by moving the contact patch out allowing gravity to induce the lean), then the wheel turns towards the turn and is steering normally (during steady-state turning). When we're done turning, we again countersteer (more deeply into the turn driving the contact patches towards the CoG) to right the bike and end the turn. Countersteering is not about keeping the front wheel turned opposite the turn during the turn. That would be foolish and would cause the bike to just lay over on it's side. Countersteering is only about changing the lean / roll angle of the bike. Once the bike is rolled into a lean, normal steering is what keeps us in balance through the turn. The effect of countersteering is more pronounced at speed because even the slightest turn of the handlebars will see the front wheel (and it's contact patch) move quickly off to the side. It's the movement of the contact patch (like Lion BR's hand) that moves outside of the CoG (the broom) that allows the bike to lean and later turn. Conversely, at slower speeds we have to make larger (counter) steering corrections in order to move the CoG quickly enough. That's why slow races are so difficult. I know, I know . . too many words. And I didn't mean to science it all up like that . . . . cheers, |
01-23-2013, 03:08 PM
#267 |
Oddometer: 76
Shaddix,
When we start from a steady-state balanced & non-turning condition (see disclaimer), and we shift our weight to one side, the bike naturally has to lean in the opposite direction. The bike's leaning is required to balance the force required to shift your weight. When a bike is leaned, however slightly, the combined effects of steering angle, rake, trail and tire profile - cause the front forks to steer into the bike's direction of lean (see note). In motion, this then causes the front tire to out-track in the direction of bike lean, moving the bike further out of balance relative to the rider and the CoG further into the direction of the body lean. At which point the bike will roll past vertical into a lean in the direction of the body lean & combined CoG. Then the bike will turn. So while it seams that all you are doing is shifting your weight, in actuality the bike naturally counter-steers in response to the weight shift. Discussions about countersteering are about using this natural effect of bike dynamics to consciously control the bike with greater precision and greater urgency on command as needed. Those people that have learned & mastered the technique enhance their ability to control their bike, especially in critical conditions. It's about learning as much as we can about how bikes work so we can ride more safely in a range of conditions. Disclaimer: A motorcycle in motion is never in a steady-state of balance. In motion all single-track vehicles lean and weave right and left continuously. The effect is most pronounced at slow speeds but even at speed it happens continuously. There's no way to stop it since we are balancing over two inline contact patches. Note: You can see this effect by holding a bicycle from the top bar while vertical w/ neutral steering angle. Now lean the bike slightly in one direction or the other. Without any input at the handlebar, the front wheel will turn into the direction of lean. Lean the bike in the other direction and the front wheel will turn towards the new lean angle. |
01-23-2013, 03:18 PM
#268 | |
Oddometer: 584
01-23-2013, 06:46 PM
#269 | |
Oddometer: 76
At any rate all of this is opinion and not science. Neither of us can prove our points without the science. So I'm sure we can agree to disagree. cheers, |
01-23-2013, 07:17 PM
#270 | |
Oddometer: 2,565
Lion BR screwed with this post 01-23-2013 at 08:43 PM |
