Old 01-24-2013, 10:25 AM   #1
mung OP
Oddometer: 607
New Raga
Bought a new 12 300 Raga in December.Very pretty bike.Luckily I disassembled the bike before any attempts to start or ride.The hose clamps on the carb to reed block manifold were so tight it split the rubber,The hose clamp on the back of the carb was way over tightened and not on all the way around so it twisted the clamp and tore the rubber boot between carb and air box.The float bowl had a layer of tree sap looking stuff about 20 mm deep and the jets were so plugged I put new ones in.I quit working on it after I found all these problems.I asked the dealer to just assemble so I could take it home to set up.He has nothing to do with the problems.Gas Gas is a very beautiful bike with incredible components but has jack asses and idiots assembling the bikes at the factory.The importer knows about the problems so I will see what happens next.
mung is offline   Reply With Quote
Old 01-24-2013, 11:34 AM   #2
dmay
Oddometer: 256
Maybe because Catalonia is undergoing quite an upheaval right now is having an effect on quality control
http://investmentwatchblog.com/spain...ty-from-spain/
I'd bet they'll make it all good for you.
Doug
2011 Sherco 250 trials,83 Fantic 240 trials,1992 Fantic 309 trials,09 Kawasaki KLX250s,1984 SWM 320TL,03 KTM 640 Adv
dmay is offline   Reply With Quote
Old 01-24-2013, 02:10 PM   #3
Jonny042
Oddometer: 88
Add to your to-do list.....
You'll want to check the float height, too. Both of my bikes they were set a bit high and fuel would leak out, and they tended to stall.
Also, if you're mechanically inclined, it might be worth taking the entire brake system apart to clean it (if it has Formula brakes there are some other things you can do to update them at the same time). It is well established that the rear brake master cylinders are particularly prone to "blowing" seals after a short time. This from crud that isn't cleaned out on assembly, then abrades the cup seal.
Minor issues, don't let them stop you from enjoying that NEW BIKE smell!!!
Jonny042 is offline   Reply With Quote
Old 01-24-2013, 02:15 PM   #4
Jonny042
Oddometer: 88
That's interesting.....
Hey maybe Montesa will declare themselves as a distinct sovereign entity from Honda and start making bikes again!
Old 01-24-2013, 06:36 PM   #5
lineaway
Oddometer: 2,944
First off the dealer is supposed to be setting up the bike! Secondly is this your first spainish bike. It seems I`ve seen your comments before so I doubt it. The intake manifold baffles me as I can`t remember that on a new bike. The gunk in the carb is just old fuel. The inlet to the carb has always sucked! These are minor things! I`ve seen bikes not shift or not run, which is a lot worse. Have you had a pro before? Not being smart, the pro`s quality has always sucked but they sure work good when running.
I checked and saw you had an `04 raga. I thought I`d remembered that! Seems the `04 that my son rides the inlet boot fits better than the newer one`s! Hopefully you have the old bike still so you can steal the master cylinders if need be. Buying a Pro has always been a crap shoot. Either you have a good one or a money pit! Take it you got it from Carlton. Both Gas Gas and Sherco are in a mess with the formula stuff. Check out the top riders bikes, most have stole the Ajp`s off their old bikes!
Hope things work out! Good thing you did go over it good though!
So are you as anal as me? Anti-sieze on every spoke nipple. (Only if I plan on keeping a bike).
lineaway screwed with this post 01-25-2013 at 05:01 AM
lineaway is offline   Reply With Quote
Old 01-25-2013, 07:46 AM   #6
mung OP
Oddometer: 607
First new Bultaco in 69,others in 71,73 and 75,new Gassers in 95,04 and now 12.Disassemble every new bike [maybe 50 ] down to the frame and put together myself.This is the first bike sold by our new dealer so not to pat my back but in this case I have a little more experience than he does.Luckily mine came with AJP stuff. The rear brake line is to short[that is being replaced]so hopefully the brakes will work decent.To even start,the bike would have had to have been disassembled.I know what the substance was in the carb. GG must use burro pee to test start the bikes at the factory because carb cleaner did not even touch this stuff. The dealer should not have to take a bike apart to get it to run.With a bike this specialized and expensive a tiny amount of tlc would have been nice.Actually I bought the bike from a new dealer in Mud Lake,Idaho.
mung screwed with this post 01-25-2013 at 07:51 AM
Old 01-25-2013, 09:15 AM   #7
laser17
Oddometer: 897
All the Raga's come with AJP (braketec) Hydro's. They have had some poor quality control issues that the dealers end up fixing - Like the formula issues on the Std and Race bike last year. (which was worse as its related to the design)
Since Mung is an experienced mechanic - I think I would rather just get the parts and do it myself to make sure everything is done right. I highly recommend checking the masters for burrs when you flush the lines. Have had to hone several.
laser17 is offline   Reply With Quote
Old 01-25-2013, 09:30 AM   #8
lineaway
Oddometer: 2,944
Yes, I figured out `Mung` this morning. I just added to my post than deleting it. Would be a great week to ride in arizona. Smage, Storz, Roper and many others getting some winter practice! Our two top riders are heading over tonight. Wish I was 18 again!
Old 01-25-2013, 11:09 AM   #9
mung OP
Oddometer: 607
My dealer said he would give me all the parts to assemble.I was assuming that the move back to AJP meant that the past problems were taken care of? Where are the "burrs" located ?
Old 01-25-2013, 11:55 AM   #10
laser17
Oddometer: 897
The vent ports in the Master Cylinders have burrs and take out the seal over time. Rear MC had a high fail rate on 1st couple bikes and customers were losing there rear brake. One guy narrowly avoided a bad fall. Fixed after a quick hone and clean and new rebuild kit. Since then, on other bikes, he checks them right away. He told me that since you cant easily see the Burrs, he drags a Q-tip across the port inside the cylinder and if anything snags - he hones it. The honed ones feel perfect - nothing snags.
Old 01-25-2013, 12:24 PM   #11
motojunky
Professional Idiot
motojunky's Avatar
Oddometer: 1,085
Quality Control
Is poor quality control exclusively a GasGas thing? Has it always been that way, or is it a recent development?
I understand that these are minor issues, but I wouldn't want to have to do repair work before even riding my brand new bike. It annoys me enough to have to disassemble and properly grease (with just about any new bike), but disassembling the braking system is too much IMO.
That said, the fact that folks are willing to do it and even defend it speaks volumes about how good the bikes must be when working properly. I'm going to have to give one a try at some point.
motojunky is offline   Reply With Quote
Old 01-25-2013, 01:37 PM   #12
laser17
Oddometer: 897
I think the GG factory in Catalonia has seen some major employee turnover in the last year and as a result, we have been seeing some issues (cost savings??/unskilled labor ??). Typically, these items are all covered by the dealer and Importer in the USA. Sometimes, with veteran buyers/mechanics, the dealer will allow the buyer to handle the issues in return for good faith down the road - this is the exception, not the norm. The dealer Im associated with inspected and repaired all the hydraulic problems after the 1st bike developed problems. He went through 6 all together. He replaced all the rear brake hoses as well. He buys Raga bikes for himself as well - so really gets to know the product and any quality issues. Im sure if Mung wanted his dealer to take the bike back and fix it - he would w/o any issue.
All dirt bikes have problems and issues now and then. I think the bigger issues are the ones associated with the design and cant be fixed with readily available replacement parts. Luckily, thats not the case with the Ragas. (as far as I know anyway)
Regardless - your right - after spending $8k on a bike, you should only be struggling with finding enough time to ride it. The riders who buy Raga bikes do have a passion for them, and in the past, have not sent bikes back. (that I know of ) Again - these are not design issues, so I think that plays into it as well.
Old 02-21-2013, 11:08 AM   #13
mung OP
Oddometer: 607
Ok, things are looking up.Recieved a box of parts from the importer and a longer rear brake hose [Venhill] from a dealer. Waiting for a stiffer rear spring from Jacks and the bike should be able to be put back together.Rear brake bled easily.Now I can at least look at the bike without getting wound up.
Old 02-22-2013, 07:19 AM   #14
Sting32
Trials Evangelist
Oddometer: 1,415
Mung, if you dont mind me asking, what is your weight?
How much is the spring for the reiger?
I weigh 210 (203 on house scale) I have NOT added springs for front forks, nor rear shock. What class you ride now?
I feel like I ride better now without stiff suspension. just wondering how you made your decisions to stiffen things up, thanks.
Sting32 is offline   Reply With Quote
Old 02-22-2013, 08:33 AM   #15
mung OP
Oddometer: 607
I am 250 r2r.Took Stu at Jacks Cycle advice on the spring.7 is stock spring in rear and he tried a 7.5 on his bike and he weighs 220 and thought it was slightly stiff so he thought a 7.5 would be good for me.No fork springs other than stock for front so will try them stock and if I have to I can mess with oil weight and height.Reiger spring is like $160 or so new.Stu had used this one for an hour so it was basically worn out so he gave me a good deal on it.I ride SR intermediate but have not ridden consistantly since about 05.This year I plan to change that.I have the Utah and Wyoming events already marked on my calender.
mung screwed with this post 02-22-2013 at 08:45 AM
Times are GMT -7.   It's 02:12 AM.
