01-26-2013, 07:06 AM
#14191 | |
Oddometer: 8
You run them as is for 95/98 octane or cut a wire for <95 octane. Someone who expects to go back and forth [depending on availability of fuel] might decide to cut the wire and fit a switch or clip of some kind I guess. Headers from http://www.abp-racing.de They don't have the easiest ordering system, particularly if you don't speak German, but they bolted straight on my original engine. People claim they give extra engine power too, but I can't confirm that, not having a dyno test before and after. Also they are slightly tighter going around the engine so no need for a leg guard to avoid burns which means the crash bars have plenty of clearance now. I wish I'd remembered to take some pics of my first 2 rides, the second one in particular was very enjoyable even with light showers. |
01-26-2013, 09:21 AM
#14192 |
It's a short cut, really
Oddometer: 4,268
Is that 260 Euros
EACH..???? ![]() Wait...nevermind. It's 260 for the PAIR... still........ |
01-26-2013, 02:17 PM
#14193 |
Oddometer: 342
I have a '96 Transalp 600 and want to make it more capable for offroad riding. So the first and foremost thing is the suspension. I've researched a bit and decided Hyperpro's are the best for me.
On the front, I will just change the springs. But on the back I have two choices: Either I can just change the springs or replace the shock and spring. ![]() The shock and spring is more than four times as expensive as the spring! Now what do you think, is is worth it? Or is the factory Transalp shock good enough? Thanks for your opinions. |
01-26-2013, 07:16 PM
#14194 |
Oddometer: 4,268
A 16 year old shock should either be rebuilt or replaced.
Yes, it's expensive but, believe me, you will find it money well spent. |
01-27-2013, 06:21 AM
#14195 |
Rookie
Oddometer: 4
Hey there!
This is my first post on here ![]() As far is i know honda built 34(36?)hp versions of the transalp... i think i got one of those, is there any opportuinity to give her the full 50hp? |
01-27-2013, 08:42 AM
#14196 |
Oddometer: 4,268
What year/model Transalp do you have?
To my knowledge, some of the Swiss bikes (both Transalp and Africa Twins) were built with reduced power by using intake restrictors. Dunno why your government required this. I have heard that it is possible to either enlarge the restrictors by using a Dremel tool or simply replacing them with the standard part from Honda. They should be the black flexible pieces between the carb and the cylinder head. Expect to change the carb jetting to match otherwise you will be running the bike without enough fuel. You should be able to change to the standard Transalp jetting. A good local Honda Tech should have details on this change and the jetting necessary for your local (I'm assuming higher altitude) conditions. |
01-27-2013, 10:36 AM
#14197 |
Oddometer: 53
While we're on the rear shock question. I'll need to update my 89' eventually. I did the spacer with even more modification.
![]() ![]() Does any of the xr shock fit? Noticed Dr. E. went with the 250 and upgraded spring. Just wanted to know so i can start watching flea bay.
01-27-2013, 10:40 AM
#14198 | |
Roaming ADV Gnome
Oddometer: 1,395
More Info "In Germany, reduced power versions are available for license reasons. The power is reduced (to 34 or 27 horse powers, depending on version) by a Restrictor in the intake manifold, so Honda offers different intake manifolds whereas accessory dealers offer metal plates that are inserted in the existing manifolds. Alternatively mechanical stops to the throttle can be used." http://www.f-ms.de/ta/faq/index.htm#redu http://www.xrv.org.uk/forums/transal...91-1999-a.html
01-27-2013, 10:42 AM
#14199 |
Oddometer: 119
Bolt ons
A little chillier this weekend than my idea of fun so got a few bolt ons out of the way.
I like a little more real estate for my big feet and the pivot action gets my boots under the shifter easier so went with Pivot Pegz: ![]() ![]() And to help me find the back roads as I ride I wired up a Garmin Montana 600 with the Touratech mount: ![]() Now I just need about 10 more degrees of warmth to get out and enjoy (and less damn salt spray on the roads). |
01-27-2013, 02:50 PM
#14200 | |
Chasing after theory
Oddometer: 142
Best of luck on your search!
Life is the last thing you experience before you die...living is what you do every day to get you to that point... |
01-28-2013, 12:01 AM
#14201 | |
Africatwinarama
Oddometer: 9,760
http://www.advrider.com/forums/showthread.php?t=384629
1990 RD04 Africa twin 750 350,000km and still going strong |
01-28-2013, 05:02 AM
#14202 |
from Baltic side of river
Oddometer: 405
These are one of the best 260EURos I spent on my TA.:) Fuel consumption dropped quite much- when riding within 90-100km/h I had mostly 5.3l/100km. With these new CDI's I have now with same riding style 4.5l/100km. Quite a difference, because I did nothing else, just swapped CDIs.
Else I noticed that vibration from engine to foot pegs around 90km/h/5th gear also disappeared. I had this regardless how pedantic I was when syncing carbs. Drawback is that these CDI's have sharp corners and don't fit good on my stock holders. |
01-28-2013, 05:30 AM
#14203 |
toy4fun
Oddometer: 36
My 89 has 77k miles on it, still runs nice. After reading about the rear shock I believe it should be replaced or rebuilt. Which way should I go, money is no object.
01-28-2013, 05:36 AM
#14204 | |
Rookie
Oddometer: 4
01-28-2013, 05:43 AM
#14205 | |
Wishing I was riding RTW
Oddometer: 2,422
If money is no object go with a new aftermarket shock. I just ordered a rear Ohlins from a dealer in the vendors section. Wilbur's or hyperpro as well make nice TA shocks.
My screen name is kind of long. I am the "ME" part, my name is Cory. Jimmy Lewis quote: "Those KLRs are full of potential. Just takes a rider..." |
