Old 01-10-2013, 06:17 AM   #946
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 702
Pick whatever one fits YOU best. The FJR was a little cramped for my legs. THe C14 was better in that regard. Both felt cramped compared to my Weestrom.
IBA #33260
cablebandit is offline   Reply With Quote
Old 01-10-2013, 07:41 AM   #947
FireIdiot
Lost in translation
Oddometer: 82
I was actually in this position last year. None of the dealers would let me take a test ride on a new unit, so I found a used one at a dealer and rode it. I also took my wife and had her sit on both and see which one she would fit better. She had more front to back seat room on the Connie, and I was leaning that way anyway. The one I found was a 2010 with abs, 3,000 miles with a trunk, risers, gel seat, and extended warranty. It took a few months of looking before I made the decision.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
FireIdiot is offline   Reply With Quote
Old 01-10-2013, 10:25 AM   #948
dmasters458
dmasters458's Avatar
Oddometer: 42
I went C14 for the 2up factor. I figured the heavier bike would be better with the wife on it. I love this bike. My poor airhead hasn't seen much road time since.
2008 Kawasaki Concours 14 ABS | 1979 BMW R100RT | 1979 Kawasaki KZ 1000 | 1979 Vespa P200E
dmasters458 is offline   Reply With Quote
Old 01-10-2013, 10:28 AM   #949
cls
Oddometer: 1,166
I've also had both. For me, it came down to the FJR had better handling and fuel consumption but the C14 had better power, ground clearance, and a little more room (The Connie also had notably more techie doo-dads until 2013. I haven't kept up w/the changes well enough to comment on that latest change.). They're both very good, but (relatively) heavy, bikes.
cls is offline   Reply With Quote
Old 01-13-2013, 06:50 AM   #950
mikejet
KlrKid
mikejet's Avatar
Oddometer: 96
Windshield upgrade
Just installed a Cee Bailey Ultra Tour Domed Windshield on my 2011 Silver Connie.
Makes all the difference in the world. I`m 6ft tall and the stock shield produced some buffeting and wind noise.
The Cee Bailey shield eliminates both the Noise and Buffeting 100%.
It`s thicker than the stock shield also. Very Happy! Under $200.00 and worth it for the quiet ride.
MikeJet: When life throws you a curve - Hit the Throttle
Current Stable: 2011 Kawasaki Concours - 2001 Harley Road King
1978 BMW R100S - 1985 Yamaha FJ1100
mikejet is offline   Reply With Quote
Old 01-13-2013, 08:54 AM   #951
cablebandit
Web Adventurer
Oddometer: 702
I use the same shield for wintertime duty. It's too hot to use once the weather breaks. Look for about a 3MPG hit between the cold temps and pushing the larger shield.
IBA #33260
Old 01-13-2013, 08:57 AM   #952
Bryn
Leicester England
Bryn's Avatar
Oddometer: 340
I had lots of buffeting with the stock screen on my '09
Changed for a Calsci Large and the bike is transformed
You would think Kawasaki could have got something so obvious right during development
Eagles may soar, but Weasels don't get sucked into jet engines....
Bryn is offline   Reply With Quote
Old 01-13-2013, 09:42 AM   #953
thetable
thetable's Avatar
Oddometer: 1,423
I run the same screen in the winter, but for warmer temps, the stock is my preference. I'd prefer an even shorter windscreen, but can't bring myself to cut the stocker.
thetable is online now   Reply With Quote
Old 01-13-2013, 01:46 PM   #954
Bryn
Leicester England
Bryn's Avatar
Oddometer: 340
Never gets that warm in England
Old 01-24-2013, 02:55 PM   #955
1 wheel peel
1 wheel peel's Avatar
Oddometer: 105
Originally Posted by cognosticator View Post
..... not sure what stock torque is at the rear wheel, but 97 at the rear wheel is a lot of fun ....
Average stock rw tq is 92.
http://www.rockthegear.org/
1 wheel peel is offline   Reply With Quote
Old 01-26-2013, 10:37 AM   #956
motocopter
motocopter's Avatar
Oddometer: 877
Question Givi E55 trunk
Questions for the mounting rack.
I'm going to replace the existing rack plate, with one that will accept the SW-MOTECH Quick-Locks so the soon-to-arrive E55 trunk can be mounted direct. I've seen numerous racks for the C14, but I want one that will move the trunk forward. There is one from Projekt D that is moveable fore and aft that is a possibility, but I'd need to ask them where the forward position actually is - forward being the OEM location only?
Anyone know of a rack that will move a trunk about four inches forward?
- marc
Kawasaki Concours 1400 (an adventuring bike!)
My only ride report | IBA member | AMA member
motocopter is offline   Reply With Quote
Old 01-26-2013, 02:30 PM   #957
FireIdiot
Lost in translation
Oddometer: 82
www.philsfarkels.com
It's a great replacement for the cheap plastic ones.
Old 01-26-2013, 05:38 PM   #958
cablebandit
Web Adventurer
Oddometer: 702
You'll need a custom job to go 4 inches forward. I have the Premier Cycle Accessories rack and the E55 clips right on. It adjusts about 2 inches but that's basically backwards.
IBA #33260
Old 01-26-2013, 07:24 PM   #959
motocopter
motocopter's Avatar
Oddometer: 877
Thanks guys. I'll have to await the arrival of the trunk. Then, set it on the rack positioned where I want it, and then assess the aftermarket racks to see what might be close. The Phil's rack may be what I need. It's just that some of the trunks look to be move rearward in an attempt to fit a pad for the passenger.
- marc
Old 01-26-2013, 08:34 PM   #960
EVLED
EVLED's Avatar
Oddometer: 593
+1 on that! i had the Givi SR410 setup but have changed to Phil's rack and it's the biz!
EVLED is offline   Reply With Quote
Times are GMT -7.   It's 12:50 PM.
