Old 01-23-2013, 04:51 PM   #46
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,096
Originally Posted by StevenD View Post
disconnecting the battery is BS.
The ecu is disconnected from the battery every time you shut the key to off .
Way to many people shouting with no idea what they shout about when it comes to efi.
how about sharing the wealth then instead of "shouting" about what we don't know? so far you've added very little to the conversation. please do share. im certainly not saying your wrong, i would just like to know more.
Originally Posted by knobbyjoe View Post
I'm just saying that if this is a REAL technical process why is this not specifically described in the KTM manual.
good question. that is the first place i looked as well with no luck. i have been pouring through the repair manual but nothing yet either.
Am I wrong? Is there any writing documentation from KTM about a 15-minute idle process to tune the ECU?
KJ
another great question. anyone?
seems all the mech's say so, seems everyone "knows" about it, but i have yet to see anything from ktm to document it.
laters,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 01-23-2013, 05:46 PM   #47
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 959
Send a message via Skype™ to ciedema
KJ
There is the section from the repair manual quoted on the first page of the thread that talks about it.
It is mentioned specifically on pages 2-11 (that is what is on the first page of the thread), 2-15 and 9-3 of the 990 engine manual, every time that it needs to be done when resetting the ECU or installing a new EFI Map.
Also from the way I read the manual it is very possible that this is only to do with calibrating the idle. Page 9-11 talks about this a fix for rough idling.
If needed I can post the words from the relevant bits.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
No Four Wheel Drives, No Fixers and No Fricken Whingers
Personal Attacks - the last refuge of the intellectually impaired.
ciedema is online now   Reply With Quote
Old 01-23-2013, 06:50 PM   #48
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 332
ciedema and fellow LC8 owners,
I am responding only to review the 15 min idle documentation mention in the above post. I really don't "no jack" but I can read.
I just checked the manual on the pages mentioned. This 15 min idle refers to, when using the KTM diagnostic tool. No procedures for doing this as a tune up. This is to reset the idle after engine replacement or maybe the dealer fixing the idle on a bike in the shop with the KTM diagnostic tool.
I still need convincing that the "15 minute idle" is nothing more than a sugar pill, wishful thinking, as an engine tuning procedure. Don't flame me if I am wrong as I hope I am wrong. But this looks like a shaman throwing bones. Yes I know, when I do the 15 min idle, I always feel like the bike is running better, but is it.
KJ
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 01-23-2013, 07:19 PM   #49
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 959
Yes that is how I read the manual also.
From page 2-11.
The engine may have a poor idle behavior if the control unit is not reset.
From page 9-33
Error: Poor idling after replacing the engine (EFi only)
Cause: Control unit was not adapted to the new engine
Remedy: Delete preset values using the KTM diagnostics tool (see Chapter 3) and allow engine to run in neutral for 15 minutes
I am going to go out on limb here and suggest that this procedure is to calibrate the airflow sensor, that is all.
ciedema screwed with this post 01-23-2013 at 08:49 PM
Old 01-24-2013, 12:02 AM   #50
Steveman
Steveman's Avatar
Oddometer: 470
Originally Posted by HeatXfer View Post
Here is the above "SOMMER KTM" tip translated to English. I kept the paraphrasing to a minimum; the content is the same (comments are mine).
Many thanks! My English is most probably not good enough to do the job, sorry.
Steve
Steveman is offline   Reply With Quote
Old 01-24-2013, 01:13 PM   #51
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 172
Steve
No no! Don't sell yourself short. Frankly, your post is shorter and more direct; I just posted the translation because a lot of folks were commenting the process was BS.
HeatXfer is offline   Reply With Quote
Old 01-24-2013, 06:11 PM   #52
DirtJack
DirtJack's Avatar
Oddometer: 347
KJ
You can use TuneECU to load maps, edit maps, reset the ECU and preform diagnostic tests and calibrations of various controls and sensors. You really do need to do the 15 minute idle after most of these operations. Otherwise operational data which the ECU retains in flash memory may not be valid for the changes being made. I recommend reading TuneECU thread.
Proud to be supporting Pyndon in the 2013 Dakar !
2007 KTM 990 Adventure
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
1998 KTM 400 RXC (sold)
DirtJack is offline   Reply With Quote
Old 05-22-2013, 01:57 PM   #53
jon6.0
jon6.0's Avatar
Oddometer: 461
I'll toss my two cents in. On my Corvette, you disconnect the battery for a while and it will reset the learned fuel trims in the ECU. Known as long term fuel trims. Each ECU is different and the car/bike learns according to its environment, mods, and fuel used. I can see where disconnecting the battery would do something on the KTM. Obviously the dealer would have a diagnostic tool and wouldn't need to disconnect the battery. I can also see where idling it for 15 minutes may somehow put the ECU into a learn mode. Which would explain why things get better initially. Then as time goes on, the ECU is adjusting itself and things may get back to where they were before. Moral of the story is that without a proper tune for your mods, you may not be satisfied with the 15 minute relearn. I'm about to put Termignoni cans from a 998 on my 990. I'll do the 15 minute relearn and see how I like it. If it has undesirable characteristics I will tune the ECU. Right now I get 38-39mpg and would like to keep that the same or better.
2013 KTM 990 Baja
jon6.0 is offline   Reply With Quote
Old 05-24-2013, 08:18 AM   #54
DirtJack
DirtJack's Avatar
Oddometer: 347
The KTM diagnostic tool (or TuneECU) must be used to do a reset adaptation before doing the 15 minute idle. TuneECU automatically does a reset adaptation when loading a new map. There is no mention of disconnecting the battery before doing a 15 minute idle in the KTM shop manuals. If this was the method of resetting adaptation, owners manuals would likely mention doing the need of doing the 15 minute idle after changing batteries.
2008 KTM 690 Enduro
Times are GMT -7.   It's 01:32 AM.
