Old 01-26-2013, 03:19 PM   #7786
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,416
Originally Posted by SFAdventurer View Post
I converted a SXC awhile back and then later picked up a complete 640 ADV. I still have an extra silver tank, silver front/mask,and headlight bracket if you're interested. Also, I fashioned an interesting substitute bracket for the headstock tabs that support the headlight bracket that worked brilliantly The ADV headstock has welded tabs for that purpose which the SXC doesn't. I've been holding on to a 2nd set of headlights which I may let go as well.
Here's the '03 SXC convert
Here's my '02 640 ADV
Awesome! PM sent.
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 01-26-2013, 03:49 PM   #7787
ScramblerTom
ScramblerTom's Avatar
Oddometer: 274
Key problem - locked out???
I just installed HID lights on my 2005 640 adv and went I went to test them I could not get the key into ignition - it s cold here -10 C, but it does not feel iced up, it feels like it is trying to lock me out - if that makes sense. The key has been sticky before, but now it goes in 1/4 inch and just hits something hard and not moving. Do these locks have some safety feature that locks you out if they detect something fishy??? I shot a little antifreeze into the lock but nothing. I was pushing really hard and gettingpretty pssed but quit before I really fooked it up.
A ride up north
2005 KTM EXC 400
2005 KTM ADV 640
-> SOLD then bought a 2009 DRZ 400 - on the weight loss plan
2006 Piaggio BV 250
1986 XT 600
traded for a Jet Ski!! taking up wakeboarding... was not riding it anyway
ScramblerTom is offline   Reply With Quote
Old 01-26-2013, 03:57 PM   #7788
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,396
Originally Posted by Gregidy View Post
58530005200 2002 660 rally 102 mm
58330005100 2002 640 adventure 101 mm
I cross referanced the parts at cheap cycle parts diff part # and list stroke 1mm longer
http://www.cheapcycleparts.com/model...32265-cylinder
http://www.cheapcycleparts.com/model...31045-cylinder
Thanks, but thats bore not stroke.
Aussie Steve is offline   Reply With Quote
Old 01-26-2013, 04:06 PM   #7789
Aussie Steve
Oddometer: 1,396
When I was researching the difference between the '03 660 Factory Replica Supermoto and my SXC, I saw that the crank bearings were different to fit different journal shafts on each side of the crank of the SXC. I assumed the differences had something to do with a different magneto to support the lights. Maybe it just takes sourcing a different bearing for the right side journal shaft that will also fit the right crankcase halve properly?
Interesting, yes you're right the rally uses the same bearings on both sides. Could be as 'simple' as sourcing the right bearing to do the job, or just using the the 640 bearings.
The rallye and 640/625 appears to use the same flywheel and stator even though it has a completely different ignition system.
Have no doubts that fitting the crank in is possible, but I've put it into the too hard/expensive basket.
Old 01-26-2013, 04:22 PM   #7790
Falcon Rust
Oddometer: 96
Kickstart.
Hi, on my 2006 i've noticed the kickstart is getting stiff and not as easy to kickstart, also, at times, it get stuck at the bottom of the stroke?
anyone had a similar problem?
thanks,
FR
Falcon Rust is offline   Reply With Quote
Old 01-26-2013, 05:37 PM   #7791
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
You've fooked it now. So sell it to me, already.
Old 01-26-2013, 06:55 PM   #7792
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,538
thanks,
FR
How cold is it outside.
When I try to kick start my 2001 under 30 degrees it too gets stuck and also gets very stiff.
When it's really cold, it doesn't even engage. Stick a heater on her for 15 minutes to warm up the oil a bit.
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 01-26-2013, 07:31 PM   #7793
ScramblerTom
Oddometer: 274
what the hell MBD- you still looking for a REAL bike???
owning a 640 adv is little like being a celebrity - all kinds of unwanted attention...
that said I am really considering why I am holding onto the 640. The 400 is more fun in the dirt and for weekend rides thats what I am on. the xt600 is smother on the commute and just as just as cool (almost). The 640 is one of those bikes I find myself wondering why I need it - it is too high strung for commuting and too heavy for enduro-style riding. As much as I love it, I am tempted to admit I could get on fine without it. I can't believe I am saying this...
A ride up north
2005 KTM EXC 400
2005 KTM ADV 640
2006 Piaggio BV 250
1986 XT 600
Old 01-26-2013, 07:51 PM   #7794
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
It's a bit of an itch; usually goes away after a while.
And I'd say owning one is not so much like being a celebrity. More like dating one.
Old 01-26-2013, 07:55 PM   #7795
ScramblerTom
Oddometer: 274
I suppose you are right - you never really own a 640 - you just have a certain perscribed time as a companion to one - that said - why the f__ can't I get my key into the ignition
A ride up north
2005 KTM EXC 400
2005 KTM ADV 640
2006 Piaggio BV 250
1986 XT 600
Old 01-26-2013, 08:02 PM   #7796
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,593
Sometimes the tumblers just jam. Have you tried a little graphite lube?
I seriously doubt the bike is reacting to your mod. It's a coincidence.
Old 01-26-2013, 08:34 PM   #7797
TripleThreat719
Track Addict ADV Wannabe
TripleThreat719's Avatar
Oddometer: 281
Thanks TripleThreat......I went to school and learned how to post pics here. All corrected.
Looks great! Nice conversion...
On the road less traveled....
.... You always meet more interesting people!
______________________________________
Coming Soon... 2004 BMW R 1150 RT; Gone Soon... 2009 Husqvarna TE 310; Gone, but fondly remembered... 2003 KTM 640 Adventure
TripleThreat719 is offline   Reply With Quote
Old 01-26-2013, 11:55 PM   #7798
Droptarotter
Oddometer: 1,235
No safety feature...........treat them like a virgin.........it's too cold.....so lube it well and slip it in easy..........take your time............lube it well......get it excited..........and wet........tease it in!
Old and experienced
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 01-27-2013, 12:24 AM   #7799
bmwktmbill
Traveler
Oddometer: 5,098
Old and experienced
Heck Drop, I just use the hair dryer on my girl.
She loves it!!!!
A little viiiibration doesn't hurt either
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 01-27-2013, 05:03 AM   #7800
Johnnyktm
Oddometer: 117
Hi!
In 2008, while I was watching the BAJA ARAGON in Zaragoza (Spain), I took some pics of a Marc Coma Dakar Rally bike that Repsol was displaying, and I'm going to post a couple, just in case that you like them
I have some other pics of this bike that I can also upload, if you wish
Johnnyktm is offline   Reply With Quote
Times are GMT -7.   It's 11:59 PM.
