Old 01-24-2013, 04:41 PM   #3031
jeepinbanditrider
KK6RBI
jeepinbanditrider's Avatar
Oddometer: 1,262
looks like those square units would be great headlight replacements
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 01-24-2013, 05:39 PM   #3032
battlecattle
Oddometer: 271
Originally Posted by sanjoh View Post
The 30, 44 and 60 all use the same housing and mount system, the internals are the only difference.
I meant light output.. in the same field as the new ones. Sorry for being unclear.
http://www.batlecatle.com/
CRF250L Service Manual
2014 KTM 690 Enduro
2014 CRF250L - Totaled
battlecattle is offline   Reply With Quote
Old 01-25-2013, 07:54 AM   #3033
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,217
Great idea!
Coming soon.
Old 01-26-2013, 08:16 AM   #3034
knightbiker63
JK
Oddometer: 1
Question Decision time
Ok...I have read all 203 threads and am now convinced these are the lights I have been looking for. My question for anyone out there is this... I drive my Vstrom 650 65 miles back and forth to work on interstate highway from Rhode Island to Boston, Mass. (mostly highway...some backroads when time permits or traffic is too heavy.), I am torn between two Model 44 or two Model 60 lights...I want to run them day AND night but not blind other drivers. Your dimmable on low-beam and full power on high beam is just what I am looking for also. I do plan some fun rides in VT / NH this summer. Either would improve my drive home at night but I have always felt you can never have too much light when there are deer/coyotes/moose ready to dart in front of you. My off-road use is limited. I guess I am asking for opinions from previous buyers in the same situation. Thanks in advance for all input.
knightbiker63 is offline   Reply With Quote
Old 01-26-2013, 09:07 AM   #3035
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,075
Dont worry, you'll wonder why you waited so long after you see what you have not seen. Just look through this thread and see how many folks are unhappy with these lights.......very few complaints compared to of a whole bunch of "hell yes these are great lights" comments....
pfdskipper is offline   Reply With Quote
Old 01-26-2013, 05:51 PM   #3036
Ned Kelly
Oddometer: 27
Is there a way to get a static camera shot that shows every light you offer? You did it with the new ones 61, 62, 64 but the 30, 44, 60 have no comparison.
Good idea. Would it be possible to put some object in the pictures as well? .... such as a human, motorcycle, or something common so viewers have an object for reference for judging the beams of the various lights? It would help us determine which lights would fit our needs.
Ned Kelly is offline   Reply With Quote
Old 01-27-2013, 02:33 AM   #3037
dljocky
Oddometer: 865
I'm not mechanical at all, but I know I need some AUX lights for my DR650. I'm confused as to how they hook up? Is there a way that I can hook them up so that the AUX lights, when turned on, stay on whether or not I'm running low or high beams? Does one need the "dimmer" switch? Does this dimmer work like the dimmer switch in a car, or is there something else to it, ie, like a dimmer switch a person migh put on their wall switch for a dinning room light?
I was thinking of the getting the Model 30, but since the M61 has come out, I'm now thinking about this. I wonder if I would need a dimmer with the M61's as they put out less light? I'm trying to keep the cost down, while just increasing my night time safety. When I'm riding with my DR650 lights on bright, I almost have sufficient light, so I'm thinking just a bit more and I would be good. Thanks all.
dljocky is offline   Reply With Quote
Old 01-27-2013, 06:46 AM   #3038
michigan400
Oddometer: 103
You can hook them up to work any way you prefer. You would only need a off/on switch of some kind if you want them seperate from main headlight. The dimmer would simply reduce power to the lights,, dimming them in increments. You would pick a setting for dim, and then you switch to high beam they go to full power.
I have a set of m61's coming now and also a model 30 that I've had for a while. I know the 30 is 1500 raw lumen and the 61 is only 900 but due to the much larger single reflector I expect the single 61 will be equal to or greater than a single 30 in terms of useable light. Maybe sanjoh can comment on that better than me. Just my 2 cents.
michigan400 is offline   Reply With Quote
Old 01-27-2013, 08:33 AM   #3039
rollinrob
rollinrob's Avatar
Oddometer: 1,626
Want to put some model 30's or model 44's on my Bandit 1250, probably mount on the holes that the fork mounted reflectors use, like the picture of a model 30 on the web page..
My question is can the light be rotated/clocked in the housing to keep the proper top/bottom orientation of the light beam/spread? Are there any pictures of a light with the yellow Xpel protection?
rollinrob is offline   Reply With Quote
Old 01-27-2013, 08:45 AM   #3040
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,157
Yes the light housing can be clocked in relationship to the mounting bracket, but the beam is round with no top/bottom/side, so it only affects how the face looks when its off and you are looking into it!
Low594 is offline   Reply With Quote
Old 01-27-2013, 10:59 AM   #3041
SiBC
Oddometer: 19
I am really looking forward to seeing more pictures and reading more info. Really interested in some comments on the effective range of the three new lights. Also, are the new lights compatible with the crash bar mounts, and are there any lens protection for the new light in the works.
I have read the whole thread and waited patiently for the new sets of lights. I am in need of a set of aux lights to help out my poor stock light throughout the range (low-high), and can't decide what's the best setup. Maybe a combo of one Model 60 and one Model 64? Maximum light output is what I want, as far as possible down the road, but also right infront of me.
SiBC is offline   Reply With Quote
Old 01-27-2013, 01:09 PM   #3042
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,326
You'll get more light from the 60's on high beam. With a dimmer you can get the same amount of light for low beam usage from either light and not offend oncoming drivers, just have to dim the 60's a bit more. I went with this setup with 44's for my new-to-me bike because I like the way it works on my sidecar rig. The dimmed floods light the side of the road in a manner similar to the fog lights on my Camry. Iv'e not been flashed by an oncoming driver in 5000 miles.
High beam lights everything!
As for service, I ordered at O-dark thirty on thursday morning and had them in my mailbox saturday, thanks John.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 01-27-2013, 06:34 PM   #3043
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
You can wire them however you want. Think about how you want to use them and post here or wire them up accordingly. The dimmer works on the lights,so your closest example given would be the dining room lights.
I'm running 3 lights, 2 30's and a 60. Not all at the same time though. My Dr650 is still running the stock stator and only puts out 200w. Running 120w of aftermarket lights sucks the batt down a bit. I used the 30s for corners and the 60 for an additional headlight. I mounted the 60 on a plate that hooked up on the fork mounts and on the lower bolt for the headlight cover. It sits just below the headlight now,does a great job too. The 30s are right by the reflectors. I just added a hole to the metal tabs and they did ok. I'd like to upgrade those or maybe move them while I have the front end off for a revalve/spring job.
Danjal is offline   Reply With Quote
Old 01-27-2013, 08:00 PM   #3044
20Fingers
MCarrera GS-Giants
20Fingers's Avatar
Oddometer: 139
Excellent!
Need to know what mounting hardware for my 2012 F650GS Special Edition....Want to run them from my turn signal mounts...any suggestions for installing a pair of Model 60's???
A dedicated rider in central Maine. I offer tour and ride support to anyone traveling through, mapping help online, Q&A by email, just about anything adventure riding and camping related!
20Fingers is offline   Reply With Quote
Old 01-28-2013, 12:49 AM   #3045
an13
Oddometer: 40
What is the weight of these M61, M62 and M64 lights? They look quite sturdy but are they heavy?
an13 is offline   Reply With Quote
Times are GMT -7.   It's 01:14 AM.
