Old 01-25-2013, 12:30 PM   #1
ozmoses OP
Ride On
ozmoses's Avatar
Oddometer: 1,149
Tranny fluid & filter change
GMC Savana.
Is this a DIY or no? Tricks, tips?
Not talking a flush & fill, just drain, drop pan, filter change & refill.
Always driven a stick...
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 01-25-2013, 01:03 PM   #2
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 2,943
Originally Posted by ozmoses View Post
GMC Savana.
Automatic trannys in general; most have a screen NOT a filter. Draining does not take into account the large volume of fluid in the torque converter. That's where the flush comes in. Take it to a quick lube joint, saves you the mess and disposal of the used fluid.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 01-25-2013, 01:04 PM   #3
troidus
Oddometer: 7,190
Make sure you have the tools to reach every pan bolt before you get started, plus have the filter, gasket, and fluid in hand. If the anti-drainback valve for the torque converter leaks, you'll dump more fluid than it says you will in the manual, so be prepared for that, too.
If the crossmember is in the way, have some way to support the tailhousing when you unbolt the crossmember to move it, and make sure you have room to move it without disturbing your temporary support. Unclip the wiring harness so if the tranny slips off the temporary support it doesn't yank the connectors off.
If the tranny is a 700-R4, note that there is a ridged silicone seal on the intake pipe on the filter and it can stay in the tranny when the filter is removed. You may have to reach up in the hole with something to catch and pull the seal out before seating the new filter. 4L60/80 trannys may be similar.
Mind your bolt torque and pattern when putting the pan back on. Tranny fluid leaks suck.
troidus is online now   Reply With Quote
Old 01-25-2013, 01:55 PM   #4
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 713
I recently changed out the filter and all fluid in a Chevy 3500 Express van.
I pushed a bucket under front, disconnected a trans line to the radiator and started
the truck. As soon at the fluid started to sputter, I shut off the truck and removed
the pan; washed out pan, installed new filter, poured in about the same quantity of new
ATF that had been pumped into the bucket (about 4-5 quarts)
Then I started the truck, shutting it off again as soon as fluid starts to sputter into the bucket.
Then I reconnected the line and refilled the trans. This changed all the oil in the trans,
about 2-1/2 gallons.
CycleDoc59 is offline   Reply With Quote
Old 01-25-2013, 02:07 PM   #5
troidus
Oddometer: 7,190
When I flushed my Camry trans, I started with a filter change and pan wash (cleaning the metal shavings from the magnets), then disconnected the cooler return line and piped that to a bucket. I then uncapped 12 quarts of fluid, started the engine, and poured in fresh fluid as the old fluid ran into the bucket. I made sure to cycle the gear selector a couple of times while doing this. As I got near the end, I shut the engine off, reconnected the cooler line, and topped off the fluid level.
Old 01-25-2013, 02:47 PM   #6
ozmoses OP
Ride On
ozmoses's Avatar
Oddometer: 1,149
Reason I ask- went to a transmission repair shop who recommended not to flush with 160k miles, only pan-filter-fluid.
Stopped at a quick-lube joint who advised that they only flush & refill but do not drop pan or change filter.
So??
I like the idea of disconnecting a return line and flushing that way. Anything to damage w/ this method by running it dry, for example? Is there a need to bleed the system afterwards ?
ozmoses screwed with this post 01-25-2013 at 03:05 PM
Old 01-25-2013, 02:52 PM   #7
troidus
Oddometer: 7,190
Don't let it run dry or you can damage the bearings. If you see foam in the output, shut down the engine until you can get the pan refilled. Using a clear line from the cooler return to the bucket will help with this.
The lubrication system is not sealed, so it will bleed air on its own.
Old 01-25-2013, 03:30 PM   #8
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 6,430
Thumbs down
It was a PITA on the GMC Jimmy. There is a crossmember that has to be removed just to get the pan off.
"Tough times don't last, but tough people do." Robert A. Schuler
D.T. is offline   Reply With Quote
Old 01-25-2013, 05:22 PM   #9
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 372
The last time I changed the transmission fluid in my Sierra 1500 truck automatic transmission, I siphoned the fluid out using clear tubing pushed down the dip stick tube. The end of the tube was put in a one gallon jug and left for several hours. I didn't change the screen. I don't like getting transmission fluid all over me anymore.
Edit: For the automatic transmissions I have worked on, I never saw a screen clogged and the mesh is not fine. Some transmissions may have have a different 'filter' though. The ATF fluid is high detergent which carries contaminants, so it is good to replace the fluid.
Stan_R80/7 screwed with this post 01-26-2013 at 06:09 AM
Stan_R80/7 is offline   Reply With Quote
Old 01-26-2013, 05:15 AM   #10
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 713
So??
No, there's no problem if you shut off engine as soon as the fluid starts to sputter; that means fluid is now
below the pan pickup. It only takes a few seconds, so it's best to watch while someone else runs the
engine. You are only doing what the transmission is constantly doing all the time; circulating oil throughout
the trans and cooler, only you are replacing the old fluid with new. Changing the oil without removing/cleaning
out the pan and changing the filter is foolish since a clogged filter can quickly starve the pump and damage
the trans. No matter if it's a fabric filter or a mesh screen, they still clog....there is no by-pass as there is
for engine filters.
I have changed the oil/filter in an '05 Grand Carravan which now shows 320K miles on same trans w/no trans
problems.....
Old 01-26-2013, 08:15 AM   #11
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 6,141
+1, just did this on a Mustang and the Chevy. I usually pour fresh fluid in while it's running and pumping out to push any old fluid out. As the poster mentioned, once it sputters, turn engine off, reconnect the line, add a few quarts, run and top off. Of course, make sure which line is which so you don't have a big mess on startup. damhik.
I used to be indecisive. Now I'm not so sure.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 02-02-2013, 08:31 PM   #12
rabbitears
Oddometer: 26
The flush v pan-drop debate is probably only slightly less contentious than the ownership of Jerusalem, and certainly more debated online. ;) There is a theory which circulates widely (but I have no idea whether it's true) that: flushing a transmission will "stir up" all sorts of filings and other nastiness, forcing them from their current quiet resting place back into circulation where they can do damage and cause further problems. Flushing necessarily means that you're not cleaning the filter/screen and removing any metal filings. On the other hand, flushing can be done just by disconnecting two hoses and hooking the car up to a (mostly?) automatic machine, so it's attractive to quick lube franchises who often don't have highly trained mechanics.
Whether any of the above is true, I have no idea - but that's the version I read a hundred times when I was researching this myself a couple years ago. For my own part, I have a pretty basic mechanical knowledge and less experience but even I was able to (slowly) drop pan etc without too much difficulty. It's not very tricky. I didn't, however, go to any effort trying to drain the rest of the system beyond removing the pan - I was happy enough replacing a large percentage of the ATF and wasn't going to worry about the rest.
rabbitears is offline   Reply With Quote
Old 02-02-2013, 09:13 PM   #13
troidus
Oddometer: 7,190
I think it's an and, not an or. Drop the pan, clean the magnets, install a new strainer, fill with fresh, then immediately disconnect the cooler return and pump out the rest of the old fluid while adding new. Anything that gets dislodged ends up in the bucket. It's the best of both worlds. No quicklube place is going to do it, and the dealer will charge a fortune, so just do it at home.
Old 02-03-2013, 04:34 AM   #14
concours
WFO for 41 years
concours's Avatar
Oddometer: 4,015
LOL +1 The 8.1L/4L80E in my 2500 'Burban had shift cable bracketry and 3" exhaust snaking UNDER the pan. The perverted CAD designed needs his balls cut off. I have most every widget on the Snap-On truck and it still was a ball buster. YMMV
2007 Tiger 1050
2005 Royal Star Tour DeLuxe
1973 Yamaha TX750
1974 Norton 850 Commando Roadster
Old 02-03-2013, 05:47 AM   #15
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 713
That actually works well; if you change what's available in the pan two/three times, virtually all the
oil will be changed since it mixes. This can be done w/out dropping pan (after the filter has been changed
the first time) by using a vacuum pump. Same technique works for changing brake fluid by changing the
fluid in the master cylinder several times over several months. No, it's not as good as a flush-out, but is
still quite effective....
The reverse is a bad idea; flushing w/out changing the filter. Because, as you say, old previously stuck-on debris
can be washed into the filter, plugging it up fairly quickly.
Times are GMT -7.   It's 10:32 PM.
