Old 01-01-2013, 06:01 PM   #796
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by small_e_900 View Post
Most motorcycle plastic is ABS.
You can repair cracks in a similar manner, but if you take the shavings and put them in a jar of acetone over night, you'll have a paste that will have a longer working time than if you use ABS glue.
Related to that, Christy's, Oatey, and Weld-On each make a black-colored, ABS-filled, medium-body, ABS cement. It sounds a lot like what you're talking about.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 01-02-2013, 05:12 AM   #797
mikesova
mikesova's Avatar
Oddometer: 1,947
I recently acquired a Honda quad that was missing it's starter button. There was a square plastic pin still sticking out, though. I work with kids in an afterschool program and we were taking old keyboards apart a few weeks ago, to use the parts for upcycling into other items. I noticed the keyboard keys might work ok for the job. I hollowed out the inside portion of the key and it slid over the square pin just about perfectly. So, I used some Goop to glue the new button on. I waited 24 hours and boom, it works perfectly. :)
2009 Kawasaki KLX250S
2005 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova is offline   Reply With Quote
Old 01-05-2013, 05:39 PM   #798
duck
duck's Avatar
Oddometer: 10,403
I wire up an Audiovox CCS-100 cruise control to the K1100LT/R1100RT windscreen switch on my K bikes. Waterproof OEM switchgear w/o the need for an add-on control pad.
duck is offline   Reply With Quote
Old 01-15-2013, 04:45 AM   #799
arcanum
Oddometer: 317
Bobcat 853 fuel line repair
The cracked fuel [suction]draw line/check valve on my Bobcat 853 was just impossibly located to remove and re-install with a replacement. The replacement part fits into a 7/16 diameter hole and when installed,expands the rubber parts to fill the non-threaded hole in the tank.
I tried for hours to figure out how to get the old part off and the new part on.The little beastie was located somewhere under the main hydro drive pump in a[ stand-on your head to get at things and no room for your hands or tools ] cluster fock engineering nightmare.
The fuel tank is made from heavy poly like an ag spray tank. Suddenly it hit me... Drilled a new hole in the tank in an accessible location ,ran new fuel line/check valve to the engine, and plugged the old fuel line coming from the original location.
Half hour job once the "right way to do it" was abandoned.
arcanum is offline   Reply With Quote
Old 01-15-2013, 11:50 AM   #800
taosgsr
taosgsr's Avatar
Oddometer: 451
Redneck Spring compressor
From web
See ya at the Pub!!
"don't I have a real dirtbike to do this on?????"
taosgsr is offline   Reply With Quote
Old 01-15-2013, 08:44 PM   #801
grizzzly
The Pre-Banned Version
grizzzly's Avatar
Oddometer: 3,406
Originally Posted by taosgsr View Post
how do you have that camper set up?
any mor pics?
you actually expect people to take responsibility for their actions in today's society?!
grizzzly is offline   Reply With Quote
Old 01-16-2013, 03:57 PM   #802
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,218
any mor pics?
Yeah, I really like the idea of a bulldozer with attached camper.
Go anywhere, make your own damn campsite.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 01-16-2013, 04:44 PM   #803
grizzzly
grizzzly's Avatar
Oddometer: 3,406
I am just thinking that he mounted a camper to his tractor to protect himself from the weather
Old 01-16-2013, 06:33 PM   #804
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,749
the weather... or flying springs
Old 01-17-2013, 06:23 AM   #805
Trixie
No, not that Trixie
Trixie's Avatar
Oddometer: 3,583
Coming home from the airport many years ago in the GF's VW jetta. Headlights just go out, fuses fine, can't find any obvious wiring issues (in the dark) .
Bought a common 110v extension cord at the convenience store, stripped the wires at one end and clamped them to the battery posts. Simply plugged the other end into the backside of one of the headlight connectors. Drove it home 1.5 hrs that way.
Buy my 1150 GS: http://advrider.com/forums showthread.php?t=1049311
Trixie is online now   Reply With Quote
Old 01-23-2013, 09:28 PM   #806
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,228
Wiper arm fell off
The driver side wiper arm fell off my 68 VW camper van while driving to Alaska thru the Yukon... at night in a rain storm. Turned around and drove slowly looking for it. Found it lying in the road unharmed but the set screw was corroded in place (steel vs aluminum).
Sat and thought a while, got a beer can from the garbage and cut a 1/2" wide strip, formed a ring to fit over the wiper stud just below the windshield and hammered the wiper arm back in place. It lasted for the life of the vehicle. Sold it several years later with the wipers still working.
My friend had his wiper motor burn out on a trip, so rigged soda straws in the wing windows and strung braided fishing line thru the straws, tied them to the wiper arms and had a loop to operate the wipers. His high school kid worked the wipers as needed.
Fixed my chainsaw wire with a soda straw.
The insulation had worn/burned off the ignition wire and the saw wouldn't run. Ran the wire thru a short chunk of soda straw to use as insulation. It's still on the 031 Stihl saw many years later. The ignition module is outboard on the side of the saw.
Dave
smilin jack screwed with this post 01-23-2013 at 09:35 PM
smilin jack is offline   Reply With Quote
Old 01-24-2013, 06:11 AM   #807
tgeliot
Topher
Oddometer: 1,359
Beer can shims. Pirsig would be proud.
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 01-24-2013, 08:13 AM   #808
mikesova
mikesova's Avatar
Oddometer: 1,947
2005 Yamaha FZ6
2009 Honda Ruckus
Old 02-08-2013, 08:20 AM   #809
Irish John
Oddometer: 234
Chinese tranny repair
Once while working in China, I repaired the tranny on an old Nissan with a pair of chop sticks. The internal shift mechanism destroyed it self. Pulled the shift boot off and I could see down into the transmission. Used a pair of chop sticks to fish out the broken pieces of the mechanism. We no longer had reverse so you had to be careful where you parked, but we did have 1st and 3rd gear if you held the shift lever in place. We drove it that way for about a week.
Irish John is offline   Reply With Quote
Old 02-09-2013, 11:15 AM   #810
Dastard
Just another guy
Oddometer: 597
Originally Posted by Bob_M View Post
Thats brilliant.
I see what you did there.
DK
S10 (the faster, sexier, more awesome BLACK one). Its like a mustache, with titties!!
Dastard is offline   Reply With Quote
Times are GMT -7.   It's 03:37 PM.
