Old 01-20-2013, 02:14 AM   #61
rade OP
Oddometer: 100
[QUOTE=WelshLAMB;20519975]I assume vent for rear tanks is lower than front tanks fuel level and level in fronttanks higher than rear filler when full. So does petcock have to be turned off until front tanks empty a bit?
Not necessarily the petcock has to be closed, if the vent tube ends near the triple clamps, itm higher than the main tanks... right?
Rade
KTM 950 Adv => Peru 2 Patagonia
BMW Xchallenge => Europe 2 Cape Town overland
Ducati 916 & S2R cafe
rade is offline   Reply With Quote
Old 01-21-2013, 12:07 AM   #62
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 163
If the main tanks' fuel level is above the aux tank's level, won't the fuel seek it's own level and fill the aux tank's vent line to the level of the main tanks? I am not familiar with fuel tank venting requirements, but wouldn't a vent line full of fuel present a potential problem? Is an air gap required?
BTW - Great idea & appealing design
HeatXfer is offline   Reply With Quote
Old 01-21-2013, 02:49 AM   #63
rade OP
Oddometer: 100
[QUOTE=HeatXfer;20538870]If the main tanks' fuel level is above the aux tank's level, won't the fuel seek it's own level and fill the aux tank's vent line to the level of the main tanks? I am not familiar with fuel tank venting requirements, but wouldn't a vent line full of fuel present a potential problem? Is an air gap required?
Sure, the vent tube will be filled by gas, but the vacuum should take it back to the tank I believe :-) Testing will show us...
Rade
Old 01-21-2013, 07:27 AM   #64
BigNastybrp
Big Nasty
BigNastybrp's Avatar
Oddometer: 502
you can use a one way valve on the vent. get a used on from the junk yard off a old car for testing. just my 0.02
Dr350, XR650R Dual Sport,XR600R,KTM ADV990R
BigNastybrp is offline   Reply With Quote
Old 01-24-2013, 04:18 AM   #65
evildingo
On a road to no-where
evildingo's Avatar
Oddometer: 397
Mate
Ill have one thanks , would like to use it for water storage .
Lets ride
evildingo is offline   Reply With Quote
Old 01-27-2013, 03:40 PM   #66
rade OP
Oddometer: 100
The form
some progress... the form in 3D:
in about a week or two the form will be billet by CNC machine :-)
Rade
Old 01-27-2013, 05:09 PM   #67
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 1,721
that's really sweet
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 01-27-2013, 06:58 PM   #68
rossguzzi
Oddometer: 243
Very cool to be able to do stuff like this. How many litres do you think it will hold?
rossguzzi is online now   Reply With Quote
Old 01-29-2013, 01:47 PM   #69
rade OP
Oddometer: 100
The model is saying 8,3 liters, but reality will be one liter less as there will be some air pockets...
Rade
Old 01-31-2013, 02:00 PM   #70
Chinookmark
Oddometer: 126
Subscribed
Chinookmark is offline   Reply With Quote
Old 01-31-2013, 03:38 PM   #71
srad600
srad600's Avatar
Oddometer: 408
This is looking better and better. I will likely chuck my ABS and mount this up when it becomes available.
srad600 is offline   Reply With Quote
Old 01-31-2013, 09:42 PM   #72
MrSandman818
INaVANdownBYtheRIVER
MrSandman818's Avatar
Oddometer: 646
Haha I just had to say that to be a dick.
Originally Posted by ciedema View Post
Hahaha - I can't even write what I mean.
-Chrome don't getcha home, but carbon fiber sure is fancy
My real name is Chris to stop the cornfusion at the RTE's
MrSandman818 is offline   Reply With Quote
Old 02-01-2013, 01:43 AM   #73
two trackin fool
Scott
two trackin fool's Avatar
Oddometer: 782
Any chance of being able to make provisions for ABS ???
Maybe as easy as shorten the tank although not sure how much cap would be lost to cost & value ?
Or even make a pocket for the ABS pump ?
'10 990
WHITE
two trackin fool screwed with this post 02-01-2013 at 01:53 AM
two trackin fool is offline   Reply With Quote
Old 02-01-2013, 04:13 PM   #74
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 163
Old 02-02-2013, 09:22 AM   #75
rade OP
Oddometer: 100
Xfingers pls. so that this one for NO-ABS models works well and when the investment returns back, I will invest into the solution for models with ABS. I have already some idea :-) But timewise - Christmas if all goes well with this one...
Rade
Times are GMT -7.   It's 01:27 AM.
