01-26-2013, 11:22 PM
#15631 |
Oddometer: 9,700
01-27-2013, 12:05 AM
#15632 |
Oddometer: 3,826
Prediction: It won't have a problem if your battery is good.
"It's better to ride a boring bike than push an interesting one" ... Canuman The 2012 Yamaha Super Tenere is a hungry bike. Touring? Eats it up. Twisties? Eats it up. Back country camping with a heavy load. Eats it up." - Tumu Rock AMA. GrahamD screwed with this post 01-27-2013 at 12:44 AM |
01-27-2013, 06:05 AM
#15633 | |
Oddometer: 265
ac |
01-27-2013, 06:06 AM
#15634 | |
Oddometer: 265
ac |
01-27-2013, 06:41 AM
#15635 |
Small Town Hick
Oddometer: 369
3 days no riding? It ain't worth it. :)
And the hard start debate is simply the S10 debate. Every bike has one.
*********************** 12 Super Tenere...........04 DRZ 400E 06 950SM (Yehaw!!).... 96 DR350SE 06 KLR 98 VTR (Track Bike) |
01-27-2013, 08:09 AM
#15636 |
Studious
Oddometer: 4,280
So I just went out to crank the tenere after it sat for two weeks (not usual around this house). Battery is totally dead. This battery is only about 2 months old. This has happened before and I blamed it on the factory battery sitting at the dealership for too long.
Don't you think a battery should hold a charge for two weeks? THIS IS NOT A "HARD STARTING" ISSUE! This a dead battery issue. The bike would not turn over. Of course now that the ignition has been turned on and the FI charged up I'll probably have a "hard starting" issue ![]() P.S.- I know there is a voltage leak somewhere. Mostly venting here, but if anybody has any insight, please enlighten me.
Later, Michael "If I can't pass at a reasonable speed I do it unreasonably." - jdmetzger |
01-27-2013, 09:56 AM
#15637 | |
Oddometer: 121
Jeff
Jeff Haar 2012 Yamaha Super Tenere Issaquah, WA |
01-27-2013, 10:08 AM
#15638 | |
EVal Innovations Inc
Oddometer: 367
Do you by any chance have a SWMotec powered tank bag? If installed the way the directions are, direct to the battery, it draws current even with nothing turned on, just the bag on the tank ring. And will kill the battery quickly. BTDT. It needs to be wired to switched power instead. I messed up the original post, edits to correct my errors. Thats what I get from not looking it up again. ![]() As for testing dark current, or parasitic draw with the key off, take a multi-meter, set to AMPERAGE in the 10 or 20 amp range and do the following: Loosen the NEGATIVE terminal so you can easily pull it off. Touch the DMM probes to the terminal and the same battery post, note the reading, which should be 12-14 Volts, then with the probes staying connected, slide the terminal off so that the DMM is now in series with the removed terminal and the battery post. I've forgotten the Ma that spec is, but post what you find and it will be immediately apparent if it's too high. Should be around 45-54 Ma. Much higher than that indicates a problem. And yes, the battery should easily last two weeks. Dirty bike screwed with this post 01-27-2013 at 10:15 AM |
01-27-2013, 10:16 AM
#15639 |
Oddometer: 367
I screwed up the above post, please read the edits to avoid any problems. Sorry!
01-27-2013, 10:29 AM
#15640 |
Studious
Oddometer: 4,280
Thanks y'all! I'll get on checking stuff out in a bit.
The battery took a charge and the bike cranked just fine, so that's a good sign.
01-27-2013, 10:50 AM
#15641 |
www.rideonadv.com
Oddometer: 352
I will add to this just a little... I had a slightly weak battery in my FJR several weeks ago.. It would turn over just fine but would not fire up. Guess what, when I opened the throttle wide open it would fire... The battery was old on it so I knew it was just an old battery, but sounds like you guys with the Teneres..... After I put a new battery in, the FJR fired right up and good as new... As several of you have said, I wounder if its a voltage "issue".... For the people that are having start up issues, what electronic farkels do you have on the bike ? It might be a common "part" for the guys having issues...... just a thought
~TABASCO~ screwed with this post 01-27-2013 at 03:40 PM |
01-27-2013, 12:42 PM
#15642 |
Boss STAG
Oddometer: 3,734
I live more in 5 minutes on my motorcycle than some people live in a lifetime............... My last ride started badly,steadily got worse,until it ended in disaster, but apart from that it was excellent!
01-27-2013, 12:49 PM
#15643 | |
Oddometer: 3,826
"It's better to ride a boring bike than push an interesting one" ... Canuman The 2012 Yamaha Super Tenere is a hungry bike. Touring? Eats it up. Twisties? Eats it up. Back country camping with a heavy load. Eats it up." - Tumu Rock AMA. |
01-27-2013, 01:30 PM
#15644 |
www.rideonadv.com
Oddometer: 352
Can you post the link to your write up?
01-27-2013, 02:32 PM
#15645 | |
Studious
Oddometer: 4,280
Battery -> Eastern Beaver fuse block -> Clearwater lights on switched circuit, Garmin Zumo 550 GPS mount on un-switched circuit I'm going to track stuff down some time this week. Not today though.
