Old 01-25-2013, 08:18 AM   #7771
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,248
Originally Posted by Aussie Steve View Post
Got my engine in bits at the moment, and as you do, am looking at the 660 rallye crank.
Anyone know how complete the KTM 'crankshaft complete' is? Is it either end only or as in the picture crank with rod?
Can anyone confirm the rallye crank will go in and can keep both electric and kick start?
You get the whole crank, both halves and the con rod in full assembled form... If you use this longer stroke crank, you may also need the 660 cylinder... To confirm you need to measure the depth of the 660 jug from top to bottom and compare it to the 640 unit, ...
gunnerbuck is offline   Reply With Quote
Old 01-25-2013, 02:05 PM   #7772
ericGSsti
ericGSsti's Avatar
Oddometer: 548
Originally Posted by liferider View Post
Eric, seems to be a good catch, welcome and congrats!
You will love it
For any help you need, check the KTM LC4 (640) Thread Index http://www.advrider.com/forums/showthread.php?t=86958, and also here you can launch a search for whatever you need, it's probably already posted. And if you can't find it... ask it
Welcome.
Thanks very much.
2003 KTM 525 EXC
2004 KTM 950 Adventure S. (GO!!!!!!!!!!!)
IBA membership no.35934
"In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar -
ericGSsti is offline   Reply With Quote
Old 01-25-2013, 02:07 PM   #7773
ericGSsti
ericGSsti's Avatar
Oddometer: 548
The tank is the stock 640A.
According to the graphic design of the tank, the bike should be a '06 or '07 model.
I'm almost sure '07 is the last production year. He must be told wrongly it's a '08.
You are correct it's a 07 but was registered in 08.
2003 KTM 525 EXC
Old 01-25-2013, 02:10 PM   #7774
ericGSsti
ericGSsti's Avatar
Oddometer: 548
Originally Posted by DaddyBigDaddy View Post
The rider in Training stick has to go!
Looks like an 05' to 07' with an SXC tank?
You can see the mounts for the 2nd disc that was removed
It had two dics and calibers but previous owner removed the right side I have the removed ones in a box along with the rear plate hanger, the indicators, the original rims and a few other small parts that he removed.
2003 KTM 525 EXC
Old 01-25-2013, 02:14 PM   #7775
ericGSsti
ericGSsti's Avatar
Oddometer: 548
Originally Posted by hAjPR View Post
Congrats on the purchase! Aren't you worried about your head? The upper edge of the fairing seems to be quite sharp...
I am looking for a different set up. Not quite liking this but the previous owner cut the fairing and adde the carbon fibre sheet.
Hopefully get sorted soon.
2003 KTM 525 EXC
Old 01-25-2013, 03:08 PM   #7776
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
New bike, and many things to do/play with... would you need more than that?
'Long Life to Dirt Riders'
__________________________________________________ _______
Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
liferider is offline   Reply With Quote
Old 01-25-2013, 03:20 PM   #7777
ericGSsti
ericGSsti's Avatar
Oddometer: 548
I'm sure I'll find loads of goodies to start adding to it.
2003 KTM 525 EXC
Old 01-25-2013, 08:00 PM   #7778
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,397
Thanks Gunner,
Havent got a 660 barrel to measure, think though as the parts lists shows both using the same timing chain with 100 links? (think it was 100) and use a different rod that difference in stroke is handled with a shorter rod.
Interested also in any differences in the ends as well as the 660 was electric start on rally only, and kick on smc only.
Aussie Steve is online now   Reply With Quote
Old 01-25-2013, 08:14 PM   #7779
Aussie Steve
Oddometer: 1,397
Thanks Gunner,
Been PMing an inmate who was going to try it years ago. He cant remember why but gave up as it was too hard, thinks casings need machining or something of the like.
Old 01-26-2013, 06:25 AM   #7780
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 162
58530005200 2002 660 rally 102 mm
58330005100 2002 640 adventure 101 mm
I cross referanced the parts at cheap cycle parts diff part # and list stroke 1mm longer
http://www.cheapcycleparts.com/model...32265-cylinder
http://www.cheapcycleparts.com/model...31045-cylinder
640 adventure rack for sale
http://www.advrider.com/forums/showp...1&postcount=23
Gregidy is offline   Reply With Quote
Old 01-26-2013, 10:07 AM   #7781
SFAdventurer
Oddometer: 6
Originally Posted by YetiGS View Post
If anyone has a line on a fairing from one of these, I'd appreciate the info. I'm picking up a 625 that I'm going to convert.
I converted a SXC awhile back and then later picked up a complete 640 ADV. I still have an extra silver tank, silver front/mask,and headlight bracket if you're interested. Also, I fashioned an interesting substitute bracket for the headstock tabs that support the headlight bracket that worked brilliantly The ADV headstock has welded tabs for that purpose which the SXC doesn't. I've been holding on to a 2nd set of headlights which I may let go as well.
Here's the '03 SXC convert
Here's my '02 640 ADV
SFAdventurer screwed with this post 01-26-2013 at 11:40 AM Reason: Learning how to post pics
SFAdventurer is offline   Reply With Quote
Old 01-26-2013, 10:14 AM   #7782
SFAdventurer
Oddometer: 6
Wicked
Oh and the '03 SXC now lives like this.
and like this when I'm attempting to blow it up
SFAdventurer screwed with this post 01-26-2013 at 12:01 PM Reason: learning how to post pics
Old 01-26-2013, 10:25 AM   #7783
TripleThreat719
Track Addict ADV Wannabe
TripleThreat719's Avatar
Oddometer: 290
SFAdventurer,
your images do not show...
On the road less traveled....
.... You always meet more interesting people!
Coming Soon... 2004 BMW R 1150 RT; Gone Soon... 2009 Husqvarna TE 310; Gone, but fondly remembered... 2003 KTM 640 Adventure
TripleThreat719 is offline   Reply With Quote
Old 01-26-2013, 10:30 AM   #7784
SFAdventurer
Oddometer: 6
Thanks Gunner,
When I was researching the difference between the '03 660 Factory Replica Supermoto and my SXC, I saw that the crank bearings were different to fit different journal shafts on each side of the crank of the SXC. I assumed the differences had something to do with a different magneto to support the lights. Maybe it just takes sourcing a different bearing for the right side journal shaft that will also fit the right crankcase halve properly?
SFAdventurer screwed with this post 01-26-2013 at 01:11 PM
Old 01-26-2013, 12:04 PM   #7785
SFAdventurer
Oddometer: 6
Originally Posted by TripleThreat719 View Post
SFAdventurer,
Thanks TripleThreat......I went to school and learned how to post pics here. All corrected.
Times are GMT -7.   It's 05:35 AM.
