Old 01-25-2013, 10:20 AM   #6961
beaney
rally racer
beaney's Avatar
Oddometer: 124
Originally Posted by LukasM View Post
Time for your morning coffee, eh?
Stock 690 tank is already black, the 450 RR tank is bigger and shaped differently, and both have the same cutout (690 has a pump and 450 a plate with a barb there).
Also the threaded inserts are in the tank for the fuel level sensor and the pressure regulator, just needs the holes cutting, the tank bolts straight on but you will need an underslung exhaust pipe
690 enduro/ rally
350 exc
RALLY-RAIDPRODUCTS.CO.UK
beaney is offline   Reply With Quote
Old 01-25-2013, 10:54 AM   #6962
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,467
Yes I meant: is that the stock 690 tank painted white or is it a tank from a 450RR. When I was in Australia I took a look at Jaybo's bike and his 450RR tank looked a lot like the 690 tank only it looked like the cutouts for the fuel pump were molded in but not drilled out. The mounting looked the same and the tail plastic also looked the same.
So the real question is: will the 450RR tank bolt onto the 690 if you run a low exhaust?
Seth S
Seth S is offline   Reply With Quote
Old 01-25-2013, 11:00 AM   #6963
ktmmitch
Oddometer: 595
Billet Clutch & Brake Levers
New Billet Clutch & Brake levers to suit KTM 690 Enduro,these have been specifically designed for these models by Rally-Raid Products,as the EXC clutch lever,whilst similar looking,will not actuate the clutch switch,so not giving full power.These will be available by end of Feb 2013.
ktmmitch screwed with this post 01-27-2013 at 01:14 AM
ktmmitch is offline   Reply With Quote
Old 01-25-2013, 11:01 AM   #6964
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Originally Posted by ABuck99 View Post
Someone was asking last week about oil filter part numbers/options for the 690. I got an email back from Hiflo today, and here are the applications for the new 2012 & up 690 motor
Thanks for tracking the part numbers and availability down-good info.
modeselector is offline   Reply With Quote
Old 01-25-2013, 11:46 AM   #6965
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,909
Someone was asking last week about oil filter part numbers/options for the 690. I got an email back from Hiflo today, and here are the applications for the new 2012 & up 690 motor:
The 2012 690R uses HF155 & HF651
http://www.hiflofiltro.com/catalogue/filter/HF651
http://www.hiflofiltro.com/catalogue/filter/HF155
These will be available in March.
Until then KTM # for HF651 is 750.38.046.100
Awesome, I've added that to the wiki.
http://ktm690.info/index.php/690_Hal...012_Oil_Filter
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 01-25-2013, 01:06 PM   #6966
690Emaf10
Oddometer: 68
Originally Posted by ktmmitch View Post
New Billet Clutch & Brake levers to suit KTM 690 Enduro & SMC,these have been specifically designed for these models by Rally-Raid Products,as the EXC clutch lever,whilst similar looking,will not actuate the clutch switch,so not giving full power.These will be available by end of Feb 2013.
Very nice, Do you have pricing information?
690Emaf10 is offline   Reply With Quote
Old 01-25-2013, 02:31 PM   #6967
ktmmitch
Oddometer: 595
Yes,they will be around 90,plus VAT(if in EU)
Old 01-26-2013, 12:35 AM   #6968
BygDaddee
Where do I get a pie
BygDaddee's Avatar
Oddometer: 1,741
690 Tool Tube
Can anyone show me photos of tool tube mounting, can you mount on opposite side to pipe without panniers.
Relax and enjoy the journey, not just the destination.
2013 WR450F(The best bike KTM never built) and BMW F700GS
Pauls Spot Tracker http://share.findmespot.com/shared/f...mgxmQRRUCqrKiY
BygDaddee is offline   Reply With Quote
Old 01-26-2013, 03:00 AM   #6969
Christophe
weekend warrior
Christophe's Avatar
Oddometer: 82
They look great. I have been searching everywhere for shorter and matched clutch and brake levers, but have resorted to sawing the oem levers... these will be on my shopping list when released.
Christophe is offline   Reply With Quote
Old 01-26-2013, 03:47 AM   #6970
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 957
Fookers at Rally Raid are going to ruin me financially
KTM 690 R - "Its just a little crush..."
Bill the Bong screwed with this post 01-26-2013 at 11:44 AM
Bill the Bong is offline   Reply With Quote
Old 01-26-2013, 06:45 AM   #6971
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 266
LED Indicator Relay
Hi all, I fitted some LED indicators, but they don't flash. I'm presuming that I need a new indicator relay?? I've located the relay behind the headlight, but can anyone point me in the right direction in where I can get a suitable LED indicator relay??
Cheers
I'll get me coat..............
Harty is online now   Reply With Quote
Old 01-26-2013, 06:55 AM   #6972
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,914
Cheers
Common problem, most any bike parts store will stock Relays for LED turn signals.
It might be a plug and play-type device or you might have to snip, strip and reattach two wires. None the less it's a very straight forward parts swapout.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is online now   Reply With Quote
Old 01-26-2013, 10:26 AM   #6973
modeselector
Common as muck
Oddometer: 624
Great Mm!
Old 01-26-2013, 03:18 PM   #6974
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 448
Any 690 folks in Florida?
I'm heading down there in March for some offroading and to check out Daytona Supercross.
thorinoakenshield is online now   Reply With Quote
Old 01-26-2013, 11:40 PM   #6975
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,671
Dirty
There are 2 main types that will work. A 2 wire which is a simple swap.. or a 3 wire which you will need to add a ground. pull the current relay and turn the bike on. Check which wire is hot. The other wire goes to the contoles. The relay you get should have a schematic with it. Good luck!
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Times are GMT -7.   It's 09:43 AM.
