01-29-2013, 09:57 AM
#1591 |
Oddometer: 28
[ I also was notified by PM that there have been some premature failures 2/2 to thin hardening process in the shaft ] are you referring to the cj designs shaft, I purchased mine last month but have yet to fit.
when did you purchase yours and what do you mean by 2/2 and is the problem fixed,what have they informed you about it. I have mine booked in next week to have the kit fitted but if there is a problem with the shaft I will cancel.thanks |
01-29-2013, 04:09 PM
#1592 | |
Oddometer: 43
01-31-2013, 08:28 PM
#1593 |
Oddometer: 43
I need to improve my lighting and would like aux lights. Have yall found a good way to Mount them that is secure and protected and doesnt hinder? I think the only option is the fork mounts right? I'd rather not do HID conversion but I was thinking some of the led spots.
Any input or pics of your solution are appreciated. Thx |
01-31-2013, 10:30 PM
#1594 |
Oddometer: 277
I mounted Sanjoh's Model60 leds directly to front fender right before forks using small bolt and washers. Only had to drill small holes through fender to mount them. I'm quite happy with this setup, lights are neatly located both side of the headlight.
02-01-2013, 02:49 PM
#1595 |
Homeless Somewhere
Oddometer: 1,567
Afternoon gents
Our running temps sitting on 5 bars here in Mexico when riding about 60 70 km/hr because of traffic, drops back to 4 bars once we hit 90 km/hr or so but takes a while, will add we are riding in 35 deg c about 95 f. This considered ok? When we got into Apatzingan it was 40 c and we were idling at lights for 10 - 15 minutes in town, temp got to 6 bars then the fuel pump squirted some gas out looks like from an overflow so I shut her off for a while. Anyone else had the fuel squirt thing go on? Now we just turn her off at the lights so she doesn't keep building temperature. Please let me know on the above, cheers all.
Cheers Andi & Ellen...Two Moto Kiwi Grüvers .....somewhere Two Moto Kiwis Home Page For More Of Two Moto Kiwis Photos |
02-01-2013, 02:57 PM
#1596 |
I'm Mr. Crabtree
Oddometer: 3,061
Ya mean that little tube coming off the top of the stock pump?.... That'd be bad. That's where the points are located... Which Spark.
02-01-2013, 05:33 PM
#1597 | |
Homeless Somewhere
Oddometer: 1,567
Seeing the petrol piss out I shut her off rather than watch it ... for obvious reasons
02-02-2013, 01:43 AM
#1598 | |
Oddometer: 51
What fuel tank do you have on the bike? |
02-02-2013, 06:40 AM
#1599 | |
Homeless Somewhere
Oddometer: 1,567
Running 30L Safari so suspect the flow is not as good.
02-02-2013, 07:20 AM
#1600 |
Oddometer: 51
02-02-2013, 02:00 PM
#1601 | |
Homeless Somewhere
Oddometer: 1,567
Seems fuel was squirting down from under the LHS of the tank, my airbox bottom drain tube is not there, could the petrol have bubbled out from a carb and with the fans on it might have sprayed it a bit? Not a biggy really, I have noted it so will keep an eye on it if she gets warm, will just turn her off while sitting at lights in the heat.
02-02-2013, 02:47 PM
#1602 | |
TWIN Cylinder ADV
Fuel Sensor Oring Gone
Sounds like the little oring around the fuel sensor has let go.
It has done exactly the same to me with the safari tank in the heat due to expansion. Just go to a hardware store and get a slightly enlarged oring. Quote:
Hodgo RD07 Africa Twin, KTM 950 Super Enduro www.facebook.com/KTM950SE Retired.. CR500E XRV750W,XTZ750,XLV750R,XR600R,CM250M,CB250T,CR125R,YZ100H |
02-02-2013, 07:15 PM
#1603 | |
Homeless Somewhere
Oddometer: 1,567
Many thanks Andi
02-02-2013, 08:29 PM
#1604 | |
Oddometer: 51
Also throw that little valve thingy away as its the cause for the fuel leak. At high temperatures and slow speed the combined heat does pressurize the tank a bit. If you stick to the original pipe setup it never happens but the fuel will run out if the bike is on its side. You don't have to replace the O ring immediately but it is a good idea to do it when you can.You can also seal it additionally with some gasket sealant to improve the seal - look for a fuel resistant one. Also keep an eye on the fuel hose as it comes out of the fuel tank at the bottom on the Safari tank. They are quite close to the brace and sometimes they will rub and eventually start leaking. Not a big problem just something to remember when you see fuel pissing out. |
02-13-2013, 03:39 PM
#1605 |
Nothing to see here.
Doing valves on my SE again, just wondering if there is any need to re-torque the head bolts like the older ADV models?
