Old 01-26-2013, 01:55 AM   #1
flexfoot OP
Oddometer: 211
R90/6 engine issues
1974 R90/6 with 140k miles. Needs timing chain replacement in addition to valve/cylinder work. I sent the heads and cylinders to Randy Long. He can repair the heads OK, but the cylinder and pistons are out of spec. First over size pistons are $365. each..... Cylinders need boring also. I was thinking that spending nearing $800.00 for pistons is not an option.
Any thoughts? i was considering a 1000cc kit for $1200. Does that make sense? Thanks in advanced for your wisdom!
Steve
74 R90/6 side car
09 F650GS Twin
flexfoot is offline   Reply With Quote
Old 01-26-2013, 07:33 AM   #2
jackd
Oddometer: 3,070
Maybe this would get more responses if you put it in 'Airheads'.
Old 01-26-2013, 12:57 PM   #3
flexfoot OP
Oddometer: 211
R90/6 engine issues
Thanks for the tip!!
steve
Times are GMT -7.   It's 10:05 AM.
