Old 01-25-2013, 01:47 PM   #331
mtbdemon
mtbdemon's Avatar
Oddometer: 993
I wonder where a person would find the bags??? I haven't seem a set for sale in a good long while....
I am a leaf on the wind, watch me.....ride (I know, it makes no sense)
2007 YZ 250F SOLD
1998 KTM 620 Adventure
2004 KTM 200 EXC
mtbdemon is offline   Reply With Quote
Old 01-25-2013, 02:27 PM   #332
hondahawkrider
DAMN Rider/Motardian
hondahawkrider's Avatar
Oddometer: 828
Pelican bags work... I have the factory rack, and it came with em...
Here is a pic prior to the rebuild starting
-Jason
DAMN Rider DAMN Rider
Maybe you have to be messed up... before you can step up!
hondahawkrider is offline   Reply With Quote
Old 02-10-2013, 04:32 PM   #333
biensur22
biensur22's Avatar
Oddometer: 179
I posted this in the lc4 index but I thought it might be better here.
I picked up this 98 620 Adv a few months ago and have been waiting for a good opportunity to put this center stand on and swap out the kick stand. In the process of mounting the center stand i noticed a few things, among others that the mounting holes are threaded on the frame. But more significantly, I discovered that I could use both my centerstand and side stand simultaneously. I'm pretty sure this is not supposed to be possible without an aftermarket bracket. This bike has been sitting in a barn for 12 years, pretty sure that wasn't an option. Plus, the side-stand kill switch was in positioned properly for the kick stand bracket. Here:
Another further out:
The real problem I'm having is that I can't find where to put the boomerang thing for the springs. It seems my year didn't include a a mounting post for the center stand springs, but it can accommodate both side and center stands at the same time. I've checked for clearance in all positions (both up, down, etc) and everything functions quite well. I just can't find anything to mount the center stand springs to. Any ideas? I know there's supposed to be a peg with a groove in it, but it simply doesn't exist for the center stand. Instead there's a bolt holding the side stand switch in place.
I had considered a rubber strap akin to those used on the trail bikes, at least that would keep it in place when not in use and I wouldn't need to weld anything. Thoughts?
EDIT:
It seems the '98 620 just didn't include the spring post. I found this old article from CW (on this thread) and it seems they had the same problems as me. Even had to enlarge the mounting holes in the 620's frame. I don't think i'll be welding on a spring-post, instead i'll just use either a rubber strap from the ktm dirt bike kick stands, or a nice-sized velcro one-strap. Since i can fit both the center stand and side stand simultaneously, I can rely on the side stand for daily use and leave the center stand available for maintenance when necessary. WOOHOO!
http://beez.smugmug.com/gallery/7341...rLF9&lb=1&s=X2
Current Rides:1998 KTM 620 Adventure
Past Rides: 1994 KTM 400 EXC WP/D LC4 - Plated; 2001 BMW F650GS Thumper; 1970 CB175; 2003 KLR250
biensur22 screwed with this post 02-13-2013 at 10:37 AM Reason: Found my answer
biensur22 is offline   Reply With Quote
Old 02-13-2013, 10:12 AM   #334
biensur22
biensur22's Avatar
Oddometer: 179
Alright, got a new question for all your 620 fiends. Anyone ever swapped out the plastic side covers for those on the new models? I ask because the airbox is a PITA to access with the current setup, especially with sidebags mounted up. The newer models had the speed-access which broke the LH side cover into two pieces, one that covered the airbox and the other which covered the exhaust. I still have the low-pipes on my '98 but would like to modify my side covers for easier access to the airbox for filter maintenance. ideas?
Old 02-16-2013, 06:30 PM   #335
DaddyBigDaddy
AKA -Evel Kneilson
DaddyBigDaddy's Avatar
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 308
Get
Get a 2004'ish Supermoto tail end... Or adapt
If you send email ill send pix of my mods
620@AspenRacing.com
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy is offline   Reply With Quote
Old 03-02-2013, 01:10 PM   #336
hondahawkrider
Oddometer: 828
Back on the road, Inspected and tagged... Time for painting...
-Jason
Old 03-02-2013, 05:33 PM   #337
Strega
Black is a color
Strega's Avatar
Oddometer: 487
Painting it all black? =)
What road computer you have in there?
-Roger
Bikes: ['09 KTM 690 RR]['98 KTM 620 Adv]['07 WR 450F]['99 YAM R6]
Support: [Where Am I Riding][Dual Sport Moto][C.O.R.E.][Nomadic Racks][Dual Sport Maps]
Strega is offline   Reply With Quote
Old 03-02-2013, 06:48 PM   #338
hondahawkrider
Oddometer: 828
Its the Koso /XR-SR speedo you can see it in this post...
http://www.advrider.com/forums/showp...0&postcount=23
-Jason
Old 03-02-2013, 06:52 PM   #339
Strega
Black is a color
Strega's Avatar
Oddometer: 487
Thanks very much :)
-Roger
Old 03-11-2013, 07:54 PM   #340
hondahawkrider
Oddometer: 828
Fairing help
I'm in the process of trying to clean up the top part of my fairing. This is the dark transparent top part of the fairing that on later bikes is paint matched... Ktm part #58211002000... In looking at it, I think I would prefer a solid color vs the transparent, and maybe a bit taller but not a must. Anyone know of aftermarket screens that would fit, without having to replace the whole setup...
Thanks in advance.
-Jason
Old 03-15-2013, 11:39 AM   #341
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 308
Only
Only way to do it is swap the whole fairing to a one piece unit like the 640A
Ill buy you smoke wind screen if you do swap
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 03-16-2013, 10:12 AM   #342
hondahawkrider
Oddometer: 828
I'll keep that in mind...
This what what I was hoping to find
http://www.advrider.com/forums/showp...62&postcount=2
-Jason
Old 03-28-2013, 08:17 AM   #343
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 308
Panniers
I also have the correct original factory pannier racks for this bike
$225 shipped!
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 03-28-2013, 11:25 AM   #344
DaddyBigDaddy
AKA -Evel Kneilson
Oddometer: 308
Ps
Looking for a 640A dual disc wheel or hub
Email Ken@AspenRacing.com if you have one or know where I can get one
THANKS! DaddyBigDaddy
FOUND ONE! Thanks
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy screwed with this post 03-30-2013 at 09:02 AM
Old 03-28-2013, 05:51 PM   #345
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,772
You know the newer two disc hub is with the larger 26mm axle (for 48mm forks) right?
wrk2surf screwed with this post 03-28-2013 at 05:57 PM
wrk2surf is online now   Reply With Quote
Times are GMT -7.   It's 01:40 PM.
