Old 01-25-2013, 02:16 PM   #7171
Peanuts
Peanuts's Avatar
Oddometer: 1,032
Originally Posted by Jdeks View Post
Yeah, I did my valves and a fluids change too....okay well that took more like another day.
Peanuts, I didn't change that - this is actually the first I've heard of it, and I've gone through the HOW in great depth. My bike's an 04 950 Adv - is it something I should be worried about?
Yes, the balls come out of the bearing and cause damage to the primary gear, clutch and gearbox.
Well documented on smaller KTM forums, but just as bigger threat to the LC8 engine, hence the factory doing the upgraded part.
Peanuts is offline   Reply With Quote
Old 01-25-2013, 04:49 PM   #7172
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,059
my K.I.S.S. approach to gear hauling. made a cheap base plate to mount all my camping gear. really happy with the results. cost me $12 and allows enough room for a passenger, plus is a solid mount and prevents stuff from sliding around. the whole bundle comes right off together and the base plate can be removed quickly so you can strip down to fun mode without worrying. can open and close both paniers without removing any gear either. originally did it without the base plate but was worried about the heat. this definitely solves that problem.
these are the things i do when i'm home sick with the flu...
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 01-25-2013, 04:58 PM   #7173
go2cnavy
go2cnavy's Avatar
Oddometer: 285
Originally Posted by go2cnavy View Post
It's been a busy week and I am looking forward to the weekend. A wave of shipments arrived and I've spent more time with the UPS driver than my kids this week...
New arrivals (pics to follow after install)
- CJ Designs Tail Rack
- Rotopax 1 gal fuel and H2O cans
- New Pelican 1400
- Wolfman Expedition Dry Bags
- 690 Enduro Fender and 2010 690 SMC fork protectors (supposed to be a direct bolt on says this guy...we'll see)
Follow-up... 690 SMC fork guards are NOT a direct bolt on. Right side - two holes (one side and one front line up which allow for a secure mount. Left side - same holes line up, but had to do some trimming of the fork guard around the speedo/abs sensor. I also swapped the stock fender for a high fender. Had to shim the rear bolts with a washer to provide some clearance between the rear of the fender and radiator. Then I installed some ROX risers and mounted my GPS in the center.
BEFORE
AFTER
Current Stable
- 2007 990A
- 2005 CRF450R - plated
- 1992 250 EXC
go2cnavy is offline   Reply With Quote
Old 01-26-2013, 06:56 PM   #7174
EZ300
EZ300's Avatar
Oddometer: 518
Mounted up a fuzeblock for accessories.
EZ
AMRA
2007 KTM 990 Adventure
2008 KTM 300 XCW
www.rockstarsmc.com
EZ300 is online now   Reply With Quote
Old 01-27-2013, 08:34 AM   #7175
Orangecicle
Orangecicle's Avatar
Oddometer: 1,085
Pelican Panniers
Getting a little closer on my Pelican pannier work. 3M Scotchlite on the outside, vinyl case liners on the inside (about 50% complete). Mounts are in the works, and weather sealed cam locks should be here next week. Getting closer every day.
Orangecicle is offline   Reply With Quote
Old 01-27-2013, 11:39 AM   #7176
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 502
Do you have a picture without the gear on it?
laramie
Dr350, XR650R Dual Sport,XR600R,KTM ADV990R
BigNastybrp is offline   Reply With Quote
Old 01-27-2013, 06:36 PM   #7177
go2cnavy
go2cnavy's Avatar
Oddometer: 285
Twisted Throttle light mounts
I've had a couple of questions about the mounts for my lights. So hopefully this will help.
The lights are from twisted throttle
http://www.twistedthrottle.com/denal...-and-m10-mount
You can choose the style of mount from the table. I used the 6mm fender mount and mounted them to the upper fairing bolt instead of the fender.
http://www.twistedthrottle.com/denal...pbjfpe2c17jq71
Here is a close up of the mount.
[/QUOTE][/QUOTE]
Current Stable
- 2007 990A
- 1992 250 EXC
Old 01-27-2013, 06:44 PM   #7178
dave6253
ad-ven-cher-uhs
dave6253's Avatar
Oddometer: 2,538
Let's see if I can remember all that I've done to her in the past 2 days.
Powerwashed the Dalton Highway Mud from underneath everything.
New Oil & Filter
New Sparkplugs
New Rear Brake Pads
Bled Rear Brakes
New Chain & Sprockets
New Chain Slider
New Sharkfins
New Chain Guard
New Oberon Clutch Slave Cylinder & Base
Bled Clutch
Cleaned & Oiled Air Filters
Re-painted Front Fender & Glove Box
Installed Fuel Filter Kit
Struggled to get the Safaris Back On
Put Everything Back Together
Went for a Ride...
...In the Rain.
dave6253 is offline   Reply With Quote
Old 01-27-2013, 07:27 PM   #7179
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,165
Well done!
2011 White 990 Adv R
2003 565exc
FakeName is offline   Reply With Quote
Old 01-27-2013, 08:55 PM   #7180
EZ300
EZ300's Avatar
Oddometer: 518
Mounted up my "New to me" FMF pipes!
Stock can on the left, New FMF on the right.
EZ
AMRA
2008 KTM 300 XCW
www.rockstarsmc.com
EZ300 screwed with this post 01-27-2013 at 09:00 PM
Old 01-27-2013, 10:02 PM   #7181
joneswgareth
Welsh Rarebit
joneswgareth's Avatar
Oddometer: 187
Did you fire her up when she was like this??!!!!
950 SE
joneswgareth is offline   Reply With Quote
Old 01-28-2013, 07:49 AM   #7182
EZ300
EZ300's Avatar
Oddometer: 518
Much to the displeasure of my wife I did fire the bike up.
Incredibly loud and I felt like a REAL man!
EZ
AMRA
2008 KTM 300 XCW
www.rockstarsmc.com
Old 01-28-2013, 08:15 AM   #7183
henryroten
Oddometer: 174
What is your opinion of the FMF's?
henryroten is offline   Reply With Quote
Old 01-28-2013, 09:09 AM   #7184
Geek
oot & aboot
Geek's Avatar
Oddometer: 25,819
www.motogeek.com
Old 01-28-2013, 09:38 AM   #7185
EZ300
EZ300's Avatar
Oddometer: 518
Just took it for a ride and it was nice. Sound is deep an throaty. Won't be able to tell performance until I put a couple hundred miles on it.
EZ
AMRA
2008 KTM 300 XCW
www.rockstarsmc.com
EZ300 screwed with this post 01-28-2013 at 04:13 PM
Times are GMT -7.   It's 08:53 PM.
