01-28-2013, 06:29 AM
#1 |
Sandwurm
Oddometer: 28
Replacing KTM 640 Adventure head gasket ... guidance?
I'm pretty sure the head gasket has gone on my 2002 640 Adventure -- coolant vanishes if I push it hard and get an insta-overheat; also bubbles rising in radiator with cap off.
Is there a way to check if it's head or base gasket? I'm looking at doing the head gasket myself - there's very little info on this topic (unless I missed it in search?). Is it relatively straightforward (have a copy of factory manual) ... what's the chance of warped head? Should I leave this to a workshop? I generally work on my bike myself, but not done something this major. I have also had LOTS of really miserable experiences with agents, workshops, etc, so would prefer to do it myself. I recently replaced the seals on the water pump shaft and resealed tappet cover, which fixed the one coolant disappearing problem (and mayonnaise in oil) and a oozing oil leak.
-- Ride it hard! Harder! HARDER! -- |
01-28-2013, 01:52 PM
#2 | |
I.Hopp.
Oddometer: 3,078
If the leak is found within the water jacket then it will either be a faulty gasket or a cracked cylinder/head... This thread will give you an idea of how to pressure test: http://www.advrider.com/forums/showthread.php?t=405073
640 A x 2 gunnerbuck screwed with this post 01-28-2013 at 02:02 PM |
01-28-2013, 11:31 PM
#3 |
Sandwurm
Oddometer: 28
Great, thanks for the feedback.
Will try talk a nearby bike shop into testing it for me (in exchange I'll buy more tyres and a new chain from them :) ) I recently relocated and now living in an apartment so don't have a workshop to fabricate things. Going to have to strip the engine in the garage at my girlfriend's place. Sigh. The alternative is having the local bike shop do it - they have good rep, but I talked to the mech and he has not worked on the 640 much (they mostly do dirtbikes), And I'm a bit anal about how stuff is out together. Prob cost around $200 labour. Hrmmmm.
03-05-2013, 07:45 AM
#4 |
Sandwurm
Oddometer: 28
I stripped the head and replaced the gasket. Problem not solved.
Pulled head off again. There's a crack across exhaust ports right down to the valve stem seals. Unfixable, I'm not a happy bunny.
03-07-2013, 08:11 AM
#5 |
Oddometer: 3,812
Ouch!
"Deeply flawed people make deeply flawed decisions." |
03-07-2013, 11:07 AM
#6 | |
Oddometer: 828
Are you sure it's not repariable?? Have you taken it to a good welder? Some of the welders are amazing what they can do. Good luck.
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat |
03-12-2013, 01:43 AM
#7 | |
Sandwurm
Oddometer: 28
Recons it's cracked right to the valve stem seals, so can't even get in there. Have a lead on a second hand head...
