01-27-2013, 10:51 PM
#10 | |
Traveler
Oddometer: 4,015
We need to find the correct wiring diagram, then you take it to the copier and enlarge it. I think a dealer or KTM USA technical will help you. http://www.ktm.com/us/contact.html Once you get the wiring diagram enlarge it. The plug socket size is 18mm. Do you have any jumper wires? Better make some around 3 feet long with alligator clips on either end. Buy a good roll of 3M Scotch super 33+. Buy some dielectric or silicone grease. http://www.amazon.com/3M-Scotch-Elec.../dp/B00004WCCL And a small pair of sharp scissors to cut the tape(don't tear it!). The scissors go in your tool kit. A small bag or old sock holds the tale, jumpers and multimeter. Grease goes to the tool kit You are looking like a motorcycle DC electrician. And smile, you are among the elite. Reread everything Gunner wrote. Unscrew the plug cap and cut off 3/8" off the wire end, re-screw the cap. Check and grease every electrical connection especially on the wires leaving the ignition switch. Check, plug and unplug every connection on the rest of the motorcycle and grease with dialectic grease. Bring the motorcycle up the steps into the dining room. It's warmer in there...oops...you have to run it, darn!!! Don't give up, we have all been there. bill
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
