Old 01-24-2013, 08:47 AM   #316
brucifer OP
brucifer's Avatar
Oddometer: 2,427
Originally Posted by spencergt66 View Post
LOL no crack just some oil on the cover the side case was taken off to determine a noise said he didnt know what it was so it sat....
Nice! That's quite a deal you got there!
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 01-24-2013, 09:07 AM   #317
JustRon
ex-broadwayron
JustRon's Avatar
Oddometer: 1,205
Just the suspension is probably worth over $400... nice find!
(I like when this thread gets bumped.)
2010 520RR
2013 TR650
JustRon is online now   Reply With Quote
Old 01-24-2013, 12:55 PM   #318
Bob Tosi
Bob Tosi's Avatar
Oddometer: 1,607
Instant wood!
When you're lost in the wild and scared as a child. And death looks you bang in the eye, and your sore as a boil, its according to Hoyle to cock your revolver... and die. But the code of a man says "fight all you can" and self-dissolution is barred. In hunger and woe, its easy to blow... Its the hell-served-for-breakfast thats hard........Robert Service
Bob Tosi is offline   Reply With Quote
Old 01-27-2013, 05:39 PM   #319
spencergt66
Oddometer: 791
tore into it today found balance shaft bearing failure, lame..... guessing most bearings are smoked now do I part it out or fix it?
spencergt66 is offline   Reply With Quote
Old 01-27-2013, 05:51 PM   #320
Idle
Oddometer: 719
Can you rebuild it and make it a 501? Can surely justify a rebuild with what you have in it yeknow? Or part it out and try your luck again..
Idle is offline   Reply With Quote
Old 01-27-2013, 05:59 PM   #321
spencergt66
Oddometer: 791
I sold almost all my berg spares when I offed my 470 I had all the parts needed I still have the guys info may call him to see if he'll part with an updated balance shaft and bearing... While I'm there I figure it would be best to update the cam chain guides and ca, bearings
Old 03-10-2013, 07:34 PM   #322
Big-Tim
Oddometer: 5
Hey everyone new to the site great to see all the info on these bikes , I have a 95 fe350 and am in love everything about the bike is great and a surprising amount of power haven't had a problem hanging with any of my friends bikes , would post a picture but not sure how
Big-Tim is offline   Reply With Quote
Old 03-11-2013, 01:08 PM   #323
Big-Tim
Oddometer: 5
http://timmyboy.smugmug.com/Other/Bi.../M/image-M.jpg
My husaberg 350 if i uploaded right soon to be camo having one of my buddies wrap the plastics
Black blue white and gray camo hope it looks good with the yellow frame , also any one know if there are other motors that interchange on this frame , power is good for now but I know I'm gonna want more soon
Old 03-11-2013, 01:48 PM   #324
brucifer OP
brucifer's Avatar
Oddometer: 2,427
Welcome Tim! Nice bike, man! Why do you want to camo it?
Old 03-11-2013, 01:52 PM   #325
Big-Tim
Oddometer: 5
just wanted somethimg different and wasent a big fan of the yellow plastics and one of my budies does custom wraps and is hooking me up always like the look of camo on bikes
Old 04-02-2013, 12:41 AM   #326
spencergt66
Oddometer: 791
Jetting and fuel range questions
Just a few questions about jetting and fuel range... 2005 fe550 jd jet kit all per instructions using the blue needle fuel screw 2 out no leak jet or leak jet adjustment. went to northern California had my 4 gallon tank on went on a long ds ride put about 30 in town miles on the bike hit the freeway for 85-90 miles stopped to fill up before I hit the woods and put in over 3 gallons? Does this seam right I am running 15-42 on the gearing trials rear tire and front knobby. Also found on the way back that from 1/8-1/4 throttle the bike has a slight bog and even coughed while on/ off the throttle once or twice. I did change the spark plug before I left and to me it seamed a bit on the rich side. I did mess with the fuel screw a bit on the way home but it didn't seam to make a difference eaither way. I was thinking of going to the red needle sice the temps outside are coming up.
What do you guys get for rang on freeway @65?
On the trails I had pry 50-70 miles of dirt pry burnt a hair over 1 gallon.
Old 04-05-2013, 08:09 AM   #327
Dieselfool
Dieselfool's Avatar
Oddometer: 350
My 05 450
My 08 450
08 FE450....Riddin hard and hung up wet.
A Berg in the bush is worth two in the shed.
Dieselfool is offline   Reply With Quote
Old 04-05-2013, 10:03 AM   #328
spencergt66
Oddometer: 791
This thing will go anywhere
Old 04-05-2013, 05:51 PM   #329
Bushmechanic
Bushmechanic's Avatar
Oddometer: 73
nice tyre Spencer
you won't go anywhere with that bike till you sort the carb with an NKBT copy
2008 Husaberg 700F 104kgs all fluids no fuel
frame build http://www.husaberg.org/forum/viewtopic.php?f=8&t=13268
engine http://www.husaberg.org/forum/viewtopic.php?f=5&t=12131
Bushmechanic screwed with this post 04-06-2013 at 12:14 AM
Bushmechanic is offline   Reply With Quote
Old 04-06-2013, 09:05 AM   #330
Idle
Oddometer: 719
My favorite tire aswell.
Times are GMT -7.   It's 04:40 PM.
