Old 01-22-2013, 05:14 AM   #931
dfye55
dfye55's Avatar
Oddometer: 134
Originally Posted by jules083 View Post
I was messing around last night, figured I'd throw this picture up for anyone curious. A Giant Loop Coyote fits the KLR fairly well. The rear hooks just barely fit, I have the strap as long as it can go and had to pull them pretty tight. They are meant to hook on the fender, but I have the left side on this gusset looking part of the frame and the right where the helmet lock used to be. I may notch the fender later to get it to fit better, haven't decided if it's needed or not. The kicker barely works, but does. You need to angle your foot out some and kick with your heel. The lower straps need to be on the passanger peg bracket to angle the bag down. If they are on the frame like I do on my XR then the bag sits more flat and the kicker hits the bag.
thanks! Wondered about fit and kicker.
Sent from mobile
Don '05 KLR 250; '09 Suzuki TU250x; '70 Honda Trail 90
dfye55 is offline   Reply With Quote
Old 01-22-2013, 06:51 AM   #932
jules083
Oddometer: 1,071
Here's a few more pictures I just took:
Kick starter clearance. It's tight but works:
The gusset at the bottom is where the hook is currently:
I think I'm cutting a small notch in the fender to move the hook up to just above the frame:
Bag sits a bit crooked. Notching the fender and moving the hooks up will fix this
Strap is right at the limit. Again, a fender notch will fix:
Ninja 250 for sale cheap:
http://www.advrider.com/forums/showthread.php?t=854880
jules083 is online now   Reply With Quote
Old 01-22-2013, 07:13 AM   #933
stevemd
stevemd's Avatar
Oddometer: 81
Good Frt Brk Pads? EBC Sintered R Series?
These are made in the USA, FA67R. Seem to get good reviews online. Thanks for any feedback. ('89 KLR250)
stevemd is offline   Reply With Quote
Old 01-22-2013, 12:32 PM   #934
enumclaw
I just....don't know
enumclaw's Avatar
Oddometer: 254
That's what I use. They seem to stop the bike.
enumclaw is offline   Reply With Quote
Old 01-23-2013, 12:24 AM   #935
Voidrider
Oddometer: 895
I've mentioned my '89 basket case. I am reading and re-reading this thread for info.
I realize I need the KLR 600 base manual, and the KLR 250 Supplement. I found that the KLR 600 appears to have been in production from '84-'90? I am wondering, would the manual of any particular year be preferable?
Voidrider is offline   Reply With Quote
Old 01-23-2013, 05:36 AM   #936
XDragRacer
Oddometer: 2,013
Not preferable, IMHO, because referrals in the KLR250 supplement are referred to the KLR600 base manual.
You could probably interpolate some yourself and "get by" with a KLR650 manual, either Kawasaki publication or Clymer's, but . . . wouldn't say the technique "preferable" to a KLR600 manual; YMMV!
XDragRacer is offline   Reply With Quote
Old 01-26-2013, 07:53 PM   #937
newcastleadam
Artful Tagger
newcastleadam's Avatar
Oddometer: 3,423
Finally got my basket case twofiddy running. The 1.0mm over Wiseco piston worked great....until the slighly ganked cam chain tensioner cap screw gave way and started burping oil. Also noticed that the handlebars took some hits, so that's on the list too.
Adam
86 KLR250 01 KLR685 06 K1200LT
As ever, buyer and seller of all things KLR
KLR Doohickey Wrench available!
The North Florida Tag-O-Rama wants YOU!
newcastleadam is offline   Reply With Quote
Old 01-26-2013, 08:29 PM   #938
EmkIoway
Oddometer: 9
I have a Klr 600 base manual for sale you can have.
EmkIoway is offline   Reply With Quote
Old 01-27-2013, 05:36 PM   #939
dfye55
dfye55's Avatar
Oddometer: 134
Question Suspension link corrosion
Got my bash plate installed, finished setting the valves and got her put back together. Wired in phone, gps, and Trail Tech computer on a switch. So far so good.
Then I pulled the rear suspension links and pins to swap for lowering links and was disappointed to find rusty pin surfaces and rusty pins where the links were in contact with them. I tried polishing out with steel wool, but there is very shallow pitting.
After seeing that the pins rotate on roller bearings, and those surfaces were clean and undamaged, I have come to the conclusion that unless there is a loose fit, the rusted links and pins are not a problem.
Thoughts?
Old 01-28-2013, 06:56 AM   #940
newcastleadam
Artful Tagger
Oddometer: 3,423
Should be fine. Perhaps apply a film of anti-seize during re-installation?
Adam
Old 01-28-2013, 06:21 PM   #941
dfye55
dfye55's Avatar
Oddometer: 134
anti-seize... good idea
Not in my routine, thanks for suggestion!
Old 01-30-2013, 02:05 PM   #942
stevemd
stevemd's Avatar
Oddometer: 81
Selling '89 KLR250 Soon: Maryland
I bought a well-maintained '89 KLR250 from another member here but have decided I miss having a XT225 too much. This is advance notice as I need to sort out a front brake problem first. This is the last year of the 28 hp model. After that you got 23 hp. Some of you may remember this bike and the owner. I will probably be asking $1000. for it and a box of spares. More pics available on request.
Old 02-01-2013, 08:46 PM   #943
Brash1
Adventurer/Goof-off
Brash1's Avatar
Oddometer: 50
Wish you were closer stevemd
That's just the bike I'm looking for close to birmingham al. I've got an 88 I've fixed up and want a match for a tat trip with my son this summer.
2003 YZ450F
1988 KLR250
Brash1 is offline   Reply With Quote
Old 02-02-2013, 06:11 PM   #944
8gv
Oddometer: 1,212
Safety switches...
Ok so I'm finally going to disable the switches on my KLR250. I'm too lazy to look it up. Am I making the circuits or breaking them? Is there a cleaner place to do this such as under the tank?
8gv is offline   Reply With Quote
Old 02-02-2013, 06:43 PM   #945
dfye55
dfye55's Avatar
Oddometer: 134
What? Why?
I just added switched power outlets for phone, GPS, and trail computer.
Maybe removing signals horn and such to make it a woods bike?
Sent from mobile
Times are GMT -7.   It's 09:01 AM.
