01-24-2013, 04:27 AM
#31 |
Thrifty not cheap
Oddometer: 783
The turbo models are 2.0 vs the 2.5 of the n/a cars. I think the bore diameter difference is why the turbo cars don't poof HG's as readily. The sealing surface between the cylinder and the water/oil passages on a 2.5 is incredibly small.
My local independent Subaru guru uses a HG supplied by, I think, Stars (whoever that is). His view is the OEM gaskets, despite the several revisions, are no assurance of sealing success. He is adamant that he has not had any of his return after he reseals them. I've heard endless stories about the wheel bearings on Subarus but I've never replaced a single one. Axle warping? Never heard of that one. Suspension problems? Nil. I have replaced cam/crank sensors (intermittent no-start problems), a/c compressors (noisy or failing clutches), ignition switch (wore it out), endless broken cup holders...that's about it. I've heard of a lot of coils that develop cracks but never had one.
'04 Wee Strom '89 KLR 650 (sold) KLR Chronicles, list of my Ride Reports in PA/MD: http://www.advrider.com/forums/showt...2#post18782262 |
01-24-2013, 06:38 AM
#32 |
Oddometer: 508
My 08 Outback XT has a 2.5L and a turbo. No HG issues either.
01-24-2013, 09:49 AM
#33 |
With Gusto!
Oddometer: 9,896
FWIW the turbo 2.0 and 2.5 are different blocks than the N/A ones. They don't just slap a turbo on a naturallly aspirated block
01-24-2013, 09:57 AM
#34 |
速
NA 2.5L Subaru's pretty much all have had or will have head gasket issues.
http://allwheeldriveauto.com/subaru-...ems-explained/ ^ All encompassing article They also make THE gasket set to solve the problem http://allwheeldriveauto.com/subaru-parts/ A very good indy subaru mechanic I know in W. Mass also uses them, 2 years ago my buddy bought an 01 Forester off of him that he uses as his winter service vehicle (IT technician) and only paid $4K for the car with 125K on it. I don't think Subarus are an avoid at all costs vehicle because of this "issue", their snow performance is unmatched by anything out there and even an Audi of similar mileage and age will probably encounter more frequent break downs and repairs of higher costs. Also if you were to buy one new and change the coolant ever 30K and/or 3 years you'd probably never encounter a head gasket failure. |
01-24-2013, 10:15 AM
#35 |
Wee-stromer
i don't know that i would call that all encompassing.. they didn't mention any years beyond 2002. 2006+ engines were also altered so head gasket issues are not nearly as common with them. late generation ej motors are the only ones to have really had this problem on a large scale.. i don't think it is fair to say "if you own a subaru, you ARE going to have problems.
01-24-2013, 10:19 AM
#36 | |
Living on a prayer
Oddometer: 6,168
![]() I sold my 97 after disclosing the shake at speed (after spending hours trying to rack it down). I sold it at a discount because of the problem. Her mechanic found the problem(warped axle) after 3 other mechanics (one a dealer) couldn't diagnose it correctly. Her mechanic told me that he replaced 30some each year. The big positive for Subarus, at least new, is the very reasonable price for a full size vehicle and AWD. That being said I've fallen out of love with them and can't look beyond the warts anymore. |
01-24-2013, 10:27 AM
#37 |
Living on a prayer
Oddometer: 6,168
I should also mention that I have a 2002 that has a very noticeable hesitation off idle.
4 mechanics have looked at it, and 2 have replaced sensors with "Known good units" without success. They've all said I could start replacing bigger ticket items or have the fuel injectors replaced/cleaned, but can't gaurantee a result. Nobody can diagnose it. I just accept it and drive "around" it. |
01-24-2013, 01:34 PM
#38 |
Phoneticide Squad
Well, this thread may have saved me some hassle. I was considering a used Subaru , but not now.
If you say "Gullible" slowly it sounds like "Oranges". |
01-24-2013, 01:41 PM
#39 | |
Wee-stromer
YMMV of course. |
01-24-2013, 01:46 PM
#40 |
dirtball
Oddometer: 9,763
I'm looking at 94-2002 Subes right now.
If the hg's, timimg belts and wp's have been done...what else should I look out for? Looking to spend less than 4K if I can.
if you keep poor...the struggle is simple my photos http://jskustoms.smugmug.com/ save yourself some $ with my smuggy discount code qvMaWy1bTFU7c |
01-24-2013, 01:57 PM
#41 | |
Oddometer: 6,262
SOA combined with the horrible dealers soured me on ever going subie again. |
01-24-2013, 02:24 PM
#42 |
The AntiHarley
Location: Bristol Hills in the Fingerlakes region of NY
Oddometer: 2,195
Who was your dealer? I've heard that Van Bortel in Victor NY is great.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149 |
01-24-2013, 02:41 PM
#43 | |
baller
Oddometer: 424
Ducati Hypermotard, Aprilia Futura, Aprilia Falco |
01-24-2013, 02:52 PM
#44 | |
bench adventurer
Oddometer: 3,538
I just got one, it don't need no stinking turbo ![]() Btw, all cars with turbos, regardless of brand, just have more moving parts to break. They tend to not be as reliable as non turbo motors. Even if the turbos no longer go south, all the extra hardware/software can have you frequenting the dealer a bit more than you wish to.
91 Hawk GT |
01-24-2013, 02:57 PM
#45 |
Cashin?
Oddometer: 16,341
All of the other parts. If you can find one that's had all of them replaced too, you'll probably have a pretty good car!
"Bueller, you're an island of sense in a sea of bullshit" - swimmer |
| Thread Tools | |
