Thread Tools Search this Thread Rating: Thread Rating: 432 votes, 4.94 average. Display Modes
Old 01-27-2013, 04:44 PM   #6721
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,712
Originally Posted by Emmbeedee View Post
Which map? Likely City Nav? Were you using Shorter Distance or Faster Time in your routing option?
I have to go through there on Tuesday so I'll give it a try.
Latest citynav, faster time.
Wasn't like I needed the navaid, was just using for eta, so I didn't really notice what it was doing until the turn directions popped up at Bronson.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 01-27-2013, 04:49 PM   #6722
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
I do that too, navigating with the gps when I already know the best route. I find I get a better understanding of if/how it works, and if I can trust it or not.
Old 01-27-2013, 04:54 PM   #6723
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
These RAM parts might be useful to mount the Rugged Mount base on a dash where you don't have access to the other side or if your gps vibrates on your bike: RAM Mari-nuts
I just noticed them in the "New stuff from RAM" section of GPSCity.
Old 01-27-2013, 05:12 PM   #6724
Bli55
Oddometer: 391
Try to buy well nuts.
Bli55 is offline   Reply With Quote
Old 01-27-2013, 05:15 PM   #6725
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
I knew I saw those Mari-nuts somewhere before, just didn't remember what they're called outside the RAM world.
Wellnuts. Thanks for the reminder.
Old 01-28-2013, 10:13 AM   #6726
BogeyMan
BogeyMan's Avatar
Oddometer: 454
Screen calibration issue?
I noticed this weekend that my Montana 650 wasn't quite "right" - so I [tried to] perform a screen calibration [Setup/Display/Screen Calibration].
Now I get stuck in what appears to be an infinite loop, with the last step being a horizontal line across the bottom of the screen (regardless of orientation) with no dot to press, then it loops back to the start...
I've tried this both from the menu and a power-on reset.
Anyone else?
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 01-28-2013, 10:41 AM   #6727
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,843
Anyone else?
Calibration issues have not been heard of much recently. Is yours an early unit? I'd call Garmin asap if I was you.
Phone Numbers
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Old 01-28-2013, 11:01 AM   #6728
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Anyone else?
Yes, as MBD suggest, call Garmin!
Also, if you can, take a photo with your smartphone etc and post here so we can see what the screen look slike when this happens?
Thank You!
atlas cached is offline   Reply With Quote
Old 01-28-2013, 11:04 AM   #6729
dlh62c
Oddometer: 1,603
Originally Posted by Jon_PDX View Post
What am I missing that is causing you, or anyone else, to be limited to 650 km?
Its not the mileage, but the 50 via point limit.
Check to see if your route is under 50 via points.
daryl
Old 01-28-2013, 11:19 AM   #6730
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 705
Yeah. I just plugged in Fairbanks AK from my house and got a route after about 4 minutes of "calculating" Looks like I can be there in a tick over 64 hours.
That route is about 4100 miles. No waypoints just using "where to"
IBA #33260
cablebandit is offline   Reply With Quote
Old 01-28-2013, 11:37 AM   #6731
Navy Chief
Navy Chief's Avatar
Oddometer: 1,544
Okay I know I have seen this someplace in this thread but the wonderful search here will not let me search for the terms I need and I don't want to re-read 450 pages of stuff....
What are the pros and cons for installing City Navigator to internal memory vs on external SD card?
Navy Chief is offline   Reply With Quote
Old 01-28-2013, 11:39 AM   #6732
cablebandit
Web Adventurer
Oddometer: 705
None that I can think of other than if your maps are loaded on the SD card and there is something hinky with the maps that causes the unit not to boot you can always remove the SD card and reboot without the hinky map data.
That's one fine run-on sentence.
IBA #33260
Old 01-28-2013, 12:04 PM   #6733
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,506
I have a Montana 600 and a eTrex 20 and got CNNA on a uSD card so I can use it on either device without the need to purchase CNNA twice.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 01-28-2013, 12:17 PM   #6734
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
daryl
My unit won't even allow you to navigate the route if it has more then 50 via points. You can look at it on the map, but you don't get the GO button.
Old 01-28-2013, 04:05 PM   #6735
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,653
from the "FAQ"
  1. Track Manager - Options. Provide a Setting tab option on the main Track Manager screen to: "Show All Tracks on Map", "Hide All Tracks on Map", "Delete All Tracks".
still no way of doing this?
Not even goofing around with the XML on the unit itself?
KTM 950 ADV '05.5
KTM 690 '10
christian is offline   Reply With Quote
Times are GMT -7.   It's 03:01 AM.
