Old 01-24-2013, 09:50 AM   #7141
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,334
990 Improvements:
For cold weather, wrapped my clutch lever with shrink wrap:
When I installed the throttle lock, my cut down brake lever was moved too far over. It was a 1 1/2 finger position. I banged some 1/2" aluminum tube into an oval, did a little grinding on the lever, and banged the extension in place with copious amounts of JB weld. The works were then shrink wrapped. I now have an extra long lever that can be used with 2-4 fingers. It should dramatically improve my braking power.
Only remaining work: Foot peg extensions and Oberon clutch slave cylinder.
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 01-24-2013, 02:32 PM   #7142
CharlieFox
Oddometer: 195
Damn Jdeks! Thats a hell of a day!!
[QUOTE=Jdeks;20561900]What did I do to my KTM today? What didn'tI do to my KTM today !!
CharlieFox is offline   Reply With Quote
Old 01-24-2013, 05:29 PM   #7143
Jdeks
Departed
Oddometer: 966
Yeah, I did my valves and a fluids change too....okay well that took more like another day.
Peanuts, I didn't change that - this is actually the first I've heard of it, and I've gone through the HOW in great depth. My bike's an 04 950 Adv - is it something I should be worried about?
Originally Posted by Peanuts View Post
Did you change the locking lever for the improved, solid wheel design?
Part Number: 60034024144
Description: LOCKING LEVER CPL.
Retail: $9.39
Your Price: $7.98 (15% discount)
Jdeks is offline   Reply With Quote
Old 01-25-2013, 05:21 AM   #7144
R&R4adv
R&R4adv's Avatar
Oddometer: 334
remote mode switch
Hi after installing HID lights my pass switch seamed useless as HID high beam take a bit to warm up so i ran two wires from the trip master plug behind the head light ( found colour code for the wires on this site after a search) and soldered them into the pass switch. i can now scroll through the modes hands never leaving the bars.
R&R4adv aka Reon
04 950 Adventure
past bikes
04 950 Adventure 03 640 Adventure 99 XR400
R&R4adv screwed with this post 01-25-2013 at 02:27 PM
R&R4adv is offline   Reply With Quote
Old 01-25-2013, 06:17 AM   #7145
go2cnavy
go2cnavy's Avatar
Oddometer: 520
:clap
Well done. Can you post a link to the color codes?
╭∩╮(-_-)╭∩╮
990A / 450 EXC R/ 250 EXC/ 450R - for sale
go2cnavy is offline   Reply With Quote
Old 01-25-2013, 08:09 AM   #7146
EZ300
EZ300's Avatar
Oddometer: 1,042
-Installed a zip-ty axle pull
-Repaired one of the latches on my luggage.
-Ordered a Fuzeblock & wiring kit
-Made a deal on some FMF can for my ADV
-Picked up a spare clutch slave cylinder
-Picked up a new heidenau K60
-Installed new galfer black pad on the rear
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 is offline   Reply With Quote
Old 01-25-2013, 10:23 AM   #7147
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,334
Please elaborate.
BTW, the longer front brake lever has make a huge difference on my 990. I found the front brakes somewhat marginal. Better pads would probably help. I should give the rotors a quick sanding as well.
Old 01-25-2013, 12:27 PM   #7148
Brokein2
Oddometer: 177
Got one on order...
http://www.touratech-usa.com/Store/2...y-ZipTy-Racing
Craig A.
'09 990 ADV
'11 R1200RT
'14 R1200GS
Brokein2 is offline   Reply With Quote
Old 01-25-2013, 01:19 PM   #7149
EZ300
EZ300's Avatar
Oddometer: 1,042
Originally Posted by HellSickle View Post
Please elaborate.
No more fighting to get the front axle out!
EZ
AMRA
www.rockstarsmc.com
Old 01-25-2013, 02:27 PM   #7150
R&R4adv
R&R4adv's Avatar
Oddometer: 334
remote mode swicth
Here you go
Brown- all road book controls get switched to this to operate
Yellow/Brown= scroll mode functions
Green/Red = Increase miles in trip meter
Yellow= Lower miles in trip meter
R&R4adv aka Reon
04 950 Adventure
past bikes
Old 01-25-2013, 03:16 PM   #7151
Peanuts
Peanuts's Avatar
Oddometer: 1,605
Yes, the balls come out of the bearing and cause damage to the primary gear, clutch and gearbox.
Well documented on smaller KTM forums, but just as bigger threat to the LC8 engine, hence the factory doing the upgraded part.
Peanuts is offline   Reply With Quote
Old 01-25-2013, 05:49 PM   #7152
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,392
my K.I.S.S. approach to gear hauling. made a cheap base plate to mount all my camping gear. really happy with the results. cost me $12 and allows enough room for a passenger, plus is a solid mount and prevents stuff from sliding around. the whole bundle comes right off together and the base plate can be removed quickly so you can strip down to fun mode without worrying. can open and close both paniers without removing any gear either. originally did it without the base plate but was worried about the heat. this definitely solves that problem.
these are the things i do when i'm home sick with the flu...
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 01-25-2013, 05:58 PM   #7153
go2cnavy
go2cnavy's Avatar
Oddometer: 520
It's been a busy week and I am looking forward to the weekend. A wave of shipments arrived and I've spent more time with the UPS driver than my kids this week...
New arrivals (pics to follow after install)
- CJ Designs Tail Rack
- Rotopax 1 gal fuel and H2O cans
- New Pelican 1400
- Wolfman Expedition Dry Bags
- 690 Enduro Fender and 2010 690 SMC fork protectors (supposed to be a direct bolt on says this guy...we'll see)
Follow-up... 690 SMC fork guards are NOT a direct bolt on. Right side - two holes (one side and one front line up which allow for a secure mount. Left side - same holes line up, but had to do some trimming of the fork guard around the speedo/abs sensor. I also swapped the stock fender for a high fender. Had to shim the rear bolts with a washer to provide some clearance between the rear of the fender and radiator. Then I installed some ROX risers and mounted my GPS in the center.
BEFORE
AFTER
╭∩╮(-_-)╭∩╮
Old 01-26-2013, 07:56 PM   #7154
EZ300
EZ300's Avatar
Oddometer: 1,042
Mounted up a fuzeblock for accessories.
EZ
AMRA
www.rockstarsmc.com
Old 01-27-2013, 09:34 AM   #7155
Orangecicle
Orangecicle's Avatar
Oddometer: 2,570
Pelican Panniers
Getting a little closer on my Pelican pannier work. 3M Scotchlite on the outside, vinyl case liners on the inside (about 50% complete). Mounts are in the works, and weather sealed cam locks should be here next week. Getting closer every day.
Orangecicle is online now   Reply With Quote
Times are GMT -7.   It's 04:24 PM.
