Old 01-27-2013, 07:34 PM   #3046
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,675
Originally Posted by dljocky View Post
I'm not mechanical at all, but I know I need some AUX lights for my DR650. I'm confused as to how they hook up? Is there a way that I can hook them up so that the AUX lights, when turned on, stay on whether or not I'm running low or high beams? Does one need the "dimmer" switch? Does this dimmer work like the dimmer switch in a car, or is there something else to it, ie, like a dimmer switch a person migh put on their wall switch for a dinning room light?
I was thinking of the getting the Model 30, but since the M61 has come out, I'm now thinking about this. I wonder if I would need a dimmer with the M61's as they put out less light? I'm trying to keep the cost down, while just increasing my night time safety. When I'm riding with my DR650 lights on bright, I almost have sufficient light, so I'm thinking just a bit more and I would be good. Thanks all.
You can wire them however you want. Think about how you want to use them and post here or wire them up accordingly. The dimmer works on the lights,so your closest example given would be the dining room lights.
I'm running 3 lights, 2 30's and a 60. Not all at the same time though. My Dr650 is still running the stock stator and only puts out 200w. Running 120w of aftermarket lights sucks the batt down a bit. I used the 30s for corners and the 60 for an additional headlight. I mounted the 60 on a plate that hooked up on the fork mounts and on the lower bolt for the headlight cover. It sits just below the headlight now,does a great job too. The 30s are right by the reflectors. I just added a hole to the metal tabs and they did ok. I'd like to upgrade those or maybe move them while I have the front end off for a revalve/spring job.
Danjal is online now   Reply With Quote
Old 01-27-2013, 09:00 PM   #3047
20Fingers
MCarrera GS-Giants
20Fingers's Avatar
Oddometer: 139
Excellent!
Need to know what mounting hardware for my 2012 F650GS Special Edition....Want to run them from my turn signal mounts...any suggestions for installing a pair of Model 60's???
A dedicated rider in central Maine. I offer tour and ride support to anyone traveling through, mapping help online, Q&A by email, just about anything adventure riding and camping related!
20Fingers is offline   Reply With Quote
Old 01-28-2013, 01:49 AM   #3048
an13
Oddometer: 35
What is the weight of these M61, M62 and M64 lights? They look quite sturdy but are they heavy?
an13 is offline   Reply With Quote
Old 01-28-2013, 06:06 AM   #3049
steveWFL
steveWFL's Avatar
Oddometer: 1,344
Quick question about your model 60. I would like it to kick on with the high beam. Should i wire in a 12v relay, or can I tap into the bike's high beam wire directly? I suspect tap right in since the draw is so low, but just curious?
I went back a few pages in this thread and couldn't fin an answer.
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 01-28-2013, 09:11 AM   #3050
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,591
It depends on the bike! If you have a bus system on it, then you need a relay.
Jim
Old 01-28-2013, 10:32 AM   #3051
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Jim
I'd only use those LED's with the dimmer controllers (built in relay/electronics), so much nicer to be able to adjust/set the brightness and then use the built-in hi-beam override, usually you don't need that much light output anyways.
tallguy-09 is offline   Reply With Quote
Old 01-28-2013, 10:45 AM   #3052
michigan400
Oddometer: 81
M30 and M61 size pics
The new M61's are riughly the same size as the previous gen lights (M30, M44 and M60). Weight feels close and the new M61's have the mount a little more in the middle. Just got them so no beam pics or anything yet. I'll start mounting them tonight. Lookin good so far! Can't wait to get them hooked up and see how they do!
michigan400 is offline   Reply With Quote
Old 01-28-2013, 05:56 PM   #3053
JimVonBaden
"Cool" Aid!
Oddometer: 51,591
This is true!
Jim
Old 01-29-2013, 07:47 AM   #3054
michigan400
Oddometer: 81
M61 mounted to bike
Messed around a little last night and mounted them to the bike so I could see where would be best. Hooked up just 1 to power so I could see them in action. To my eye and the quick pics I took with my cell phone so I could compare,, the M61 looks to have about the same size and brightness of the model 30 beam with just a touch less spill light. Bigger reflector looks to make up difference in raw lumens ( 1500 for model 30 and 900 for model 61). Of course I'm just going by what I saw on the door of my garage and I have not done an outside test to check out total distance.
They mount up good and solid and I like the way they look. Here they are mounted to handguards, hanging down.
Mounted to guards but on top. I attached a model 44 below one of them just for fun and to see what it would look like. A little to clunky for my tastes but I bet the light output would be awesome with a set up like that on each side.
Old 01-29-2013, 10:11 AM   #3055
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,926
I just posted this over in the Cylops thread, FYI.
Originally Posted by sanjoh View Post
I do not normally post in other vendors thread, however you do not have your facts straight about the model 60. It does not use 40watts, this is a common mistake, especially by marketing folks. I am an engineer, the light uses 28watts@12v, measured with a calibrated amp meter. Not the 40 watts you stated.
The light picture of the model 60 looks ridiculous, looks like the light is pointed at the ground, very obvious as you see the top of the main beam is over exposed on the lower part of the picture.
I invite any comparison but seriously it needs to be done by a third party that is not biased, any volunteers?
Old 01-29-2013, 12:07 PM   #3056
paulvandenbogaard
Oddometer: 16
Hi Sanjoh,
I just read that clash. I would definitely be interested in being this third party. However even if the other party(s) agree, that would mean shipping to Europe. Taxes are 21% excluding import duties... I do have a good camera to make a very comparative range of pictures though. And of course a good interest in this stuff since planning for additional lightning for my KTM 990SMT that I hope to get in march. And finally the nights are still long in this northern part of Europe.
Thanks,
Paul
You might even consider to also put the M61..64 in this comparative arena.
paulvandenbogaard is offline   Reply With Quote
Old 01-29-2013, 01:03 PM   #3057
WindSailor
WindSailor's Avatar
Oddometer: 648
I invite any comparison but seriously it needs to be done by a third party that is not biased, any volunteers?.
I might be... like the previous - if both can agree. I'll try and get at least three people involved for the comparison. PM me if your interested...
WindSailor is offline   Reply With Quote
Old 01-29-2013, 01:18 PM   #3058
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,605
Ι Have two model 60 and two model 40 on my 640 Adv ...
Comparison?
Anytime baby
Aurora Rally Equipment
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is online now   Reply With Quote
Old 01-29-2013, 03:00 PM   #3059
Russentreiber
Free-Biker
Russentreiber's Avatar
Oddometer: 15
Thumb Received lights !
Just to let you know that I received the lights yesterday
Will post pics when installed
Hooked them up temporarly and... WOW !!!
More as soon as I can install... prepping for Elefantentreffen.. so much stuff to do... so little time...
Great stuff Sandjoh...
Russentreiber is offline   Reply With Quote
Old 01-29-2013, 05:36 PM   #3060
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,926
Great to hear you are happy with the lights. Some pics of the Elefantentreffen Rally would be great, sounds like fun!
Times are GMT -7.   It's 04:16 PM.
