Old 01-29-2013, 11:22 AM   #73261
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Rusty Rocket View Post
I have always cut strips of HD innertubes and squeezed them between the frame and skidplate on all my bikes. I think that much of what people are hearing is the plate vibrating harmonically. This may not be enough for some of you. The DR650 is the quietest bike I have ever owned, I've never had a streetbike so I can't compare what others perceive as noisey.
You definitely want closed cell foam,(like GSF suggests) especially offraod. The bufferpad will soon be adobe. Think about using a "pool noodle" or foam pipe insulation instead.
I also used HD innertube stripes on all places where frame contacts skid plate. Not sure how much it helped but seems OK. Spraying with some sound deadening stuff can't hurt. More the quieter.
Old 01-29-2013, 12:51 PM   #73262
gjcarving
Oddometer: 119
Originally Posted by WindPipe View Post
What size socket do I need for that primary nut. My searches have come up empty ...
I did mine a few months ago. I believe it is a 30mm. Had to go to an auto parts store to get one. Pep boys! Hope yours is not as loose as mine was. Mine ate a bunch of the clutch basket apart on the back. Enough that I decided to replace it. Good luck!
gjcarving screwed with this post 01-29-2013 at 02:24 PM
gjcarving is offline   Reply With Quote
Old 01-29-2013, 12:54 PM   #73263
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 412
In addition to the bedliner spray, I also have the HD tube strips between the frame and skid plate. I didn't notice much, if any difference. My KLR 250 with the same treatment on the skid plate is way worse for reflecting noise, my DR 650 is quiet by comparison! Can't hear either with my earplugs in. Good point about the closed cell foam, I didn't think about the buffer pad-type material filling up with dirt and turning into a brick.
Gear Nazi rant on: If you are not wearing ear plugs when you ride, you need to, every time! As someone with hearing loss and that has to wear hearing aids, I can tell you from experience to do everything you can to protect your hearing. It is not the noise of the bike that will damage your hearing unless you are running straight pipes, it is the constant wind noise! You can have the quietest exhaust ever and still lose your hearing in pretty short order! Plus it helps tremendously with fatigue. Ear plugs every time! Gear Nazi rant off!
Tim
3DChief is offline   Reply With Quote
Old 01-29-2013, 01:41 PM   #73264
Adv Grifter
Oddometer: 6,128
Tim
As a sound recording pro ... I agree. I've done many many similar rants on ADV ... most riders just ignore ... if falls on "deaf ears" .
Everybody has an excuse, like, "... plugs are too uncomfortable", " ... they don't fit my ear canals". "... too expensive". " ... too much trouble to put in and out". Yada Yada. Got an issue? Get a tissue!
As you say, hearing loss is no joke. And yes ... it's the low freq buffeting from wind noise that does damage to the tiny Scilia around the ear drum. First you loose ability to hear high frequencies ... makes understanding speech in a noisy place hard. Goes downhill from there.
So easy to protect your hearing. At least wear them on long rides ... and learn how to insert them properly .... many riders do it wrong.
RANT OFF!
Old 01-29-2013, 02:26 PM   #73265
neo1piv014
ADV in training
Oddometer: 621
RANT OFF!
As a fairly young guy who actually has noticed a little bit of hearing damage since I started riding a few years ago, I definitely second this. I ride with tight fitting ear buds in when I'm on long trips or commuting, though I'm sure they're not helping as much as real plugs would. Do you ride with any kind of music/sound system in your helmet? If I didn't have music and podcasts, I'm not sure I'd ever use my bike to commute.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 01-29-2013, 03:13 PM   #73266
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,145
Tim
Anyone ever try that Dynamat ( I think that is what it is called) the car stereo guys use in trunks? Might be a good alternative.
I noticed my DR650 when I first put the skid plate on. Now, it is just the music it makes. Now if I don't hear stuff I get worried.
The dyno room has ruined my hearing. If we are out anywhere that has "noisy" dining area I can't hear anyone say shit. I just nod and smile. I have gotten where I wear ear plugs on long trips or if I ride the highway. Makes the ride more enjoyable.
Mongle is offline   Reply With Quote
Old 01-29-2013, 04:09 PM   #73267
Adv Grifter
Oddometer: 6,128
This is a common question. Guys think riding with ear buds they are OK ... and they are partly right! You are protecting your hearing from low frequency wind damage.
BUT ... if you crank up the Tunes ... this will also take a toll on your hearing over time.
At speed we tend to listen LOUDer and LOUDer as the day goes on ... and we've all read the studies about the Japanese teenagers going deaf from listening to their Walkman/Nano too LONG and too LOUD. Tens of thousands affected in Japan.
With hearing damage its not just db levels ... it's duration of the abuse and proximity or source of the sound to your ear drum. Ear buds are in close proximity to your ear drum ... and more worrisome ... they SEAL up your ear canal providing NO venting ...which is critical to prevent damage. Loud Ear Buds inserted ALL THE WAY IN ... really can hammer your ear drums when cranked up to max.
In my industry very few use Ear Buds for this reason. We use open air headphones ... and take them off for loud transients or gun shots.
If you listen riding ... try to keep the volume down. Over time you'll get used to a lower level.
Old 01-29-2013, 04:11 PM   #73268
dogjaw
plays well alone
dogjaw's Avatar
Oddometer: 3,213
new goodies from Seat Concepts
just talked to SC, sounds like they have some very ambitious projects coming down the road for the old DR...
...their own seat pan, will be selling a complete SC saddle for around 250.00
...an aftermarket rear fender with integral tail light, if I understood correctly
...a luggage set designed specifically for the DR
....and a combination of an oversize tank with matching Dakar-type fairing!!!!!
sounds pretty dang sweet to me!
dogjaw is offline   Reply With Quote
Old 01-29-2013, 06:16 PM   #73269
gofast1320
gofast1320's Avatar
Oddometer: 736
riding and tunes
Get you some helmet speakers like J&M or whatever. Use them and wear ear plugs. You'll be fine. You will notice you can turn the music on, set it at a level you can hear it and leave it. You will be amazed that at the end of the day you haven't had to turn it up as the day went on. This will protect your hearing and allow you to enjoy your tunes.
gofast1320 is offline   Reply With Quote
Old 01-29-2013, 06:21 PM   #73270
planemanx15
planemanx15's Avatar
Oddometer: 1,009
My friends and I bought these a couple of years ago. They still work great and I can play music all the time while wearing ear plugs.
http://www.ebay.com/itm/2-BT-interph...item2c62b76867
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 01-29-2013, 06:25 PM   #73271
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,443
Cool ...
More options for the old DR ... is always good !!!
Honda
GsVs is offline   Reply With Quote
Old 01-29-2013, 06:25 PM   #73272
gofast1320
gofast1320's Avatar
Oddometer: 736
Handle bar vibration dampeners
The left side bar end vibration dampener thing on the end of the stock handlebar keeps trying to come out. The PO must have read the things about fasteners on stock bikes being loose and went beserko tightening ANYTHING with threads. I have yet to touch a fastener that has not taken an unbelievable amount of force to undo.
Back to the vibration dampener thing. I thought maybe I could loosen the Phillips head screw to relax it and then shove it all the way back in the bar and retighten it thereby expanding the rubber part. That screw won't budge. What do I need to get ? The whole thing, the rubber part and the screw or some aftermarket one that works better.
Old 01-29-2013, 11:34 PM   #73273
Magnum Noel
Magnum Noel's Avatar
Oddometer: 189
Try using an impact driver, carefully , at first by hand but if no luck then a couple of taps with a hammer may work. It did for me when I had the same problem. Good luck.
Magnum Noel is online now   Reply With Quote
Old 01-30-2013, 05:42 AM   #73274
SCExpat
Ex-expat
SCExpat's Avatar
Oddometer: 634
Originally Posted by doug s. View Post
if it otherwise looks decent, you could always offer $1500, and then walk away if the seller says no...
doug s.
This idea fits my cheap arse just fine. A good deal plus I can get some farkles and still not have much $$$ in it.
A very good point ... and valid reason for concern. When buying ... and I've bought over 50 bikes ... a good idea to have close look at the seller. How is his garage kept? Does he keep maintenance logs? Lots can be learned from his answers regards maintenance or "fixes" he has done on the bike.
All that said ... as I said before ... the DR is a pretty tough customer and can handle abuse well. Still ... a hard used bike would never be my first choice. Good luck! Good shopping.
Good tips. Then I thought about how my garage looks. Time for a clean up.
Part of the fun of buying another bike is the hunt. I enjoy scanning CL and the newspaper seeing what is available. I don't want this to be over too soon as I may end up looking more and getting yet another bike.
SCExpat is offline   Reply With Quote
Old 01-30-2013, 05:58 AM   #73275
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,535
Originally Posted by Sic Semper Tyrannis View Post
That would look sweet next to my Penton
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Times are GMT -7.   It's 01:56 AM.
