Old 01-23-2013, 09:42 AM   #61
Cyath OP
Impetulant Ignoramus
Cyath's Avatar
Oddometer: 431
Yep, she has a brand spanking new Yuasa battery on a battery tender and the spark was blue.
What's the CDI?
"You think I can remember what you posted a year ago? I can't remember what kind of beer I drank for breakfast." -SScratch
'10 KTM 990 Adventure aka The Spork
Cyath is offline   Reply With Quote
Old 01-23-2013, 10:30 AM   #62
Dogtown
Dogtown's Avatar
Oddometer: 410
Hummm?
Fuel coming in and sparking blue plugs equal combustion! The only thing I can thing of is fuel to air ratios not being correct for actual combustion. If this was the cause a sensor would be out somewhere and your FI would be throwing a fault code. My money is on a pinched wire some where. Check all over for missing insulation on wiring or a ground.
Good luck!
OH 7 990
Marin County To Cabo!
Dogtown is offline   Reply With Quote
Old 01-23-2013, 07:18 PM   #63
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 698
You've got spark & fuel: too much fuel? If the ECU lost control of the EFI leaving both injector valves open you'd experience the same symptoms you're having now. Can you smell gas at the exhaust tips?
Or maybe the fuel pump isn't running when you crank the engine, only when you turn the key to on. Again, an ECU failure.
2
HeatXfer is offline   Reply With Quote
Old 01-23-2013, 11:38 PM   #64
achile
achile's Avatar
Oddometer: 289
2
Dosen't the pump need a bit of priming?
If you don't smell gas, you can always use a seringe and a hose to squirt some gas in the cylinder. My xtz 750 Super Tenere had this nasty habbit.
achile is offline   Reply With Quote
Old 01-24-2013, 11:08 PM   #65
Steveman
Steveman's Avatar
Oddometer: 471
Originally Posted by DuctTape View Post
Naw, as a matter of fact if you hit that switch the lights on the dash won't even come on and you'll think you have a dead battery.
Yeah right!
Come on.... all lights of the dash would be on if kill switch is pressed... and this is the same on all KTM motorcycles.
Repeat the spark test and do it properly. Take the ignition cable off and put a sparkplug into the plug and hold the spark plugs thread against the engine block, start and see if theres a healthy blue spark, repeat for second cylinder.
You could also check the kill switch, meaning measure it with an Ohmmeter and check if your bike is equipped with an roll-over switch which might be the reason why your bike didnt fire up before the battery mess. Even if your battery is brand new, take another one for testing... Try to get an ECU from a mates bike or someone in here for testing...
Good luck
Steve
Sent from Samsung w. Tapatalk
Steveman screwed with this post 01-24-2013 at 11:19 PM
Steveman is offline   Reply With Quote
Old 01-25-2013, 02:47 AM   #66
Adventcha UnCut
Wannabe
Adventcha UnCut's Avatar
Oddometer: 323
Originally Posted by Cyath View Post
@achile
Turn the key and it everything lights up as it should.
Fuel pump and ABS whir on key on.
Place your hand on the bottom of the fuel pump on the start up procedure to feel if it is actually working - no vibes then something is amiss. Pull the pump assembly out of the LHS tank & check to see if the neg (-) female wire hasn't pulled from the male in the bottom of the pump unit or other way around. From experience .
Good luck
ADV UNCuT
Adventcha UnCut is offline   Reply With Quote
Old 02-03-2013, 06:47 PM   #67
przjohn
Oddometer: 145
So, what happened? Did you take it to the dealer?
przjohn is offline   Reply With Quote
Old 02-04-2013, 05:57 PM   #68
Dogtown
Dogtown's Avatar
Oddometer: 410
+1
Did you not have the kill switch to on???
OH 7 990
Old 02-13-2013, 10:22 PM   #69
Cyath OP
Cyath's Avatar
Oddometer: 431
Well, just to put this thread to bed, it was the fuel pump after all. It was working, but when they pressure tested it, it wasn't putting out enough psi. Go fucking figure.
Old 02-14-2013, 11:33 AM   #70
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 19,871
All good ideas catalina83.
No FI code, and everything is back and plugged in again, rechecked.
At least an FI code would give me a starting point.
I hate to admit this, but I once hooked up the low fuel connection to the fuel pump and vice versa. I know- it's color coded so a monkey can figure it out.
Shit! Now that I got to the end, I want to delete this post.
But I won't. It may help somebody as dumb as me someday.
I don't have to be right to argue.
NICO
unaweep screwed with this post 02-14-2013 at 11:40 AM
unaweep is offline   Reply With Quote
Old 02-14-2013, 04:02 PM   #71
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,811
I shall not cast the first stone.
But I won't admit anything, either ; )
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Times are GMT -7.   It's 10:00 PM.
