Old 01-25-2013, 05:09 AM   #16
Core10metal OP
Core10metal's Avatar
Oddometer: 270
Originally Posted by Drif10 View Post
Sounds like your layers are insulating you from the heated gear.
For me:
In -20: long underwear, then heated gear, then insulated suit over that, done.
Foggy respro in the helmet with a pinlock, fleece tube (Buff) under helmet, over collar. Hippo hands, warm boots.
Tried switching layers and put jacket liner closest to my skin...big difference. Thank you for you and others who suggested it.
Had to tune down thermostat a bit.
As for legs and feet, well, the electric is somehow not getting to pants and socks. I'm actually surprised then that my layers alone kept me as warm as they did. And god bless those Scout boots. Even though feet were freezing, I made it to work/home without too much discomfort which is saying a lot about the boots in -10 and under windchills. So I have to straighten out the faulty connection.
I def want to give hippo hands a try. Putting on heated glove liners then ski gloves is a bit of a pain. The thought of wearing comfortable gloves is very appealing.
Core10metal is offline   Reply With Quote
Old 01-25-2013, 06:10 AM   #17
cliffy109
cliffy109's Avatar
Oddometer: 1,703
I had my coldest commute ever this week. Temp was 8 f. My layering was fine. I have Gerbing pants liners, jacket liner, insoles and gloves. I wore thermal underwear on the bottom with unlined Aerostich Darien pants. On top, I have a BMW Tourance 2 jacket and was toasty warm.
The problem was the helmet. I have a Pinlock that seems to not fit correctly. About half way to work (total commute is 16 miles), the fog filled the inner shield and had frozen. I had to stop at a grocery store and stand inside for 5 minutes to let it thaw. I pushed the inner shield up to make a good seal and continued my ride in with no problems.
Ice on the inside of the helmet is a ride stopper.
cliffy109 is offline   Reply With Quote
Old 01-25-2013, 07:18 AM   #18
spoon
Rubber's gone!
Oddometer: 212
http://warmlite.com/vapor-barrier this is a good read. The tech section on the Stevenson Tent site has some interesting concepts. They also make some good camping gear. Glad to see folks interested in cold weather riding and finding ways to overcome the challenges. Gives you a new outlook on the old timers and the gear they had available to them. A tougher breed for sure.
spoon is offline   Reply With Quote
Old 01-25-2013, 07:20 AM   #19
Ceri JC
UK GSer
Ceri JC's Avatar
Oddometer: 2,462
I found this to be the limiting factor to winter riding too. It's all well and good saying to man up and open the visor, but heavy snow in your eyes at 70mph results in visibility is as bad as a frozen visor. I have taken to carrying a pair of ski goggles with me, when I go out expecting it to get really cold.
Yes, they robs you of peripheral vision.
Yes, they aren't designed for motorcycling.
Yes, they aren't going to protect you from a stone in the face as well as MX goggles can.
Yes, they are illegal in some places as they don't meet the requirements of the "eye protection" standards.
Yes, they are colder than riding with your visor closed
Nevertheless, they are preferable (IE safer) than riding in heavy snow without any visor, they are relatively cheap and their intended application means they deal with snow on the lense and extremely cold temperatures far better than anything designed for motorcycling does.
I would recommend wearing a balaclava under your helmet if going down this route, even if your helmet (with the visor shut) is warm enough for you not to warrant one. Once the visor is up on the highway, it gets very, very cold, particularly on the thin/sensitive skin of your cheeks, just under your eyes.
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back.
Ceri JC is offline   Reply With Quote
Old 01-25-2013, 07:47 AM   #20
Ironfish653
Combat Commuter
Oddometer: 61
The problem was the helmet.....
Yup, same here. My old Caberg flat sucks in cold, it seals the wind out, but there's not enough venting to keep the shield clear w/out leaving it open.
Had an unavoidable ride in 34* rain/snow mix, and discovered that my cheapest stuff actually worked the best:
My $99 Bilt 'Explorer' D/S helmet has a full shield that will close tight over my Oakley ski goggles.
Worn over a Schampa balaclva, to keep my face warm, if i'm moving more than 20mph, it clears almost instantly.
Now, I just need better boots...
Cleverly Disguised as a Responsible Adult
Ironfish653 is offline   Reply With Quote
Old 01-25-2013, 08:10 AM   #21
Turbo Ghost
Oddometer: 223
I used to have a Fog City insert in all my visors. I rode at 15* below 0 Fahrenheit and blew directly on the insert to try to get it to fog and it absolutely would not fog! The downside is they scratch if you blink too hard! Mine got to scratched-up and was interfering with visibility so, I tossed it and haven't replaced it but, work has kept me off the bike more than usual lately so, it's not been an issue.
Turbo Ghost is offline   Reply With Quote
Old 01-26-2013, 02:17 AM   #22
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,919
It's been in the teens the past week or so. It was 9 degrees the other night.
Now the new ride is a naked FZ6, so it's MUCH MUCH colder on that than it used to be on my two wheeled heater, the Concours. On the concours I could ride in a few less layers in these temps and I was just fine.
I've been out every night, sometimes out for a few hrs on the highway. Here are the combinations I have tried over the last few days.
First layer
Rev'IT! compression shirt, I'll look up what model
OR silk shirt
OR outlast long sleeved shirt
Second layer
Outlast long sleeved shirt (only over the silk shirt, too hot w the Rev'IT!)
OR Subzero, level 2 long sleeved turtle neck from BMG (never over the outlast)
[sometimes I may wear a cheap walmart brand compression shirt over the two above to tighten things up a bit]
Third layer, only UNDER 10 degrees AND at night, never over 10 or in the sun.
wool sweater
OR Aerostich Fleece
OR USMC expedition fleece
Jacket
Darien with liner
Pro
-waterproof (but not windproof)
-large pockets allow you to get stuff with gloves on
Cons
-It doesn't feel as windproof as it should be
-The liner (or even without) it "feels" cold.
-raised arour allows cold air to circulate (when not wearing the liner)
Moto Guzzi Grand raid jacket
Pro
-Looks good off the bike
-outlast liner is very thin and warm
-seperate waterproof drop liner is thick, windproof and waterproof
-Armour feels very secure and the jacket gives me a "safer" feeling
-tall, soft fuzzy and cozy collar=very warm neck
Cons
-outer shell doesn't bead water as it used to, but still does better than most
-Can't wear as many turtle necks under it due to the collar. However I only wear one under this particular jacket anyway. (subzero)
- I wish there was a zipper on the end of the sleeves to make putting gloves under them easier, however half of the wrist is stretchy so you can just grab it and pull it over your gloves. This is only an issue with THICK gloves.
Roadgear Oregon Trail jacket
Pro
-Thick leather is very windproof
-Looks great off the bike
-Lots of pockets
-nice tall corduroy collar
-leather outer will insulate better than any nylon\cordura outer layer
Cons
-Not all day rain waterproof
Gloves were a pair of EXO2 heated gloves NOT PLUGGED IN
I alternated between that and a pair of BSX welding gloves
I also have a pair of thick and warm Belstaff insulated gloves, now if I could only remember who I lent them too.....
On my head\face I alternated between
a schampa (thick fleece on the neck, thin part on top of the head).
An Aerostich Wind triangle. I have 3 or 4 different kinds, I wear the fleece one.
I used to wear a cyclone or typhoon buff, but i lent it to someone....and they stole it.
On my legs I alternate between these 3
Olympia Ranger 2 pants with it's liner
Pros -
Warm
waterproof OUTER
liner is slick and insulated and has it's own pockets and can be worn on their own.
Full side zip.
Fit over boots (Gearne Balance Oiled, Aerostich CBT)
Cons -
the liner is made of nylon taffetta. It's slick and slippery which is good, but it is not "warm" feeling against your skin. So it takes a while to be warm. It also will cause you to sweat once you get off the bike or are hanging out inside where someone has turned the heat way up. Thankfully I only ride in these temps to places where I'll be taking my pants off.
Darien pants with TLtec2 fleece pants
Pro -
They look like normal pants, which in these temps is good since I do not need to take off any over pants.
TLtec fleece liner feelse nice, except for the cold zipper touching your bare skin. As well as the hard velcro tabs.
Cons -
I feel like the pants are not as windproof as something with goretex should be.
The thick armour keeps the pants off your skin, causing cold air to circulate. Even Aerostichj tells you to remove the armour in cold weather.....
Without a liner the goretex feels cold against your skin, but then again most people wear these as over pants.
Icon Barrier jeans.
Pro
One pair of pants with 4 layers, FOUR LAYERS.
Layer 1 is 100wt fleece, feels nice and warm as soon as you put em on.
Layer 2 is Kevlar\Aramid in strategic places
Layer 3 is a windproof waterproof layer, not sure what it is but it is a thick rubbery feel to it (I know this because I have another pair that's been torn up working under bikes)
Layer 4 is the denim.
On the outside of the knees is a second layer of denim with another layer of Aramid\Kevlar between the two, which gives you some extra wind protection on your knees.
Cons
No real armour to speak of.
Since the outside layer is denim it will soak and get heavy in the wet. However that is generally not a problem in these temps.
Been trying a few different socks lately.
Wigwam outlast socks - nice, thick cushion, warm, I've worn these for up to a week at a time without them stinking.
North Face outlast socks - These I do not like so much, the material feels cold
Thick wool socks, these I like the best, as evidenced by the big wear holes on the bottom. I sometimes wear these over thin dress shoe outlast socks.
Boots
Usually Gearne Balance Oiled
Pro
-3 clips make putting them on and taking them off a cinch.
- truly waterproof
Cons
- That small velcro tab on top gets caught on my socks or pants all the time, causing wear on those items.
- I feel like I sweat more in these.
sometimes Aerostich CBT lights
Pros
- They look like normal boots (so did the Gearne, until the left toe turned black)
- Waterproof, but not claimed to be
cons
- Not really waterproof, but unless you're standing in a puddle for a while they should be just fine.
- I hate the speed lace crap and all that velcro.
other times my Vendramini Marathon Steels.
Pro
- Lighter and thinner than the two above
- waterproof\windproof
- super comfortable, like an old pair of sneakers
Cons
- May not be as protective as say the Gearne, but that's based on nothing more than the physical size and thickness
- Velcro closure (in addition to two super cool ratcheting closures)
- depending on the pants you wear, the shorter boot might let more wind up your pants.
HaChayalBoded is offline   Reply With Quote
Old 01-26-2013, 01:30 PM   #23
bob393
bob393's Avatar
Oddometer: 389
I'm a year round commuter also and so far this year the coldest has been 1.5 deg F.
I use warm and safe products, all four, gloves jacket, pants, and socks with a two channel wireless remote. On long trips I put that under my stitch two piece suite with a silk belaclave, yeah what are the chances of that being spelled right, under my Nolan helmet with the double face shield, micro pin I think, and except for my glasses fogging up occasionally it works. Plus you can clear your glasses by lifting up on the shield for a moment. I find the belaclave a must because a wind leak on my neck is unacceptable! On the short trips I don't use the full suite. I have Darian jacket with a polar fleece liner and that works but you have to time the trip. Much over a few files and you will get cold. If I'm wearing the socks I use a pair of Icon boots but with out the socks I use heavily insulate winter Wolverine work boots with wool socks and again it seems fine for short to medium trips. I do plug the bike into a battery tender and use 5w-30 synthetic oil and she starts OK, at least she never let me down.
2007 R1200GS almost farkeled to perfection!
bob393 is offline   Reply With Quote
Old 01-26-2013, 01:42 PM   #24
PeterW
Oddometer: 2,664
Originally Posted by bmac View Post
The one suggestion I would make is to change what you do for your legs. The fact that your legs and feet were getting cold is a clear indication that a change is in order.
Hard shell leg protectors work wonders (cheap MX style). They stop the air getting to your legs in the first place, and particularly help around the knees where the airflow is highest and natural insulation the thinnest.
One other comment, heated gear is great, but if the bike stops, the heat stops - so if you are riding somewhere isolated, make sure the gear is good enough to cope without the extra heat input.
Pete
PeterW is online now   Reply With Quote
Old 01-26-2013, 01:52 PM   #25
damurph
Cold Adventurer
damurph's Avatar
Location: The far east of the far east of North America
Oddometer: 1,835
I ride all winter on an old style KLR as my salty beater. Not much wind protection on it so i use long underwear and alot of layers. -13C was my coldest ride last year but have not hit that yet this winter. Heated vest was my only electrics and that malfunctioned last spring so i have to replace it someday. I found if my core was warm i could deal with the extremities. Once my body got cold the bloodflow to my fingers/toes was compromised.
R1150 GSA, KLR650, K75s, RD350, PS250 (Big Ruckus), R65, 990 Spyder
If I still had every dollar I spent on motorbikes I would be a richer man but a poorer person.
damurph is offline   Reply With Quote
Old 01-27-2013, 12:44 AM   #26
pingvin
pingvin's Avatar
Oddometer: 522
What found works:
- Wool base layers, even 2 thin layers on upper body (not too tight second layer). Even wool boxers.
- Smart wool socks
- Held winter gloves
- If very cold (like below 20 fahrenheit), heated vest, soles, gloves
- EDZ inner shell, blocks wind and insulates. Takes no space (really) an make a HUGE difference. Also available as pants. http://www.thermalshop.co.uk/product...__jacket_black
- Textile jacket with thermal liner on top. Textile pants.
- Mostly prefer visor as can adjust opening while riding to avoid fog and less wind in face.
- Breath box and balaclava with wind stopper.
- Ugly giant hand guard extensions...makes a huge difference at speed
2006 KTM 950 SuperEnduro
2010 KTM 530 EXC-R
2006 Suzuki RM-Z 250
1981 Husqvarna 420 AE
pingvin is offline   Reply With Quote
Old 01-27-2013, 01:18 AM   #27
pingvin
pingvin's Avatar
Oddometer: 522
Originally Posted by HaChayalBoded View Post
-Thick leather is very windproof (...)
That is so true, "everyone" think textile is warmer but leather is great when cold. But for winter riding my leather gear isn't roomy enough as want tight fit for safety reasons. But great down to freezing temps.
2010 KTM 530 EXC-R
Old 01-27-2013, 10:17 AM   #28
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,430
I commute throughout the winter here in northeast PA as long as the roads are free of snow/ice. I wear leather overpants and a leather (nonperfed) jacket. I have leather Goretex boots, a Shampa Tall Deck dickie, and Gerbings gloves. I then try to wear a long sleeve shirt underneath of it. This gets me by for my half hour highway commute so far down into the low single digits (Fahrenheit).
The only two things that I feel are necessities in really cold weather are my double-paned helmet visor and heated gloves. This keeps my fingers warm and able to safely use the hand controls, and lets me see without a frosted visor. As long as I've got those two things, I'm good to go for my commute.
My current setup leaves me pretty cold when I get to my destination, but for a half-hour commute, it's fine. If I were to go any further in temps colder than say 20 degrees F, I'd need to figure out something a bit better.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is offline   Reply With Quote
Times are GMT -7.   It's 10:29 PM.
