Old 01-24-2013, 08:34 PM   #6916
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by Baja Dad View Post
I do but I have No tube bender, and besides he owes me !!!!!!
Ah, that works I just buy straight pipe and use a chop saw to make fittings and Tig weld it together.
Just say'IN
crankshaft is offline   Reply With Quote
Old 01-25-2013, 04:15 AM   #6917
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 973
Does it actually requires a rally style exhaust to fit the Evo 2 tanks? I thought it was actually designed to clear the exhaust?
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 01-25-2013, 05:02 AM   #6918
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,176
Jeepers Aaron - You sure found some new love for your 690! I didn't think you liked that bike? I'll get a chance to see it in MX and can hardly wait. I'm driving the truck this year.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 01-25-2013, 07:35 AM   #6919
Baja Dad
Baja Dad's Avatar
Oddometer: 2,021
No the Evo 2 was built to work with the stock exhaust
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 01-25-2013, 08:12 AM   #6920
beaney
rally racer
beaney's Avatar
Oddometer: 124
690 enduro/ rally
350 exc
RALLY-RAIDPRODUCTS.CO.UK
beaney is offline   Reply With Quote
Old 01-25-2013, 08:32 AM   #6921
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,605
Originally Posted by beaney View Post
Beaney is that the 450RR rear tank or the stock tank painted black? I know the 450 RR uses the same tank as the 690 except that the tank is not cut for the fuel pump.
Seth S
Seth S is offline   Reply With Quote
Old 01-25-2013, 08:42 AM   #6922
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
It's amazing what will happen when you can actually ride a bike without having it die randomly. 63 hp at the wheel as opposed to 62 at the crank helps, along with the extra 12ft/lbs I plan on having 8 gallons on board for MX this year, I'll be running the 170 mile stage wihout stopping for fuel The 690 is the perfect bike for the MX1k, longer chassis, big power and lots of fuel.
Just say'IN
Old 01-25-2013, 08:43 AM   #6923
beaney
rally racer
beaney's Avatar
Oddometer: 124
Stock tank painted white
Rally tank above
690 enduro/ rally
350 exc
Old 01-25-2013, 08:59 AM   #6924
LukasM
Oddometer: 5,425
Time for your morning coffee, eh?
Stock 690 tank is already black, the 450 RR tank is bigger and shaped differently, and both have the same cutout (690 has a pump and 450 a plate with a barb there).
Old 01-25-2013, 09:11 AM   #6925
ABuck99
0.0
ABuck99's Avatar
Oddometer: 609
HI-FLO Filter Applications for 012+ 690
Someone was asking last week about oil filter part numbers/options for the 690. I got an email back from Hiflo today, and here are the applications for the new 2012 & up 690 motor:
The 2012 690R uses HF155 & HF651
http://www.hiflofiltro.com/catalogue/filter/HF651
http://www.hiflofiltro.com/catalogue/filter/HF155
These will be available in March.
Until then KTM # for HF651 is 750.38.046.100
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 01-25-2013, 09:20 AM   #6926
beaney
rally racer
beaney's Avatar
Oddometer: 124
Also the threaded inserts are in the tank for the fuel level sensor and the pressure regulator, just needs the holes cutting, the tank bolts straight on but you will need an underslung exhaust pipe
690 enduro/ rally
350 exc
Old 01-25-2013, 09:54 AM   #6927
Seth S
Seth S's Avatar
Oddometer: 4,605
Yes I meant: is that the stock 690 tank painted white or is it a tank from a 450RR. When I was in Australia I took a look at Jaybo's bike and his 450RR tank looked a lot like the 690 tank only it looked like the cutouts for the fuel pump were molded in but not drilled out. The mounting looked the same and the tail plastic also looked the same.
So the real question is: will the 450RR tank bolt onto the 690 if you run a low exhaust?
Seth S
Old 01-25-2013, 10:00 AM   #6928
ktmmitch
Oddometer: 662
Billet Clutch & Brake Levers
New Billet Clutch & Brake levers to suit KTM 690 Enduro,these have been specifically designed for these models by Rally-Raid Products,as the EXC clutch lever,whilst similar looking,will not actuate the clutch switch,so not giving full power.These will be available by end of Feb 2013.
ktmmitch screwed with this post 01-27-2013 at 12:14 AM
ktmmitch is offline   Reply With Quote
Old 01-25-2013, 10:01 AM   #6929
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Thanks for tracking the part numbers and availability down-good info.
modeselector is offline   Reply With Quote
Old 01-25-2013, 10:46 AM   #6930
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,103
Awesome, I've added that to the wiki.
http://ktm690.info/index.php/690_Hal...012_Oil_Filter
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Times are GMT -7.   It's 02:25 AM.
